Offline Puttputtmaru
#1 Posted : 15 March 2021 19:05:44(UTC)
Puttputtmaru
It has been suggested in one of my other thread to use Merkur track bed for my flex track.
What makes Merkur track bed different from any other. I looked at the web site but all I can guess is that there is an indent in the cork for track placement?
Seems to me like a big investment, is it worth the benefit? If so why?
Offline Harvey
#2 Posted : 15 March 2021 19:40:38(UTC)
Harvey
I recently switched to K track and purchased the Merkur track bed. While they suggest gluing the bed to the surface, I have not done this, I rely on the fit of the track into the bed, the level surface and the weight of the train to keep it from moving. I have not had any issues with this except one minor item. A long straight section of track bed (1 meter) typically requires 1-2 cuts to allow all the K track cross sections to fit in the track bed. Seems the geometry is off by a really small amount. This could be I left the track bed lay around for a while and it 'swelled up' or 'shrank' by a millimeter. Very minor in my mind. I felt the Merkur product was easier to work with versus building my own bed (which could be messy)
Harvey
#3 Posted : 15 March 2021 20:00:01(UTC)
Merkur track bet is totally worth it.
Harvey,
Different K-tracks have slightly different spacing in the ties (sleepers)
When you insert flex track into long strips of Merkur roadbed, you sometimes have to 'gather' the ties closer together, just push them along the rails.
#4 Posted : 15 March 2021 20:06:27(UTC)
What I know is Merkur started those track bed very long time ago: I used them on my N gauge Arnold layout in 1978.
So obviously they have a lot of experience.
What does it bring?
* the key difference is you only glue the track bed and not the track (flex and track pieces) which are inserted into place without gluing
* no corrosion of (K) track contacts because of the glue
* no vertical bending of the track resulting in a much better laid track
* much better noise absorption because an elastic link (foam) between the track and the layout structure
* much better functioning of junctions because of no loose ballast
* much better reuse of track afterwards (It is brand new after extraction)
* very professional finish without much work
The down sides are:
* price
* increase height of track
* not practically usable for lower levels of layout
Now using Märklin C Track I don't need much ballasting.
I have used some K flexible track but with Faller cork bed and C Track ballast from Noch. Big pain in the neck and poor result compared to Merkur ballast
Offline PeFu
#5 Posted : 15 March 2021 20:12:53(UTC)
PeFu
I learned to add the track bed to the flex track, before bending the flex track and before laying the track bed on the layout. With this method, I never needed to cut the track bed as you describe.
#6 Posted : 15 March 2021 20:52:25(UTC)
the other thing to note is that most (all?) professional layouts that use Märklin, use K-track and Merkur. I have even noticed the Märklin catalog showing how to insert K-track onto Merkur roadbed.
Offline scraigen
#7 Posted : 15 March 2021 22:49:26(UTC)
scraigen
Totally worth it, speaking from experience so much easier than ballasting the entire layout, which I find very tedious.
Must build something
Online mvd71
#8 Posted : 16 March 2021 00:02:03(UTC)
I have used Merkur for a number of years and found it to be a very good product for all reasons mentioned above. In terms of cost I think it is not that expensive if you consider that without it a modeller would have to buy underlay for sound absorption, glue and ballast in much larger quantities. When this is taken into account the Merkur looks good as you get a professional finish without pay much more per metre.
#9 Posted : 16 March 2021 00:13:20(UTC)
Not totally true. The layouts they take around the various IMA shows use C track these days.
[edit]
Whoops, I thought you were talking about layouts made by Marklin themselves. But the comment still stands, that there are significant numbers of layouts produced by commercial layout manufacturers that use C track.
[/edit]
#10 Posted : 16 March 2021 02:18:23(UTC)
yea thats why I said 'most'....
Märklin of course has to use C-Track, and it would look bad if they had to rely on a 3rd party product to make their K track look decent :-)
#11 Posted : 16 March 2021 02:28:12(UTC)
Puttputtmaru
This is really a good endorsement by all for the Merkur., I will have to give it a try for sure.
Now to find a dealer in Canada or make a large order to make it worth while ordering from Germany I guess.
