Offline Rosscoe
#1 Posted : 05 June 2023 10:02:08(UTC)
Rosscoe
Hi All,
I'm trying to identify this decoder.
The markings on the PCB are:
MTX10
No other markings, it's in a converted 3005 loco.
TIA
Offline heinrichhess
#2 Posted : 05 June 2023 10:56:14(UTC)
heinrichhess
the dial's are for max speed and acceleration delay and pins are to set address and you got motorola logo on it
Offline Rosscoe
#3 Posted : 05 June 2023 11:01:39(UTC)
Rosscoe
Thanks. I'm aware of all that but what decoder is it?
#4 Posted : 05 June 2023 11:04:03(UTC)
heinrichhess
i would say old 6090 generation decoders but i quite new so good luck hess
#5 Posted : 05 June 2023 11:36:34(UTC)
Not a simple task.
The logo on the chip is not Motorola, it is Microchip.
It looks like a programmable decoder (PIC) and those programmable decoders typically do not have pots. But who knows.
Does not look like a 6090 or 6090x decoder.
Does it support DCC? Can you read CV 8?
#6 Posted : 05 June 2023 12:38:44(UTC)
It is definitely not a marklin manufactured decoder. It looks like some third party attempt at a 6090 series copy, with the two pots to adjust top speed and acc/dec delay, and the microswitches for address setting.
I suspect it is someones home brew decoder, rather than a commercial one, as the soldering does not look like what I would expect for a commercial product, although, having said that, it could be low production volume hand soldering.
As Tom (H0) said, the logo is not Motorola, but Microchip, and the chip part number is definitely Microchip. It is also a very old microprocessor as it is a PIC16C family instead of a PIC16F family, so that probably makes the design 20 years old or more.
H0bph
#7 Posted : 05 June 2023 15:37:47(UTC)
A warning! Do not use this home made decoder with Märklin system!!! You might destroy digital system. If not less decoder might shut system off.
#8 Posted : 05 June 2023 15:59:28(UTC)
Ah. What do you know about this decoder?
It was installed in a Märklin 3005.
And Märklin digital controllers have overload protection that should prevent them from destruction.
#9 Posted : 05 June 2023 21:24:19(UTC)
heinrichhess
will be interesting to see if dip switches match marklin ID
#10 Posted : 05 June 2023 21:28:29(UTC)
Probably not. This decoder uses 8 input pins, allowing 256 switch combinations while Märklin decoders only use 4 input pins, allowing 81 switch combinations.
Offline pederbc
#11 Posted : 05 June 2023 21:57:22(UTC)
pederbc
Hmmm, 4 binary switches will only provide 16 combinations…
#12 Posted : 05 June 2023 21:58:33(UTC)
Märklin is a ternary system, using trits, not bits.
Offline pederbc
#13 Posted : 05 June 2023 23:13:06(UTC)
pederbc
So you mean that the switches has 3 states?
#14 Posted : 05 June 2023 23:40:32(UTC)
The switches have two states, but there are two switches per decoder input. And that is the source of the 80 address limit.
But that is probably off topic, as the decoder discussed here has 8 inputs and not just four.
#15 Posted : 06 June 2023 00:25:08(UTC)
It is possible that it encodes in exactly the same way as the standard MM decoder, which does have 8 switches going to 4 pins.
To pederbc, note that the marklin decoder switches never have switch pairs both on at the same time. Look at a switch table, at say switches 1 and 2, the valid states are both off, switch 1 on with switch 2 off, or switch 2 on with switch 1 off. The table never defines a state where switch 1 and switch 2 are both on to produce a valid address, as this switch combination shorts out the power supply within the decoder.
The same occurs for switches 3 & 4 as a pair, 5 & 6 as a pair, and 7 & 8 as a pair.
#16 Posted : 06 June 2023 08:20:03(UTC)
Decoder seems are home made.
Those are always risk and never ever should be use.
Offline Rosscoe
#17 Posted : 06 June 2023 09:24:08(UTC)
Rosscoe
Futher info.
It doesn't work on any system. Marklin, DCC or analogue (AC or DC).
The motor does work. It's been converted with a permanent magnet so will run with DC applied directly to the brushes.
So I'll just replace it with a lokpilot and go from there.
Thanks to all anyway.
And I doubt that a single loco decoder would damage a control system, both my Marklin and DCC systems have built in protection.
thanks 2 users liked this useful post by Rosscoe
#18 Posted : 06 June 2023 09:40:22(UTC)
Never ever trust advice from a stranger. There is always risk of false information.
Oh, wait, you are a stranger for me. And I am a stranger for the folks here. Who can I trust here?
What if the decoder uploads malware to the controller? Cool
Offline Rosscoe
#19 Posted : 06 June 2023 09:57:40(UTC)
Rosscoe
As closer view of the decoder.
The switches are connected in a straight binary fashion.
So that gives 255 possible addresses.UserPostedImage
Offline Rosscoe
#20 Posted : 06 June 2023 10:05:03(UTC)
Rosscoe
So you're saying I shouldn't use the 10 DCC accessory decoders that I designed and made which have worked flawlessly.
Why would a simple loco decoder damage a controller? It's never going to put more back to the controller than what it's getting from the controller.
Just because it's home made doesn't mean there's a problem with it.
I've had a digitraxx and lokpilot loco decoder both fail and all that happened is that the loco stopped working. Did not even cause a short and shutdown the controller.
Other than the soldering on this which looks to be done by hand rather than machine it appears to be well made with good quality components.
thanks 3 users liked this useful post by Rosscoe
#21 Posted : 07 June 2023 07:02:30(UTC)
It is difference between manufacture warranty decoder from home made decoder.
It´s your own risk and if digital system fail and you have no warrenty that cover.
You have still not identify decoder you show up with a picture?
No one other did either too.
#22 Posted : 07 June 2023 09:05:55(UTC)
Actually there is no difference when you buy a loco from second hand: manufacturer warranty typically is expired.
Offline ocram63_uk
#23 Posted : 07 June 2023 16:24:31(UTC)
ocram63_uk
Views messages in topic : 740
The question here is: does the loco work with this decoder?
Yes, keep decoder
No, change decoder
The motor has a permanent magnet?
Apply dc current to motor and see if it turns.
It turns? change decoder with multi protocol
Does not turn? motor blocked, fix motor
Solution? change decoder, who cares who built it😊
Keep it simple 👍🏻
#24 Posted : 08 June 2023 04:47:53(UTC)
We are not discuss about loco.
The problem are decoder.
A own home made decoder are not trusting and it is difference too if a manufacture decoder was install in the loco instead.
That make a sense.
Offline vmsysprog
#25 Posted : 08 June 2023 20:09:17(UTC)
vmsysprog
Interesting that the PIC chip is still manufactured. Being a PIC, it is programmable. Would be interesting to see what the code does.
Steve
Guest (4)
This page was generated in 0.560 seconds.
