Offline Jose Mº Caparros
#1 Posted : 10 October 2025 12:00:00(UTC)
Jose Mº Caparros
Hola buenas tardes haber si alguien lo lee y lo sabe y si al deco 60906 se le pone el imán permanente , que pasaría se estropearía , seria mas suave , gracias por las respuestas un saludo jose lol!
Hello good afternoon there will be if someone reads it and knows it and if the decoder 60906 is put the permanent magnet, which would pass would be spoiled , it would be softer , thank you for the answers a greeting jose lol!
Online bph
#2 Posted : 11 October 2025 11:26:34(UTC)
This thread also applies to the 60906: https://www.marklin-users.net/forum/posts/t53014findunread-66032-Decoder-with-60943-motor
The 60906 is intended for old fiel coil motors and is unregulated. It also works with the old 35* series analogue 5-star field coil motors, but the top speed will be a bit high. So connecting the 60906 to a permanent magnet motor without the diode solution is not recommended, and won't work. And even with diodes, if it works, I doubt the result would be good, aus ut uses a frequency control optimised for the field coils. I haven't seen anyone trying that, so at your own risk. some more info: [url=https://www.marklin-users.net/forum/posts/m630824-New-decoders-60906-and-60983https://www.marklin-user...decoders-60906-and-60983[/url]
Edited by user 11 October 2025 15:40:14(UTC)  | Reason: Not specified
#3 Posted : 11 October 2025 12:52:24(UTC)
Jose Mº Caparros
Hola y gracias por tu respuesta , mañana probare haber que pasa lo tengo montado y lo pondré en el banco de pruebas , lo comentare un saludo jose
Hello and thank you for your answer , tomorrow I will prove that I have it happening I have it mounted and I will put it on the test bench, I will comment a greeting jose
#4 Posted : 11 October 2025 13:36:22(UTC)
Can I just mention that this site is English speaking.
This page was generated in 0.338 seconds.
