Offline arcanjo
#1 Posted : 26 February 2011 15:00:44(UTC)
arcanjo
Hi there!
I would like to know what is the best way to connect an S88 to the layout. I have two pairs of 24995 but there is a note on the instructions manual, that say do not use it to change turnouts or signals wich is my objective. I'm taking the first steps in this matter so I would like to have some suggestions.
Miguel
Offline arconell
#2 Posted : 28 February 2011 01:45:11(UTC)
arconell
Hi Miguel,
That really is an either / or question. You can use the contact rails for switching purposes. In that case you use the contact to close an electrical circuit when a train moves over it. The circuit can switch something through a relay or directly, for instance a turnout motor. Keep in mind that anything that is switched directly should be able to withstand continuous powering, in case the train stops on the contact. Also, everything is switched with current taken from your loco control, be it a transformer when running analog or a digital control station. However when running digital this is not a recommended practice.
Alternatively, you run a single wire from the contact rail to a S88 module, which must be hooked up to a digital system with either a readout for s88´s or with computer control. In that case the signal (mass detection) is used to identify sections of track on your layout that are occupied by a train. When using computer control or an advanced digital system like CS2 that information can be used to follow a train around the layout and to set turnouts and signals in accordance with planned routes around the layout, just as it is done in real life. Here is an example of such a system: Click here.
Regards, Robert
Faulty S88 module? (Digital)
by morsing 12/08/2020 19:52:50(UTC)
Creating a shuttle train route with a S88 module (Digital)
by Rocca 06/05/2013 09:47:05(UTC)
Marklin 60880 s88 module equivalent (Digital)
by biswasg 12/01/2009 07:44:17(UTC)
This page was generated in 0.419 seconds.
