I've got a basic event operating so that a train entering a station switches on the station lights, plays the cs3 default wav file and 4 seconds later the lights go off. I'd like the train to stop for a period of time, but I haven't figured out how yet!
Ive picked up more wav files from the Märklin web site but I don't know how to transfer them from my computer to the CS3. It also appears that the SD I've just placed in th CS3 is to help expand its memory, so how can I get more sound effects installed and played by the CS3?
Thanks for any help :-)
Joined: 05/09/2014(UTC) Posts: 686 Location: NEW HAMPSHIRE, Somersworth
You need to do a better job describing exactly what you have done. What is the CS3 default wav. file? Are you referring to a sound from the loco? How are you getting the train to stop in the station? Did you "record" an event or construct it? If you created an event you should be able to add one which just hold things for a period of time. Or you can simply add a delay before the train leaves the station. Unfortunately, right now Marklin considers the event feature not suitable for regular hobbyists and they have not bothered to provide explanations of all the features available so you have to just experiment with it In America we have two factory reps who are very good at helping explain the features but I am not sure if you also have anyone available in England.
Joined: 27/02/2008(UTC) Posts: 297 Location: Santiago
Hi, Here is a link to the Marklin database that shows how to upload any wav files into the CS3. You will need to use a memory stick. The instruction are in German but you can use google translate if you don´t read german. You can store the wav files in the stick or into the internal memory of the CS3. https://www.maerklin.de/fileadmi...1_Sounds_Hinzufuegen.pdfRegarding the timing delay, it is possible adding some time at the moment of arrive of the locomotive to the point of stop. In the below link from Soren Jakob from Denmark you can review the process. You just need to add time to the specific event. https://railway.zone/pos...station-3-2-rail-version I hope that you can now increase the fun of the event with these instructions. Kr, Eduardo
Hi eduard71
you've been very helpful. I'll have a go at this again tomorrow.
Many thanks
Joined: 23/07/2014(UTC) Posts: 8,508 Location: ENGLAND, Didcot
Originally Posted by: rhfil  You need to do a better job describing exactly what you have done.
He has provided a pretty good description of what he has done, and what he wants to do. Originally Posted by: rhfil  What is the CS3 default wav. file? Are you referring to a sound from the loco?
default.wav is a sound file provided with the CS3 software release. He is not referring to a loco sound file. The CS3 has the facility to play a sound when an event happens. This sound is played through speakers that you attach to the cs3 by using the speaker connector on the back panel. A quick check of the cs3 manual will show this. What the OP is wanting to do is load some other sound files onto the cs3 to use instead of the default one supplied.
 2 users liked this useful post by kiwiAlan
Joined: 12/12/2005(UTC) Posts: 2,448 Location: Wellington, New_Zealand
Originally Posted by: kiwiAlan  This sound is played through speakers that you attach to the cs3 by using the speaker connector on the back panel AND / OR the internal speaker |
The "trick" (if you can call it that) is that the files on the SD-Card need to be in the \CS3\wav subdirectory |
 1 user liked this useful post by clapcott
Originally Posted by: clapcott  The "trick" (if you can call it that) is that the files on the SD-Card need to be in the \CS3\wav subdirectory Done that but, although I can hear the default p VI Gong Abfahrt.wav the others in the USB 0>>wav>>Soundbibliothek>>mBibliothek>>Multitext>>Multihanhofsansage etc etc The 01.wav etc don't make a sound when I try to play them inside the CS3. If I drop them into iTunes & VLC again no sound. I've looked at the file info and they appear as waveform audio with various kb files sizes very puzzling btw what's the eigeneBibliothek fold used for? Also this may be the problem on the downloads page Märklin it tagged Files and sounds for mLD3/mSD3 Decoder - does that mean I can't use them with the CS£ directly and what are these decoders? Can they be converted to be used with the cs3?
Most of the (snipets) in the sound library are just components for a bigger assembly - e.g. starting, stopping and running at different speeds.
Not all .wav files are created equal. If the sound does not play on a PC then do not expect it to play the CS3.
Originally Posted by: oranda  Originally Posted by: clapcott  The "trick" (if you can call it that) is that the files on the SD-Card need to be in the \CS3\wav subdirectory Done that but, although I can hear the default p VI Gong Abfahrt.wav the others in the USB 0>>wav>>Soundbibliothek>>mBibliothek>>Multitext>>Multihanhofsansage etc etc The 01.wav etc don't make a sound when I try to play them inside the CS3. If I drop them into iTunes & VLC again no sound. I've looked at the file info and they appear as waveform audio with various kb files sizes very puzzling btw what's the eigeneBibliothek fold used for? Also this may be the problem on the downloads page Märklin it tagged Files and sounds for mLD3/mSD3 Decoder - does that mean I can't use them with the CS£ directly and what are these decoders? Can they be converted to be used with the cs3? Sound files supplied as part of that download are only for use in decoders. I would suspect they are encrypted like the Loksound ones are.
Joined: 03/10/2010(UTC) Posts: 1,299 Location: Cape Town, South Africa
I believe that the 'eigenBibliothek' folder is the folder where you place your own sound files which you want to play. The folder gets created when you download the Marklin Sound Files. Regards John
