Offline Cfap30
#1 Posted : 09 October 2025 20:24:25(UTC)
Cfap30
France, Metropolitan
Hello everybody,
I really like the old 3021 model but I have one with windows damaged (because of their age, retraction of clear plastic).
Is anybody how to find these parts ? You will save one my favorite old loc...
Kind regards
Offline Bart
#2 Posted : 09 October 2025 21:28:39(UTC)
Bart
You may want to check Centro Assistenza Märklin at Modeltreno.com in Bologna (Ebay name coccodrillo114),
my favourite spare parts distributor.
www.modeltreno.com/2020/marklinservice.html
*Bart
thanks 1 user liked this useful post by Bart
Online JohnjeanB
#3 Posted : 09 October 2025 21:46:20(UTC)
Hi Cfap (a first name would be great)
I found this on ebay Germany This is NOT an original Märklin window
https://www.ebay.de/itm/39662433...D%7Ctkp%3ABk9SR5Dkvaa5Zg
Another solution would be to use a transparent PVC sheet (e.g.: format A4, 0.2 mm thick and cut it to the dimensions of the old one.
To obtain the exact aspect of a Märklin Cellon window, you need to install behind a tracing paper for frosted effect. Alternately, you may paint the rear side of the window in middle grey
Fixing is made by unbending one of the front handles on the top and then bend back after installation
Here is how it looks on my 3021 (1965) when it was factory fresh
You will need to slide the sheet metal cover (red arrow) to remove the light conduit and access to the full window
Offline Cfap30
#4 Posted : 09 October 2025 22:35:10(UTC)
Cfap30
Thank’s a lot, I’ll try this link as soon as possible !
Vincent
Marklin V200 3021 (H0-scale)
by minizazay 30/04/2025 15:22:01(UTC)
This page was generated in 0.273 seconds.