#12 Posted : 16 March 2021 03:21:12(UTC)
You may have to order direct from Merkur in Germany. Its not difficult it just takes some weeks to get across the pond. (And would be no different for a dealer.)
https://www.merkur-styroplast.de/
Offline Harvey
#13 Posted: : 16 March 2021 03:46:13(UTC)
Harvey
No one carries their product in the US. Likely the same in Canada. Delivery in the US is slowed significantly due to the USPS issues (5 months for my last order). My first order pre-Covid, pre-USPS issues) was 5-6 weeks. If the number of flights increase significantly, DHL may switch back to air freight.
Harvey
Offline PeFu
#14 Posted : 16 March 2021 06:54:08(UTC)
PeFu
It’s made from a plastic foam material, not cork. This makes the Merkur track bed less noisy and more flexible.
Yes, the track bed has indent for the sleepers. We - ”The Merkur Fans” - haven’t mentioned how good these indents are for the specific turnout track bed parts. No more ballast glue in sensitive areas causing jerking turnouts.
When it comes to sleeper distance: If you are strict using flex track bed for flex track, and the other track bed parts dedicated for each standard track (including turnouts), in my experience they all fit well. My recommendation is therefore to design the layout carefully in a PC program before ordering the track bed from Merkur.
The flex track bed is 100 cm and the 2205 flex track is 90 cm. I cut approx. 10 cm from the track bed, draw the soldered track cables through the track bed, add the track bed to the flex track, and then lay the whole ”package” on the layout. I found this as a best practice for myself. This makes it easier to manage fine tuning of rail cutting at track joins. You may have use for the 10 cm leftovers in other areas of the layout. Any track bed joins will disappear usin the loose ballast they offer.
#15 Posted : 16 March 2021 07:12:40(UTC)
Hello PPM,
I am a big fan of K track in Merkur.
Some of my previous posts explain why :
See post # 13 at https://www.marklin-user...rack-problems#post515769
also : https://www.marklin-user...erkur-roadbed#post502091
post #6 at https://www.marklin-user...ls-and-Hedges#post468476
and even :
https://www.marklin-user...rklin-K-track#post516522
and https://www.marklin-user...rklin-K-track#post516517
PJ
Edited by user 25 October 2021 08:13:59(UTC)  | Reason: eliminate redundant link
#16 Posted : 16 March 2021 07:43:23(UTC)
I have used it on my 2nd and 3rd layout (I am currently on my 4th and "final" layout).
I was pretty happy with it when I used it; Nice looking with little effort.
I stopped using it, because it seemed too expensive, and I had trouble sourcing it for a long time. (However, it now seems to be "back in business")
It gives a very uniform looking layout. Maybe even too uniform. However, everything you can do to your OWN ballasting, you can do to the Merkur too, so that shouldnt really be a detracting point.
If I had lots of money and good access to it, I would probably use it, if starting a new layout.
Especially MiWuLa and Brima seems to use Merkur everywhere.
Offline Roland
#17 Posted : 16 March 2021 17:30:44(UTC)
Roland
EuroRailHobbies in BC might have some Merkur left in stock but you'll likely have to order from Germany. I ordered direct (as Dale suggested) a couple of years ago.
Märklin H0 for sale
My Layout Build | Märklin CS3+ | K-track | Merkur | Viessmann | LDT | iTrain | Rolling Stock: Märklin, Roco, Piko, ESU/Pullman | Modeling primarily DB/DB AG EpIV-VI
#18 Posted : 16 March 2021 17:55:21(UTC)
No, I checked already. They don't carry it anymore.
#19 Posted : 16 March 2021 18:02:06(UTC)
The key features that make it worth the expense from my view, when using K-track are:
1) The foam used I think has a proven long time stability (doesn't break down into soft gunk like other soft foam bedding)
2) Consistent full bedding optics from straight track through turnouts vs the 'un-ballasted open spaces' typical of using ballasting in K-track.
#20 Posted : 16 March 2021 18:32:53(UTC)
Puttputtmaru
You got me convinced guys.
Still in the planning stage for my layout but Merkur, instead of cork or Woodland track-bed, is in the cards.
Unpacking old boxes of my last layout and rediscovering past memories.
thanks 3 users liked this useful post by Puttputtmaru
Offline jlopez
#21 Posted : 19 March 2021 06:27:27(UTC)
jlopez
I’ve been using merkur with my module l building for the module group. You don’t need to glue it down just use the k track screws and screw the track down. You can always unscrew it and adjust if necessary.
