Offline mrunix
#1 Posted : 29 April 2022 21:43:19(UTC)
mrunix
Hello
I find it hard using the documents to see how the physical connection of a cables to the SwitchPilot 3 is done.
Is it using screws or some special connector?
#2 Posted : 30 April 2022 12:03:38(UTC)
The user's manual can be downloaded here
00221-24443_SwitchPilot3_SP3_51830_ESUKG_EN_Betriebsanleitung_Auflage-2_eBook.pdf (2,552kb) downloaded 23 time(s).
On page 5 it says "The SwitchPilot 3 is supplied with 5 detachable terminal blocks (1x
4-pole for the track connection, 4x 5-pole for the outputs) as well
as this operating manual. Under part number 51800.SP.01 a pack
of replacement terminal blocks is available from ESU.3
The detachable terminal are screw terminals
On page 11 power connection is shown
On page 12, Switch / signal / Lamps / LEDs is shown
I hope this helps
Offline mrunix
#3 Posted : 30 April 2022 12:17:35(UTC)
mrunix
How come I missed that, my wife is mayby correct when she says I am blind :)
Thanks alot Jean
This page was generated in 0.360 seconds.
