Offline Alex H
#1 Posted : 02 September 2025 09:19:31(UTC)
Alex H
Hi.
I am looking to create a new layout as per the attached image; the red dots indicate proposed power connection points. The longest length is 4m x 1.1m. I am using Marklin C track, with a Z21 controller and iTrain, with occupancy detection.
I know that usually it is suggested that a track power bus is installed around the layout and then drop wires are used from the track to this bus.
However, I was wondering if there were any operational reasons why the wires from the track connections cannot be run back to the front of the layout and then connected using a strip connector? I appreciate that I will use more wire and I will probably need to increase the gauge of the wire itself.
Very many thanks
Offline osoraku
#2 Posted : 02 September 2025 12:13:01(UTC)
osoraku
Dear Alex - parasitic capacitance can be aproblem, depending on how you do occupancy detection. See, e.g. this discussion for current detection.
Osoraku
Offline analogmike
#3 Posted : 02 September 2025 13:23:30(UTC)
analogmike
Power bus is the way to go. Trust me. ThumpUp
Offline Alex H
#4 Posted : 02 September 2025 15:34:09(UTC)
Alex H
Osoraku
Hi thanks for those post. I will be using the YaMoRC YD6016LN -CS current sensing for occupancy detection
Online PeFu
#5 Posted : 02 September 2025 17:59:05(UTC)
PeFu
Osoraku
Do you have a specific reason for using current sensing instead of ground sensing, which probably >99 % of all C track users, are using?
Smile
Offline Alex H
#6 Posted : 02 September 2025 18:57:30(UTC)
Alex H
Osoraku
Smile
Yep - I find them easier to set up, and they suit my needs. BigGrin BigGrin
Offline BenP
#7 Posted : 03 September 2025 00:59:12(UTC)
BenP
Osoraku
Why not ground sensing? Easy and fail proof with Marklin 3-rail design.
Ben
Ben van der Pluijm--
Offline Alex H
#8 Posted : 03 September 2025 08:59:59(UTC)
Alex H
Osoraku
Ben
So how do you set up your ground sensing then Ben?
Offline BenP
#9 Posted : 04 September 2025 05:06:44(UTC)
BenP
Ground sensing uses track with one outer rail isolated. When metal wheels pass over that track they create a ground connection, sensed by a sensor box. Power to sensor track is uninterrupted and continuous with rest of layout. Works on m, c and k rails.
Offline Alex H
#10 Posted : 04 September 2025 16:17:06(UTC)
Alex H
Thanks for that, so ground sensing works by a physical change, and current sensing works by an electrical change. I imaging they both work as well as each other dont they?
Offline BenP
#11 Posted : 04 September 2025 17:07:16(UTC)
BenP
I believe that current sensing requires power isolation segments (extra wiring), whereas ground sensing can be installed anywhere without power supply breaks. Both require a sensor hub to communicate with central station.
Offline Alex H
#12 Posted : 04 September 2025 17:12:21(UTC)
Alex H
Ah Ok. yes for current sensing you isolate the track at both ends and then have a cable from the track back to the sensor hub. I can see now that Ground sensing would require a lot less wiring, which is always good. Thanks for your help - learning all the time :). I assume that you can use the red Marklin isolators on the rail
Offline blid
#13 Posted : 04 September 2025 17:37:30(UTC)
blid
I think it is worth pointing out that current sensing will only report vehicles currently drawing power. Ground sensing will report all vehicles with non isolated wheel sets – all Marklin and others for 3-rail. Wiring and isolation is about the same. The Marklin C-track isolators can be used to isolate rails as well. However, you have to cut the two connections of the rails on the underside of the C-track pieces involved. I had all my C-track cut except for turnouts.
thanks 4 users liked this useful post by blid
Offline osoraku
#14 Posted : 04 September 2025 23:53:16(UTC)
osoraku
… I assume that you can use the red Marklin isolators on the rail
2 mm OD heat shrink tubing is much cheaper and works a treat.
Osoraku
Edited by moderator 05 September 2025 04:31:32(UTC)  | Reason: Fixed quotes..
thanks 2 users liked this useful post by osoraku
Offline sudibarba
#15 Posted : 28 September 2025 04:17:48(UTC)
sudibarba
That's a lot of wire on a large layout. Very confusing under the layout board. Maybe I don't understand the question.
Offline Alex H
#16 Posted : 28 September 2025 09:24:28(UTC)
Alex H
There will be a lot of wires whatever, and I think that not having any connections under the layout board is probably less confusing. With all the connections at the front and well labelled, I think that maintaining will be a lot easier BigGrin BigGrin
Offline ocram63_uk
#17 Posted : 28 September 2025 12:46:52(UTC)
ocram63_uk
I love the layout!!! The blue track is the only one 'elevated' correct?
Offline Alex H
#18 Posted : 28 September 2025 14:50:05(UTC)
Alex H
Thank you,yes the blue track is the main elevated one, I might add a big sweeping curve into it on the long back straight. I am think that the green track will also be partially elevated, or perhaps the rural line. I find that when you start laying the track, ideas that I haven't thought of, suddenly spring to mind. I can't change the layout too much as I've now built the layout frame, and put the 10mm foam onto it BigGrin BigGrin
I was short shipped one sheet of foam so I have started to plan the control board - going to n need probably six more YD8116's and one 6016ES
M-track power connection device (H0-scale)
by perz 23/03/2004 01:25:23(UTC)
This page was generated in 0.635 seconds.
