Offline jpklecker@yahoo.com
#1 Posted : 13 November 2023 23:51:42(UTC)
jpklecker@yahoo.com
Has anyone who is familiar with this new model experienced any issues with the two motors working against each other (e.g. not in synch) like the issues with the Ae 8/14 motors? I like this loco due to the older style side rods but am concerned about this possible issue.
John from AZ
Offline Dave Banks
#2 Posted : 14 November 2023 05:02:20(UTC)
Dave Banks
https://static.maerklin....cfcc6e40161647521154.pdf
I can only imagine one of the motor wires have to be swapped around if the one motor is fighting the other or the mapping has to be tweaked as an incorrect box has been ticked.Confused
D.A.Banks
#3 Posted : 14 November 2023 21:29:14(UTC)
jpklecker@yahoo.com
Actually I have not yet purchased one of these locomotives, I was just wondering if anyone that has one had encountered a problem with the two drives being out of sync.
John from AZ
Offline franciscohg
#4 Posted : 15 November 2023 14:04:38(UTC)
franciscohg
Chile
Hello, mine works just fine, as well as my old 8/14
#5 Posted : 15 November 2023 15:00:42(UTC)
There are a few things to check. Install the loco upside down on a foam bed and power it
- if the 2 wheel groups run against each other, then someone has modified the wiring
- if the 2 wheel groups run in the same direction but with different speed then one of the motors is probably faulty (can order at Märklin for 25 to 30 Euros
Offline dickinsonj
#6 Posted : 17 November 2023 01:50:55(UTC)
I have the 2014 double Crocodile set with two motors per loco and I have never seen any problems with them.
As far as I can tell both motors work perfectly in synch without any issues and they run beautifully.
#7 Posted : 17 November 2023 02:04:55(UTC)
jpklecker@yahoo.com
Thanks for the replies and information from everyone, glad to know this locomotive works correctly with two motors. Guess I will go find one before they are no longer available.
John from AZ
This page was generated in 0.408 seconds.
