Offline Michael@parsche.net
#1 Posted : 15 September 2018 14:05:47(UTC)
Michael@parsche.net
I can not connect directly to my CS3+. I can an error: Web server fehler
#2 Posted : 15 September 2018 15:38:09(UTC)
Have you tried with an router?
#3 Posted : 15 September 2018 15:56:51(UTC)
Michael@parsche.net
I am trying to login from a web browser. I am entering the IP address and I get the error "Märklin CS3 Webserver Fehler"
#4 Posted : 15 September 2018 16:40:27(UTC)
Looks like you have problem with the web server at your home by web operator.
Before i did download my CS3 i did cleaned caches and cookies in my computer.
Did you add DHCP?
Offline JJCS
#5 Posted : 03 December 2018 19:13:02(UTC)
JJCS
I have the same problem "Märklin CS3 Webserver Fehler" after update the CS3+ with the latest available SW.
Central Station 3 60216
Hardwareversion HW:03.03
Softwareversion 1.3.3(1)
Seriennummer xxx
(GPL) GNU/Linux 4.5.0 armv7l
(GPL) U-Boot 2015.01
The CS3+ are connected trough a router and I tried with DHCP and also with a fixed IP.
CS3+ are reachable with ping command from any computer.
The message appears in IE and also in EDGE browser and cannot reach the CS3+ with VNC.
Everything works fine except the Web Server.
Anyone knows how to start the web server manually?
José Cadalso
Offline MaerklinLife
#6 Posted : 03 December 2018 20:19:32(UTC)
MaerklinLife
Did you add DHCP?
Honestly, Goofy: What a load of rubbish. You don't make any sense. Ask yourself: If the web browser can spell "Märklin CS3 Webserver Fehler" how can that be a problem with the operator? I take it you mean ISP. Clearly, a connection to the CS3 has been made, sadly, an unsuccesful one. But the network connection is fine, so no need to debug DHCP or anything network related.
The message "Märklin CS3 Webserver Fehler" means that the CS3 is alive, but the built-in webserver has not started. There is no problems with the network connection to the CS3, the error message gives it away: "Märklin CS3 Webserver Fehler". There is no way a browser or computer can create such an error message without having some form of connection to the CS3. The problem is with the CS3.
I have seen this before, I guess the update corrupted some files. Unfortunately, I have not seen any solution, and I do not think it is possible to start the webserver manually, because that would require access to the CS3 that we as customers do not have.
Unless someone in here knows a way, I'm afraid that the CS3 needs to go back to Märklin for a complete re-install of the software. That's what I would do.
But before that: Did you let the CS3 sit for a while? I mean, like a couple of minutes or so. The webserver need a few minutes to come online, so if you try to access it right after a system start, you will receive the same error message. After a few minutes it will go away, because the webserver is ready.
thanks 1 user liked this useful post by MaerklinLife
#7 Posted : 03 December 2018 20:48:24(UTC)
Or... try an update via Internet once more...
Also some reading... https://www.maerklin.de/...ate_1_3_3_info-04_en.pdf
Offline JJCS
#8 Posted : 03 December 2018 22:03:49(UTC)
JJCS
Juhan is right: Nothing to do with "ISP", router or home network.
The problem lies on the CS3+
I was reading the Update Information CS3 version 1.3.3 and I noticed that they say "Important: The IP address assignment in the CS3 should be set at 'auto' ".
I'll try again, asap, with DHCP and use the IP assignment by the router on the browser, or/and using the Dynamic Name (CS3-xxxxx-.local).
I do not like using DHCP in my network, I prefer fixed IP, but if it is the only solution for now I'll try, waiting a little longer for the Server come up...
Has all the appearance of being a bug, because before the update the web server functioned normally (accessing CS3 through browser immediately after a system start).
#9 Posted : 03 December 2018 22:58:35(UTC)
I too did had some problem to start CS3 with the IP adress at DHCP.
I tried set manually and it did not worked.
Finally CS3 did react and accept network.
#10 Posted : 03 December 2018 23:01:06(UTC)
Did you add DHCP?
There was no message in my CS3 with "Märklin Webserver Fehler".
Offline JJCS
#11 Posted : 04 December 2018 10:29:45(UTC)
JJCS
Good morning,
Trying to solve the problem again:
- System configured to DHCP, waiting 5...10...20 min, same problem, webserver down.
- From Marklin site, downloaded the update file "cs3update_v1.33.btrfs", 297MB, copied to a USB stick, inserted in CS3, waiting for reaction, nothing happened.
Searching the forum, following instructions from "skukuza", https://www.marklin-user...new-update-V-1-3-3/page2
- Hold down the stop button and one of the throttle buttons at the same time while connected to the internet and it will automatically do an update.
CS3 rebooted, started a direct update from Marklin site, showing steps on screen, rebooted, and:
- Both EDGE and IE browsers, start to work again.
- Changed from DHCP to FIXED IP, and everything works.
Now I can access CS3+ from the BROWSER (!) and/or from VNC VIEWER
Thank you for the tips.
José cadalso
thanks 3 users liked this useful post by JJCS
Offline edominguez
#12 Posted : 02 February 2020 14:11:22(UTC)
edominguez
I followed your steps and I was able to resolve the problem.
Thank you for posting it.
Ed
Originally Posted by: JJCS Go to Quoted Post
Good morning,
José
Edited by moderator 02 February 2020 18:35:40(UTC)  | Reason: Quote tag error
Offline Bones
#13 Posted : 03 April 2020 15:27:12(UTC)
Bones
In reply to the question
In had some trouble getting my CS3 to work with my computer until I realised that at the very end of the IP address you will have something like this
XXX:XXX that :XXX bit is the port number for your router and it's different with each ISP provider and you need to find that Port number
In my case since I am with LPG and the port number was 80
#14 Posted : 03 April 2020 15:59:53(UTC)
IP addresses do not have ports. Port 80 is the default for HTTP, thus you can skip adding ":80" if the URL starts with "http://".
Routers route everything and the port of the server does not depend on the router or provider used.
The error message "Web Server Fehler" indicates that IP address and port are set correctly for the web server, but the web server is not working correctly.
This page was generated in 0.441 seconds.
