Offline nasargy
#1 Posted : 10 May 2019 08:58:24(UTC)
nasargy
Hello everybody,
I have an issue and would like some help if it is possible.
I 've started retrofitting a Marklin diesel loco Class 218 (No 29476), initially equipped with FX decoder, by using the No 60976 Marklin sound decoder (mSD/3).
I have unsolder the wires from the old decoder and resolder the wires to the new decoder 60976, as per instructions of the decoder's manual.
Without change anything in CV values, the sound it is ok , I'm hearing the sounds fine (I have used the bigger loudspeaker of the 60976 set), the lights working ok (they are lighting accordingly to the chosen direction).
But there is no motion !!! At all!!! Neither to one direction nor to the other direction. Not even the smallest movement!!!
Can somebody help me , advise me , or anything?
It is important to say that before start retrofitting , I've tested the loco and was running adequately both directions.
Experience is like a comb. You get it when you are already bald
#2 Posted : 10 May 2019 11:37:59(UTC)
The number one cause of the above symptoms after a conversion is forgetting to put the brushes back in the motor. It might seem obvious but it's had me stumped more than once!
Offline nasargy
#3 Posted : 10 May 2019 13:58:54(UTC)
nasargy
Please explain. I hadn't touched at all the motor. The only thing I have done I've soldered the green and blue wires to the resistors. Nothing else.
Offline ktsolias
#4 Posted : 10 May 2019 14:41:40(UTC)
ktsolias
Post a good photo of how the loco is now
From the photo that you have post so far I can see a mess, and a nice opportunity to fry a decoder
Conversions with modern decoders are quite complicated things and require knowledge of the motors the decoders etc
Costas
#5 Posted : 10 May 2019 20:58:16(UTC)
OK, so if you didn't remove the brushes my theory goes out the window! Sorry to have confused you even further!
By the way the "resistors" are actually chokes, or inductors, and they are there to stop high frequency pulses generated by sparks from the motor from frying the decoder. They also function as RF interference suppressors.
Double check all the wiring and maybe resolder the leads to the motor.
Offline tiono
#6 Posted : 11 May 2019 03:43:37(UTC)
tiono
From the photo; the motor is connected to the decoder at the left side, which is not connected to any power cable. (The power cable seems to feed to the other decoder). Without power into the decoder, surely the motor will not turn.
#7 Posted : 11 May 2019 10:07:48(UTC)
On the photo there is the old PCB with the fx decoder and a new PCB without any decoder at all.
The simple conversion would have been to keep the old PCB, replace the decoder, and solder two speaker wires to the old PCB. Been there, done that, easy.
On the photo there really is a mess, as stated before. Two PCBs, but only one decoder. And it is unclear how connections are in detail.
Online dickinsonj
#8 Posted : 13 May 2019 03:49:35(UTC)
I have had the same thing happen to me - and like Ray, more than once!
Offline nasargy
#9 Posted : 13 May 2019 10:28:00(UTC)
nasargy
Hello everybody
Many thanks for your messages.
The problem was the no conductivity to the green motor cable, after a bad wire soldering.
The issue has been solved and now the loco works fine.
The photo is from a pre-mature step, while I was trying how to arrange cables and decoder.
During all trials to operate the loco I have been using the appropriate PCB and its decoder. At this time, I had the issue described above, due to the bad wire soldering .
The photo below shows a more recent image of the locomotive condition.
I have admit that I must improve the settle of the wires.
Thanks again for your help and comments.
thanks 4 users liked this useful post by nasargy
This page was generated in 0.864 seconds.