#22 Posted : 19 March 2021 07:23:38(UTC)
Does that not defeat one of the benefits of the foam track bed by creating a rigid connection to the baseboards and thus transmitting vibrations more directly?
Online mvd71
#23 Posted : 19 March 2021 08:13:48(UTC)
Yes, it does to a degree. Although in that scenario the Merkur will still dampen the sound. Better to glue the Merkur and have the track free
#24 Posted : 19 March 2021 09:19:08(UTC)
[edit]
Whoops, I thought you were talking about layouts made by Marklin themselves. [/edit]
The new Marklin Museum layout is K track and there's an awful lot of it that layout. Take a look at some of the pictures in the New York Times article about Marklin, there's a few of this layout.
https://www.nytimes.com/...del-trains-pandemic.html
#25 Posted : 19 March 2021 11:21:10(UTC)
Hum... Actually... It looks like C-track to me!
Definitely the first part, with the camera-lok, is C-track!!!
On another overview you see some kind of "sweeping" lines, but not QUITE the same sweep as you see with K-track. They might have mixed with K, and/or tweaked stock C-track.
#26 Posted : 19 March 2021 11:50:26(UTC)
That's definitely K track, although the roadbed has been painted and partially ballasted in this picture I took in 2019.
#27 Posted : 19 March 2021 22:45:52(UTC)
This is the area where the video was taken (red circle) and you can see that area wasn't developed when I viewed the layout in 2019. It may well have been done with C track, as Henrik points out it certainly looks like C track in the video.
Offline BenP
#28 Posted : 27 April 2023 13:49:08(UTC)
BenP
I started with Merkur roadbed for K track, but notice that it pushes rail connections just a little apart. There is no lock mechanism in K track connections, so how can i best shave a mm from Merkur styroplast to improve track connects? The roadbed otherwise fits great and looks wonderful.
Ben van der Pluijm--
#29 Posted : 27 April 2023 14:21:58(UTC)
Hi Ben
I used Merkur roadbed for a N scale layout and had just great results:
- very nice look
- sound dampening
- keeps track together
- track remains removable without interference with the landscape
In your case, the track bed being elastic, if you pull (even slightly) on it, it may change the distance between track pieces.
Online mvd71
#30 Posted : 27 April 2023 15:23:21(UTC)
The roadbed can easily be cut with a modelling knife to shave a little off to get perfect joints.
Offline BenP
#31 Posted : 27 April 2023 19:22:13(UTC)
BenP
I experimented with trimming and found spinning stationary wheel handy for tiny corrections.
I also realized that placing track joins in middle of merkur roadbed sections keeps rails nicely together. I just needed to cut one piece in half to create a circle segment with tight rail fit. And no need to screw track down.
This is sturdy, dampens sound and looks great.
(btw, 3370 ice set is for sale)
thanks 2 users liked this useful post by BenP
Online GlennM
#32 Posted : 21 September 2025 09:50:20(UTC)
GlennM
So I went to the Merkur site today to buy some track bedding and it seems the owner has retired and the business has been sold to HG´s Modellbahnambulanz – Reparatur und Digitalumbauten von Modelleisenbahn but their site has no products for sale.
I assume there is a hand-over period but there is no information when products may be available again.
Does anyone know?
Also does anyone sell stocks of the product as I was hoping acquire some urgently.
Offline Roland
#33 Posted : 21 September 2025 17:54:08(UTC)
Roland
Does anyone know?
Hi Glenn,
I have a decent amount of brand new Merkur stock on hand. 80-90% of my track is laid so I could probably start to part with what I definitely won't need. Send me a PM with what pieces you're looking for.
Roland
Märklin H0 for sale
thanks 1 user liked this useful post by Roland
Online GlennM
#34 Posted : 23 September 2025 06:33:07(UTC)
GlennM
Does anyone know?
Hi Glenn,
Roland
Roland,
I am currently looking for straight pieces;
1) The deal track 64.6mm wide
2) Single straight pieces 1 m long or roll
3) Distance strip 10 cms wide 1 meter long
4) Embankment strip 50 cms long
5) Superelevation strips
Thanks for any help you can offer
Best Regards
Guest (7)
Merkur track bed glue question (General MRR)
by Puttputtmaru 04/02/2022 23:22:36(UTC)
This page was generated in 1.160 seconds.
