Offline jmallen622
#1 Posted : 02 December 2019 17:54:51(UTC)
jmallen622
I have the 29186 Starter set and part of it is the 604017 decoder. What is this used for in addition to supplying power to the track?
Thank You
#2 Posted : 02 December 2019 18:53:11(UTC)
For Marklin this is a 120V Delta set with a transformer
The other reference you give is not recognized by Marklin
Is this the loco decoder ?
If yes and if the warranty is finished then install a mld decoder
#3 Posted : 02 December 2019 20:11:33(UTC)
Thank You
I think we need a photo so we know what you have.
Offline bph
#4 Posted : 02 December 2019 20:31:29(UTC)
Most likely its a radio noice filter for analog operation.
#5 Posted : 03 December 2019 05:24:40(UTC)
As always, Mr Google is your friend and this (BPH's answer) is what he says....
Offline jmallen622
#6 Posted : 03 December 2019 15:56:34(UTC)
jmallen622
MARKLIN-Funk-Entstordecoder-604017-V15-04-99-ATE-mit-Flachstecker.jpg Here's what I have. I don't read German Thanks
#7 Posted : 03 December 2019 17:20:17(UTC)
Ah, that is only for connecting a transformer to C track. When running a digital system you don't want that in the circuit. The wires from the digital controller connect straight to the track, not through that PCB.
This page was generated in 0.486 seconds.
