Online mvd71
#1 Posted : 06 May 2020 21:58:54(UTC)
Has anyone tried using the Märklin decoder tool/software with an iPad?
Is this a realistic possibility to give a portable programming unit without the slowness of working through a Central Station?
Thoughts/experiences appreciated.
Cheers....
#2 Posted : 06 May 2020 22:26:40(UTC)
Hi Mike
You got me confused. There are 2 Märklin products:
- the mDecoderTool3 (freeware from Maerklin.de) to be connected to a PC to download, edit and prepare the memory files to be programmed though a CS2 or CS3 or directly to the Decoder / Programmer
- the Decoder/Programmer (60971) a USB device with a connector for various types of Märklin decoders. It needs a PC and is much faster than using a CS2 or CS3.
I may be wrong but I believe there is nothing for iPads.
Speed difference is 40 minutes for CS2/CS4 programming and only 5 minutes with the Decoder / Programmer
Edited by user 07 May 2020 11:57:31(UTC)  | Reason: Not specified
Online mvd71
#3 Posted : 07 May 2020 09:49:48(UTC)
Hi Jean,
Thanks, you have answered my question. I have the 60971 for the PC and was wondering if I could utilise it with the iPad purely for convenience. But I understand now that that is not the case.
Thanks again,
Cheers...
#4 Posted : 07 May 2020 11:20:46(UTC)
The software is Windows only. If you want to run it on a tablet you would need a Surface Pro!
Online dickinsonj
#5 Posted : 11 May 2020 18:19:14(UTC)
Davis correct (as usual ThumpUp ) and I have a different question.
How would you attach the USB stick to an iPad since Apple has never provided any of their tablets with a USB interface?
This page was generated in 0.289 seconds.
