Offline osoraku
#1 Posted : 16 March 2025 16:52:36(UTC)
osoraku
Dear All -
I have two Märklin C track turnouts 24611 & 24612 with factory-installed turnout mechanisms (74491). Both are programmed to operate under DCC by the DIP switches. These have worked fine under digital control with an MS2 controller and a 60116 Gleisbox, and with Rocrail for months (since setting up the track layout).
They recently stopped working for no apparent reason. I had not switched either of the turnouts for a few days, and when I tried to operate them digitally they would not respond. Mechanically they are fine - they freely switch directions manually with no apparent mechanical resistance to touch. Now neither the MS2 nor Rocrail can operate them.
I put a CAN packet sniffer into the transmission path between the Rocrail and the Gleisbox. The command to switch directions is sent; the Gleisbox acknowledges the command; and the DCC agent in the turnout/switch also responds to acknowledge the command. This shows that the switch is responding to DCC communication on the rails, but it is simply not budging from its position.
There is no movement on either switch.
If anybody has similar experience with making the turnouts work again, please share it.
Osoraku
Offline Johnvr
#2 Posted : 16 March 2025 17:45:51(UTC)
Johnvr
Hello Osoraku
The most likely cause is that the micro switch inside the solenoid mechanism has failed.
The micro switch is there to protect against prolonged activation when used in an analog mode.
For example, if a locomotive gets stuck on a section of track where the activator is triggered.
The common solution when using digital operation is to bypass the micro switch.
There are various articles on how to do this, which you can locate in this forum.
Essentially, you need to open up the solenoid mechanism, and solder a wire across each of the two micro switches.
You need to be able to operate a soldering iron in order to do this.
Fixing Turnout Solenoid Mechanism
Offline osoraku
#3 Posted : 16 March 2025 19:46:55(UTC)
osoraku
Dear John -
Many thanks for the video pointer. After watching the diagnosis & remedy however, I can't imagine how the two turnouts failed essentially simultaneously ... and they are only 3 months old. Notwithstanding the doubts, it should be easy to check whether that fixes the problem by testing with jumpers across the microswitch terminals. More as and when.
Osoraku
#4 Posted : 16 March 2025 20:07:55(UTC)
Hi Osoraku
Just a shoot in the dark.
IMO there is NO WAY that an MS2 and its Gleisbox 60116 would have destroyed SIMULTANEOUSLY two decoders and still work.
Another possibility is MAYBE an anlogue use of the track and switches with an old transformer. The overvoltage can easily kill decoders without leaving traces. Those decoders are VERY fragile
Offline rhfil
#5 Posted : 16 March 2025 21:41:07(UTC)
rhfil
I agree plus my experience with failing micro switches is they continue to operate in one direction. Easy way to tell is replace one decoder.
Offline osoraku
#6 Posted : 23 March 2025 15:30:48(UTC)
osoraku
Dear All -
Following the procedure recommended by JohnVR & rhfil, I removed the solenoid from its cover and shorted across the microswitch terminals to test. There is no response to the digital signal to switch the points. To verify that the microswitches were working correctly, I moved the solenoid to each of its limit positions and tested each switch to verify that they turn on and off. Hence it is not a problem with the microswitches.
I traced the CS2 protocol packets sent by the controller to the turnout to move the points. There are three packets sent:
  1. controller → track to actuate the switch (CS2 protocol packet 0x'0B', command, rocrail CAN hash);
  2. gleisbox → controller to confirm switch actuation and send DCC command to switch on the rail (CS2 protocol packet 0x'0B', response, gleisbox CAN hash);
  3. DCC agent (turnout) → controller to confirm switch actuation (CS2 protocol packet 0x'0B', response, DCC agent CAN hash).
So the DCC agent in the turnout thinks it is actuating the points, but they do not move. I can only surmise there is a fault in the electronic side of the turnout making it unable to power the solenoid.
Jean suggested that the electronics were quite fragile. I have no analog transformers to blame the fault on, but it is possible that a derailment briefly shorted out the track circuit. Could this cause both turnouts to simultaneously fail?
Any further diagnostic comments welcome.
Osoraku
Offline Copenhagen
#7 Posted : 23 March 2025 21:50:10(UTC)
Copenhagen
About a month ago I had a turnout with a built in decoder that failed. It wasn't the switch motor that failed but the decoder that stopped working. I have some switch motors that I have fixed in the past. I have both a number of decoders for turnouts and also a number of m83s that can operate up to four motors each. I connected the switch motor to a free spot on an mk83 to get it to work again. I run everything with a CS3 and the standard power supply for it.
Offline blid
#8 Posted : 23 March 2025 22:26:24(UTC)
blid
Can’t you just test the turnout motor analogue style - without the decoder? The yellow wire to track power/B/red/studs. Then quickly touch a rail with the blue wires one at a time.
Offline osoraku
#9 Posted : 24 March 2025 09:45:19(UTC)
osoraku
Dear All -
Problem resolved. Put each turnout onto the programming track, set CV8 = 8, and now each works again. No mechanical problems, no other settings changed. (No idea why a reset was needed, either!)
Thanks to all for the feedback.
Osoraku
thanks 5 users liked this useful post by osoraku
Offline rhfil
#10 Posted : 24 March 2025 12:46:18(UTC)
rhfil
Wow. Interesting. Never would have tried that.
Offline White Buffalo
#11 Posted : 22 April 2025 04:35:12(UTC)
White Buffalo
Interesting, I just had two switch motors start to act intermittently.
#12 Posted : 26 April 2025 03:38:00(UTC)
White Buffalo
Originally Posted by: osoraku Go to Quoted Post
Dear All -
Osoraku
I’m trying to test two of my switches that stopped working as well. Same symptoms, will not respond to the digital command from Rocrail or the ESU command station.
What program did you use to read the switch CV 8? I have the ESU Lokprogrammer and a ESU Command Station…Confused
Offline osoraku
#13 Posted : 26 April 2025 07:37:36(UTC)
osoraku
Dear WB -
It makes no odds. SET CV8 = 8 to reset, no matter what value the CV has. I used my MS2 to change it, I think.
Osoraku
thanks 1 user liked this useful post by osoraku
#14 Posted : 26 April 2025 10:21:55(UTC)
Hi WB
With Rocrail, the possible errors could be:
- not to declare the central station in charge of the switch / signal in the field "Interface ID"
- not to declare which protocol. Avoid using "default" but rather Motorola (MM2) or NMRA DCC
- not to include the address in the field "Port1". A common error is to include it in the field "address"
The switches will not respond when they are reserved so unreserve them / restart Rocrail
#15 Posted : 26 April 2025 14:45:05(UTC)
White Buffalo
Thank you ThumpUp
Offline Alex H
#16 Posted : 01 November 2025 16:06:42(UTC)
Alex H
Hi, I ma having the same issues.
I am running under DCC with a YaMoRC YD7010 controller.
I am building a new layout using the Marklin C track - turnouts fitted with 74462 decoders and 74491 motors. A number of the turnouts are switching intermittently on the main track. However on the programming track, the same turnouts perform faultlessly. I have tries a CV8=8 reset but to no avail.
I am puzzled as to why the turnouts are working impeccably on the programming track, but not on the main layout.
Any help VERY much appreciated as I have come to a stop on building the layout till I can resolve this issue
Alex
This page was generated in 0.658 seconds.
