Offline Borsig-Werke
#1 Posted : 01 December 2020 17:42:38(UTC)
Borsig-Werke
I would like to know what is needed to upgrade/convert this delta digital railcar to digital? I would like to have better motor and decoder. Is märklin decoder kit 60760 suitable? is there better alternatives? Never done this so therefore pls. do not assume I know anythingBlushing
Pics from railcar current motor and decoder, what type of motor is that?:
Offline Martti Mäntylä
#2 Posted : 01 December 2020 22:17:47(UTC)
Martti Mäntylä
This looks like the LFCM = Large Flat Commutator Motor. For this motor, the upgrade kit Märklin 60944 Hochleistungsmotor should be OK. As to choosing to decoder, other members probably have better knowledge. I would try Märklin 60983 LokDecoder mLD3.
Märklin 60760 is only for DCM = Drum Commutator Motors.
- Martti M.
Offline bph
#3 Posted : 01 December 2020 23:39:59(UTC)
this site, list the class 515 having an SFCM motor, and for an SFCM a 60943 kit would be required. (plus a decoder eg 60972 or 60983.)
https://wiki.3rail.nl/index.php/Sjabloon:Märklin-br515-modellen
this thread might give you some more information (use google translate if needed)
https://stummiforum.de/viewtopic.php?t=132243
Online xxup
#4 Posted : 02 December 2020 01:31:55(UTC)
I have this little railcar and confirm that it was a SCFM.. A 5 pole motor helps it to run great, but make sure that all the running gear moves freely before installing the new motor bits.
I also did some work installing LEDs instead of the power hungry bulbs.. In terms of reducing the power consumption, it worked great, but that center bulb needs work.. In hindsight, I should have used an LED set from a passenger wagon instead of simply replacing the bulb..
#5 Posted : 02 December 2020 09:47:58(UTC)
Borsig-Werke
^^ Thanks a lot for very useful links. 60943 it will be then.
^Adrian: could you explain your led installation a bit more? What kind of LED's did you use? and did you connect those to decoder + and - or somewhere else and how big resistor?
Online xxup
#6 Posted : 02 December 2020 10:34:47(UTC)
I used John's 3028 conversion topic as the basis for converting my 3429..
Have a read of this:
https://www.marklin-user...ersion-3028--3428-Br-515
Where John used surfaced mounted LEDs, I used 2mm white/red LEDs that I bought from China, but the whole approach is similar...
#7 Posted : 02 December 2020 15:47:51(UTC)
Borsig-Werke
If I would like to include sounds would 60987 märklin decoder be enough with 60943 motor upgrade set? Or do I still need additionally 60972 or 60983?
This page was generated in 0.504 seconds.
