Offline jsnoddy
#1 Posted : 16 January 2023 18:54:11(UTC)
jsnoddy
I purchased both Faller 161651 Traffic-control and Faller 161654 Traffic-light-control thinking I could make them work together. Sadly, that doesn’t seem possible. 161654 works fine with two stops and two traffic lights, but the only way to control them is by setting a delay timer. But I want to control the stops based on sensors in the roadbed. I can do this with 161651, but now the traffic lights don’t sync up with the stop actions. Has anyone dealt with this situation? I know going digital could resolve this, that option is just too expensive for me.
thanks 1 user liked this useful post by jsnoddy
Online marklinist5999
#2 Posted : 17 January 2023 01:38:17(UTC)
No, and cost is why I don't have one yet. Have you seen the new Viessmann 8000 carmotion? Each vehicle has infrared sensors. No digital needed. About $220 for the start set. Comes with mini usb charging cord, guide wire, magnetic wand, and permanent road magnets. 35 minutes quick charge for 2 hour run time. A remote control is $15, as is a mini usb prgrammer. I'll wait until another set is available with a diffrent vehicle other than an Actros dump truck.
#3 Posted : 17 January 2023 03:24:20(UTC)
Yes, and Modellbahn Lippe won't sell them outside of Europe.
Offline DB Fan
#4 Posted : 17 January 2023 04:17:26(UTC)
DB Fan
Where did you find the start set that includes the guide wire?? So far I saw it only without the guide wire that needed to be purchased separately. Let me know please. Thank you.
Robert
thanks 1 user liked this useful post by DB Fan
#5 Posted : 17 January 2023 07:46:19(UTC)
How interesting Blink
Why do you think that is David?
Philip Smile
#6 Posted : 17 January 2023 12:38:16(UTC)
Like you I started with modules like the one you mentioned but also the Rola but soon there was a need for changes, adaptations.
So I ended up connection sensors to my Märklin CS3 and Rocrail and process the signals exactly as if it was a train.
It is cheaper and you do exactly what you want:
- processing at grade levels
- interval control
- 3 road intersections
- interference of Bus stops at traffic lights
Here is what I mean
On the Rola, after I burned "Freimachtspulen" (liberation coils) I installed thermal switches on coils so that, as soon as they get warm, they switch off.
It gives this
#7 Posted : 17 January 2023 13:56:38(UTC)
The Viessmann 8000 complete start set with the blue MB Actros dump truck includes the guide wire. Read the full spec. descriptions. Other start sets with different trucks do not, nor all of the other items. Modellbahn Union has them, and I wasn't aware that Lippe Detmold won't sell them outside Europe.
They may have limited stock, because The Viessmann spokesman said at the recent exhibition that the chip shortage had affected it's release.
Perhaps the Faller electronic modules can be used only to automate the signals?
#8 Posted : 17 January 2023 20:40:01(UTC)
Those are nice, they integrate the DC Car / Open Car type technology into a more mass produced major brand, a good move.
But that doesn't solve the issue the OP had about traffic lights and traffic control, I think.
Offline TrainIride
#9 Posted : 18 January 2023 17:26:46(UTC)
TrainIride
on the unexpensive side of the thing, I had made some experiments with 161773 Roadbed sensors.
They are kind of Reed switches, so if we take care of the feeding current passing through,
we can easily drive some bistable relays (using a few common electronic components)
to sequence stop sections and simultaneously traffic lights...
The wiring diagram is in the movie, maybe it can give you some ideas...
Best Regards
Joël
Edited by user 19 January 2023 10:25:43(UTC)  | Reason: Not specified
#10 Posted : 18 January 2023 21:02:26(UTC)
After reading the Viessmann carmotion manual on their website, it states "not intended for use in the USA, China, or Taiwan. I can guess that our FCC "federal communication compliance has not been approved. This mean s an electronic devic emay not emit any frequency which could interfere with any Govt. used one, but it can not be isolated from such frequencies either. This doesn't make sense given the very short range of the I.R. sensors, and remote. American dealers have it listed for preorder reservation.
It says the system is compatible with exhisting ones already on the market. That may mean Faller?
The guide wiring isn't included as I thought, but is an additional 15 euro.
