Offline Bahner
#1 Posted : 02 March 2018 06:32:10(UTC)
Bahner
New to Z scale and I'm hoping this one has an easy answer (that just escapes me at this point).
While I am waiting patiently for some Marklin Z Flex track to finally show up, I decided to play around with the track pieces that I do have to get a feel for things. I set up a single track 'dog-bone' with a passing track and a dead-end siding. What I noticed is that when I park a train on the dead-end siding and then set the turnout back to main line traffic, both this train on the siding and a second train on the main line move together when the power is cranked up.
The switch setting has no effect in so far as cutting power to the train on the dead-end siding. My N scale Minitrix turnouts kill the power on a dead-end siding once the switch is set back to main line so the train on the siding can't move (switch points can't be split open by a train if they are set against it). How is this handled in the Marklin system?
Thanks in advance,
Ralph.
Offline Carim
#2 Posted : 02 March 2018 16:58:03(UTC)
Carim
Hi Ralph,
You will have to isolate the siding. I did this by cutting a gap in one rail on the siding, then bridging this with an On/Off switch.
Carim
Offline Bahner
#3 Posted: : 02 March 2018 17:05:25(UTC)
Bahner
Hi Ralph,
Carim
Hi Carim,
Thanks for the info. Looks like all the Marklin Z switches work this way, then.
I must admit that I am surprised by this, but as they say "It is what it is".
Offline Carim
#4 Posted : 02 March 2018 17:15:11(UTC)
Carim
Well I think Rokuhan switches/points also allow you to do this. I think it has the advantage that you don't have to depend on the actual switch blade transmitting power to either the mailine or the spur.
Carim
Offline Bahner
#5 Posted : 02 March 2018 20:37:53(UTC)
Bahner
Carim
Makes sense. Since the switchblades are so small, I can see where a small speck of something could prevent contact with the rail when the switch is thrown.
Offline Bill Dickson
#6 Posted : 12 March 2018 10:34:13(UTC)
Bill Dickson
You need to be careful with Rokuhan switches because the two blades are the same piece of metal so you cannot trail a loco through them! an advantage (apart from the looks) is that, by fitting or removing the screws supplied, you can convert them from isolating (i.e. one branch not having power transmitted to it through the switchblade rail) to all live as with the Marklin version.
This page was generated in 0.249 seconds.
