Offline Crocodile
#1 Posted : 01 November 2014 09:56:27(UTC)
Crocodile
any problems runningMA 6423 with CS 2. Just want to use loco on a short shuttle route using S-88's
#2 Posted : 01 November 2014 10:34:06(UTC)
Is your question about the Märklin transformer 6423?
The CS2 was not programmed to work with a 10 VA transformer. In case of overload the transformer may switch off before the CS2 does.
10 VA may be insufficient even just for the CS2 and a single train.
And you'll lose the factory warranty trying this.
Offline Crocodile
#3 Posted : 01 November 2014 14:48:03(UTC)
Crocodile
My fault for not being more clear. It is MA 6423 Railbus, which is advertised at Delta Digital. I run all digital stuff using CS 2. Delta digital is something I'm not familiar with.
#4 Posted : 01 November 2014 17:37:25(UTC)
Probably 3423.
Delta is digital and can be run with a CS2. 3423 is a BEMO model in a Märklin box. Nice model, performs better than the average Delta model.
#5 Posted : 01 November 2014 19:19:56(UTC)
Probably 3423.
I prefer to call it a cooperation between Marklin and Bemo. The chassis is clearly marked with the Märklin name, so it's not just a Märklin box.
Offline Crocodile
#6 Posted : 02 November 2014 22:23:40(UTC)
Crocodile
Correct - it is MA 3423. My error. Thanks for all the info. Looking forward to getting same and run it.
Edited by user 14 November 2014 15:34:29(UTC)  | Reason: Not specified
DELTA Digital Problem with 60760 Decoder (Digital)
by marylandmarklin 10/05/2020 04:20:53(UTC)
Marklin DELTA DIGITAL (Digital)
by Rohit279 06/09/2019 15:44:10(UTC)
CS3 and Delta digital (Digital)
by Nick2017 05/04/2018 18:34:13(UTC)
Delta Digital Problem (Digital)
by rossco328 02/03/2013 00:51:31(UTC)
This page was generated in 0.441 seconds.