Offline Nielsenr
#11 Posted : 18 January 2023 22:51:20(UTC)
Nielsenr
Hey!! Although I have been a member here for quite sometime, I haven't been on the forum for a few years. I happened to go on today to see comments on the new Marklin items and to see if there was a post by Stevetrain on the estimated delivery schedule that he use to post, and I saw this thread.
I have used both of these Faller items in the past. On a client's layout I used the 161654 controller and added some hardwired relays and sensors to add additional stop sections on each side of the traffic signals. I also have "kit bashed" using the 161651 controller and a servo controller to activate RR crossing gates and also stopping the cars. The last thing I worked on was similar to what I think you want to do. It was on an O Scale layout using some O Scale cars from a company called Automotion FX (I think that was the name of the company) and the Faller hardware.
I assume you want three cars in each direction to stop at a traffic signal when it turns red and then release the cars in sequence when the traffic signal turns green. I also assume you are only trying to control a two way intersection, not a three way or four way. Under program 15 on the 161651 controller, you need a dry contact closure at E3 to stop the cars and a dry contact closure at E4 to start the cars back up. You should be ale to connect a 12v "unlatched" relay to one of the stop solenoid connections on the161654 when it is energized for the stop position to energize the relay. The normally open position of the relay would connect to E3 (the normally open position of the relay will close when the relay is energized) and the normally closed position of the relay would connect to E4
I am willing to rethink this if someone finds a flaw in my logic. Also, if you are trying to do something different than what I am assuming, I would need a more detailed explanation.
Robert
thanks 2 users liked this useful post by Nielsenr
#12 Posted : 19 January 2023 01:36:55(UTC)
I agree with TrainIride.
To organize a road layout with Faller bricks can become expensive (stops, deviations, etc)
Below is a simple example of a combination of one stop (traffic light) and one deviation.
The starting point is because it was on a bridge there was no space to install the very large stop coil and the very long and fragile deviation coil.
So I used a disposable cleaner's hanger to shape a stop and a deviation.
Here is the underneath of a road bridge made of Laserstreet elements that you can see during operation testing
The brain is a very inexpensive servo purchased from China (3 to 5€ apiece) and a servo controller from ESU
You may see that one servo moves a magnet close to the "street" to stop cars and away 5 to 6 mm to let them go
The deviation is a bent iron wire underneath the street to guide the car out.
Since this first approch I found much easier to drill a hole in the laserstreet and cover the hole with a thin plastic.
Underneath a bent iron wire (my disposable hanger) rotates to go in the hole as ordered by a servo motor. A little magnet (watch for proper polarisation) attracks the slider of the car in the deviation mode. The the wire plunger is not up in the street then the car / truck goes stratit ahead. Seems complex but it is not (can be made in less than one hour)
Where to drill the deviation hole?
Here is a picture with dimensions of a standard deviation cover and the Blue and Yellow points indicate where to locate these holes to deviate either to the right or to the left.
The other very important bricks are the Faller sensors 161773 and the magnets 163221 for stops or for differentiation of vehicules (Buses, Trucks, others).
I also found that the key tool is the groove cutter 161669.
You can see the bridge (on the left) in operation on this video
Note: the bridge on the right has also 2 servos (1 for stopping and one for the left turn)
Regarding Faller automation block, I find them expensive and good in stand-alone mode (cannot be combined) and non modifyable (try to manage a 3 road intersection with the traffic-Light control 161651. It goes much easier and flexible using like for trains, the sensor feed-back and the modules to drive switches, the brain being a CS3 or Rocrail
Just my opinion
Faller car system - stop section does not work 100% - reed contact (H0-scale)
by fvri 26/02/2010 10:38:15(UTC)
Faller Car System - crossing C tracks (H0-scale)
by fvri 14/12/2009 22:40:28(UTC)
Faller Car System Stop Light Question (General MRR)
by elliottpd 08/07/2007 04:21:32(UTC)
faller car system... (H0-scale)
by littledragon 15/04/2007 02:43:51(UTC)
Faller Car System (H0-scale)
by CCS800KrokHunter3 13/04/2007 22:56:57(UTC)
This page was generated in 0.583 seconds.
