Offline marklinologos
#1 Posted : 21 September 2011 14:39:07(UTC)
marklinologos
Hi to all Marklin fans,
I have a transfer table 7294 analog operated but unfortunately after every stop in the exit it never start to move except if I push it with my finger... Do you have any idea what happen....?? I tried to check all metal contacts under the bridge but looks ok. Confused
Thanking in advance for your help...!!!BigGrin
Keep Marklin away from China
#2 Posted : 22 September 2011 23:23:28(UTC)
marklinologos
Confused Confused Confused
#3 Posted : 22 September 2011 23:35:50(UTC)
Have you checked the brushes in the motor?
Offline kbvrod
#4 Posted : 22 September 2011 23:53:26(UTC)
kbvrod
You'll need to take the unit part and begin to inspect everything.Please remember to take photos and notes in doing so.
Dr D
Offline drwhitl
#5 Posted : 23 September 2011 01:20:00(UTC)
drwhitl
I've never laid eyes on one of those, but i think it works in a similar fashion to the old turntable, doesn't it?. If that's the case, then check that the solenoid latch is withdrawing ok, and are the contacts on that clean?. Else it's likely to be a contact issue on the equivalent of the turntable slip rings.
cheers
Marklin transfer table 72941 (Digital)
by Gerald Lynch 14/12/2022 06:27:53(UTC)
Transfer table 7294 catenary (General MRR)
by Boydrlhome 21/11/2022 16:09:09(UTC)
Transfer Table 7294 (H0-scale)
by Tom Jessop 29/05/2015 06:43:26(UTC)
by Tom Jessop 28/02/2015 22:53:38(UTC)
cs 60213 and transfer table 7294 (Digital)
by jamesf 08/01/2011 16:15:14(UTC)
This page was generated in 0.511 seconds.
