Offline egonzinc
#1 Posted : 13 October 2025 18:22:11(UTC)
egonzinc
Puerto Rico
You have been a member since:: 04/07/2013(UTC)
Looking around eBay there are a lot of the K track catenary in 10x posts packs at reasonable prices.
But don’t see any for C track. The C track posts at retailers come in 5x packs and are a lot more expensive.
I’m thinking of adding catenary to my future C track layout just for cosmetic purposes.
The C track post comes with a bracket that I imagine makes it very easy to install.
Has anyone out there used the K track posts for a C track layout?
I imagine you would need to build a base to the K track post to raise it to the level of the roadbed.
Thanks in advance for any comments or advice.
Eduardo
Offline mvd71
#2 Posted : 13 October 2025 21:29:03(UTC)
Yes, you could easily use the k track masts and catenary wire but you will need to get the height correct. And the catenary wire is different too.
Offline twmarklinfan
#3 Posted : 13 October 2025 23:17:50(UTC)
twmarklinfan
You can get the C track bases as a separate item, 74109. A pack of 20 pieces.
However you will have to decide if you want to use the older now discontinued catenary system or the latest more realistic looking system.
#4 Posted : 14 October 2025 01:02:39(UTC)
Lots of unanswered details here. To start at the top:
OLD MARKLIN CATENARY SYSTEM:
- Don't use the K bases, just fasten the poles to the layout directly.
- As mentioned, the height will be difference
- 74109 is a proper fix, but an expensive and out-of production one. (I've been dying to 3d print a substitute for height and mounting! This is the best answer if you know a designer...)
NEW MARKLIN CATENARY SYSTEM:
- Assuming this isn't what you mean- just buy the proper base for in this case
- To clarify, I can't see any way a K track base can even begin to work
Hope this helps,
-JP
Offline egonzinc
#5 Posted : 14 October 2025 13:22:52(UTC)
egonzinc
Puerto Rico
Thaks guys!
E
Offline TrainIride
#6 Posted : 15 October 2025 08:45:26(UTC)
TrainIride
Well, I'm not claiming it's the best solution, but I built my layout like this:
For my old school hundred catenary masts, I naturally used reference 74109, but I couldn't find many.
So most of the bases I used were M track bases,
with the end that folds down onto the ballast flattened.
I then compensated for the height of the bases by inserting calendar board under the tracks.
To fix the masts on the bases , I used the C track fixing screws.
Best Regards
Joël
thanks 8 users liked this useful post by TrainIride
This page was generated in 0.489 seconds.
