Offline Evergreen
#1 Posted : 21 April 2025 15:47:07(UTC)
Evergreen
Croatia
I just recently got a couple of old used märklin cars with what I assume is interior lighting. This made me wonder if I could use them with the light feature on my digital system? I know the article number of a few of the cars. The article numbers are 4027, 4023 and 4032 and they all have the "regular" märklin pickup below the car. One of the cars i got is missing the box so I dont know the article number of that one and it has a slightly different pickup. I will provide a picture of the pickups of that car.
Many thanks
Offline BenP
#2 Posted : 21 April 2025 16:50:25(UTC)
BenP
Lights will work on track power, incl digital AC. Slider is old type and needs exact positioning to avoid shorts that may reset digital control, especially over switches.
Ben
Ben van der Pluijm--
Offline Evergreen
#3 Posted : 21 April 2025 17:18:29(UTC)
Evergreen
Croatia
Ben
Thanks for the reply! Would you say that it is better to use the cars without the slider? The other cars that I mentioned, but did not provide pictures of, all have the "regular/modern" slider. I assume that they dont have that problem?
Offline BenP
#4 Posted : 21 April 2025 17:29:08(UTC)
BenP
Ben
Both work, but short one may flicker lights more. Longer one between wheels is better positioned and has more contact. Just see what works; won't damage things.
Ben
#5 Posted : 21 April 2025 20:25:36(UTC)
Consider replacing the light bulbs.
The type for analogue operation is typically rated 60 mA at 19 V, the type for digital operation typically has 20 mA at 22 V.
Analogue light bulbs can become very hot with digital operation and maybe even damage plastic parts.
Offline Evergreen
#6 Posted : 22 April 2025 00:35:29(UTC)
Evergreen
Croatia
Thanks for the tips! I will certainly try to change the bulbs then. Do you know any good place where you could buy those kinds of bulbs cheap in Europe?
Offline White Buffalo
#7 Posted : 22 April 2025 04:18:51(UTC)
White Buffalo
I have also noticed that incandescent lights in my older 346 wagons, the ICE 37780 (8 wagons) and Rheingold 4228 (with table lights) will put a large power demand on the digital controllers.
#8 Posted : 22 April 2025 04:20:40(UTC)
White Buffalo
She's a beauty by the way!
thanks 2 users liked this useful post by White Buffalo
Offline Bill L
#9 Posted : 22 April 2025 23:43:12(UTC)
Bill L
https://www.lctm.info/Se...teca/Catalogos/index.php
gives link to older Marklin catalogs, with pictures and description. You can find your passenger car here, probably early 1960s.
Try 1960 and page 28 for this red car.
Offline Evergreen
#10 Posted : 23 April 2025 00:41:24(UTC)
Evergreen
Croatia
Originally Posted by: Bill L Go to Quoted Post
https://www.lctm.info/Secciones/Trenes/Biblioteca/Catalogos/index.php
Your right that looks like the car I got. I will have to try to hunt down the other cars! I am trying to find a cheaper alternative than the märklin 43369 car set for my ae 6/6.
Offline Evergreen
#11 Posted : 23 April 2025 00:47:44(UTC)
Evergreen
Croatia
I am currently using a MS2 so a larger power demand on the controller is probably not optimal in my case. I will have to try fix those bulbs... I have the märklin 26750 set which I think includes the same Rheingold cars as the ones you have. I did not even consider that those also use the old kind of lights.
Offline mvd71
#12 Posted : 23 April 2025 06:18:56(UTC)
Try these: https://www.ebay.de/itm/...D%7Ctkp%3ABk9SR6qH7o3MZQ
Offline mvd71
#13 Posted : 23 April 2025 06:24:13(UTC)
Or these for an older yellow look: https://www.ebay.de/itm/...D%7Ctkp%3ABk9SR5qjlI7MZQ
Offline Evergreen
#14 Posted : 23 April 2025 18:09:13(UTC)
Evergreen
Croatia
Thanks! I will look into that!
#15 Posted : 24 April 2025 19:55:39(UTC)
White Buffalo
Here is a list of Wagons that will go with it sir, I'll try to go through what I have this weekend if you might be interested. Just PM me if you are.
#16 Posted : 24 April 2025 19:58:55(UTC)
White Buffalo
I started checking various sets & wagons when I experienced a couple of overloads to the limit I had set. I am using the load monitor on the ESU Command Station, I am sure you have a similar way to monitor. ThumpUp
thanks 1 user liked this useful post by White Buffalo
Offline BenP
#17 Posted : 24 April 2025 23:02:59(UTC)
BenP
I have those too. Refitted with led strips but then retrofitted with old overhead light holders, using leds instead of bulbs. Gives that 1960s vintage look. Low power draw in both cases.
Offline Evergreen
#18 Posted : 26 April 2025 21:12:11(UTC)
Evergreen
Croatia
I am still a beginner when it comes to model model railroading so I have never checked how much power my trains are drawing but I assume that I can do that on my MS2. Regarding the Rheingold set, I have never actually used the complete train yet becuase I found it to be such a pain to use the old powered couplings to connect the cars together.....
Offline Evergreen
#19 Posted : 26 April 2025 21:18:32(UTC)
Evergreen
Croatia
Speaking of wagons, I have had a bit of trouble with the coupling on a märklin 4788 set that I picked up lately. The wagons are using an "old style" coupling that I find quite to couple with the new style coupling. Do you guys know a good way to replace the coupling on these kinds of old wagons?
thanks 1 user liked this useful post by Evergreen
Offline mvd71
#20 Posted : 26 April 2025 21:21:07(UTC)
If by powered coupling you mean the drawbars that have to be inserted into the nem pocket everytime, these can be replaced with couplers: https://www.maerklin.de/...ts/details/article/72025
Offline mvd71
#21 Posted : 26 April 2025 21:29:21(UTC)
That one could be more tricky: https://www.maerklin.de/...cts/details/article/7205
Or perhaps you could find a suitable NEM pocket as a sparepart to retrofit?
Online marklinist5999
#22 Posted : 26 April 2025 23:57:53(UTC)
I still use some of the old current conducting draw bars. They are trouble free for running because they flex up and down and twist. Just a hassle railing a train. So I keep two coupled and use the close current couplers between the pairs.
#23 Posted : 27 April 2025 21:13:30(UTC)
White Buffalo
I installed these a few years ago and they work well ThumpUp . Prior to installing, just clean the copper contacts on the car with some rubbing alcohol on a Q-Tip so you get a good electrical contact & no light flickering. You can get them directly from Marklin, Trainz or Ebay as well.
Offline Evergreen
#24 Posted : 28 April 2025 01:05:51(UTC)
Evergreen
Croatia
Thanks! those couplers sure would make coupling the train a lot easier.
Offline Evergreen
#25 Posted : 28 April 2025 01:18:59(UTC)
Evergreen
Croatia
The coupling looks like this: b2dd4ea2c7c15586876c52172580921f.png It looks like it would be quite difficult to replace it, but I have no clue.
Offline mvd71
#26 Posted : 28 April 2025 06:51:02(UTC)
Yeah, the ones in the link may work, but it’s hard to say. Those ones are held on with a retaking ring on what looks like a metal bogie. Might take a customised solution.
#27 Posted : 08 May 2025 03:41:45(UTC)
White Buffalo
Is the Marklin 4788 the 3 wagon Tank Car set? If so, you would not need the current conducting couplers (for interior lighting) that I posted.
This page was generated in 0.598 seconds.
