Offline jaakkomu
#1 Posted : 01 April 2024 17:37:03(UTC)
jaakkomu
I would like to have a list of Märklin wheelsets including eg:
- part number
- rim diameter
- axle lenght
- design: tapered axle or not
Does somebody knows where to find?
#2 Posted : 01 April 2024 23:11:25(UTC)
Hello jaakkomu
Here are some notes I made in 2020.
This might be a start for you.
700020: Wheel Dia: 12 mm Axle Length: 24.9 mm Design: stepped axle
700070: Wheel Dia: 12 mm Axle Length: 25.2 mm Design: stepped axle
700080” Wheel Dia: 12 mm Axle Length: 26.2 mm Design: stepped axle
700100: Wheel Dia: 10 mm Axle Length: 26.0 mm Design: stepped axle
700150: Wheel Dia: 10 mm Axle Length: 24.4 mm Design: tapered axle (this is the standard fittted to most European rolling stock)
700190: Wheel Dia: 10 mm Axle Length: 24.8 mm Design: stepped axle
700200: Wheel Dia: 10 mm Axle Length: 24.1 mm Design: stepped axle
700230: Wheel Dia: 10 mm Axle Length: 24.4 mm Design: tapered axle, spoke wheels
700530: Wheel Dia: 12 mm Axle Length: 24.9 mm Design: stepped axle
700590: Wheel Dia: 10 mm Axle Length: 26.0 mm Design: stepped axle, DC
700600: Wheel Dia: 10 mm Axle Length: 24.8 mm Design: stepped axle, DC
There is also a 9mm diameter wheel fitted to US rolling stock.
Offline jaakkomu
#3 Posted : 02 April 2024 12:45:49(UTC)
jaakkomu
Thank's kimballthurlow
I have noticed your fine list allready before. It's fine start but unfortunately it's not completed. I have noticed that there are more wheelsets eg.
700120
700270
700280
700630
Sometimes it is very difficult to understand what is the right wheelset for some wagon. It is also challenging to find all those types in the market.
GR
jaakkomu
Online H0
#4 Posted : 02 April 2024 13:55:41(UTC)
It'll be difficult to compile a complete list.
There also are wheelsets with 8-digit numbers for some rolling stock.
When you have the reference number of the rolling stock, then it should be possible to find the suitable wheelsets.
Are you asking for specific rolling stock?
Offline jaakkomu
#5 Posted : 02 April 2024 15:04:06(UTC)
jaakkomu
I need eg. information for Märlin 4015 and 4017. What wheelsets they use?
I wonder why Märklin doesn't have a complete list of wheelsets?
jaakkomu
This page was generated in 0.403 seconds.
