Offline Conductor0179
#1 Posted : 17 December 2024 06:04:41(UTC)
Conductor0179
I have been running an old 3000 model loco and an F44039 for the last couple of weeks. Neither had been run for many years but seemed to be doing fine. All of a sudden both are having problems. Does anyone have a shop that works on Marklin engines? I live in an area of New Mexico where we don’t have services like this.
Offline mvd71
#2 Posted : 17 December 2024 06:35:27(UTC)
What are the symptoms? People here may be able to guide you in diagnosing and repairing yourself.
Cheers….
#3 Posted : 17 December 2024 10:32:08(UTC)
I guess that both locos, because of inactivity, have some greasy deposits in the axles which make a poor ground return.
One simple solution is to lubricate the driving axles and then, let them run for half an hour in both direction
Then, wipe out the oily residue out of the axles.
At the beginning they will stop all the time but after a while it will improve a lot
Offline ocram63_uk
#4 Posted : 17 December 2024 11:38:18(UTC)
ocram63_uk
For engines that have been kept in boxes for decades I first remove the motor shield and rotor and then wash them with WD-40 until I get axles and distribution to move freely. Once this is done I dry up as much as possible the excess of WD-40, reassemble everything and put back on tracks. Let them run for a bit, in both directions, at low speed and then apply a drop of oil on each side of the axle and start running them at medium speed and high speed in both directions. Job done.
Offline Harvey
#5 Posted : 17 December 2024 17:50:32(UTC)
Harvey
It's good to first try the suggestions of others. Regarding repair shops. Not many in the USA but the following could help if your efforts don't work. I have no experience with either but some other members likely have.
http://helmutshobbies.com/service_center.htm
Either Rick or Curtis does repairs. Not sure which one. They run the Marklin Digital Club
To contact Rick and Curtis for help with your Digital, technical and product related questions:
Phone: 650-569-1318 Hours: 6:00am – 9:00pm PST. Monday through Friday.
E-mail: digital@marklin.com
rjftrains@aol.com
Harvey
thanks 1 user liked this useful post by Harvey
#6 Posted : 17 December 2024 18:07:47(UTC)
I would contact AJCKids in Texas or maybe one of the dealers in Colorado
Rick and Curtis might also be a good place to get assistance
As far as your models, what problem exactly are they having? (Both the same or different issues?)
You could try checking to see that the rails are clean and that the contacts between track sections are ok,
You can clean the slider with rubbing alcohol and check the axle contacts to make sure there is no dirt/lint
#7 Posted : 17 December 2024 21:48:45(UTC)
Rick Sinclair does repairs.
Online dickinsonj
#8 Posted : 18 December 2024 00:50:08(UTC)
AJCKids is located in Wichita Falls, Texas and Guy is an expert at Marklin repair.
I would first try the cleaning tips suggested above though, which is a good way to get acquainted with those locos.
If that doesn't work, you might contact Guy and see what he suggests or just send them to him for repair.
Email: service1@ajckids.com
Offline DB Fan
#9 Posted : 18 December 2024 02:08:38(UTC)
DB Fan
Unfortunately I live near Glenwood Springs, CO or I would swing by or have you come over to look at them. I do all my own repairs. If you don’t have any luck with finding someone to repair them I could take a look at them (not charging anything for it) or we could do a google meet or face time and I could walk you through it to see if it is something simple to fix or clean.
Just send me a pm.
Robert
thanks 1 user liked this useful post by DB Fan
#10 Posted : 19 December 2024 12:30:37(UTC)
Guy at Ajckids is very experienced and knowledgeable about repairing and upgrading to digital and sound. Almost every item in their site has an instruction and or a video of how to use, connect and install it,
#11 Posted : 19 December 2024 15:54:50(UTC)
Conductor0179
Thank you!
thanks 1 user liked this useful post by Conductor0179
This page was generated in 0.441 seconds.
