Offline Dennis H.
#1 Posted : 20 January 2018 21:33:14(UTC)
Dennis H.
I've had older Marklin ho for quite some time but just recently bought a few Marklin 0 items. That just started rolling downhill very fast when I made a lucky bid and won the HR66 12920 loco and cars. It was not cheap by any means, but it went for less than I thought it might, maybe because it was on ebay over here in the US?? not sure if that had an effect or not. It will need some parts, small loco wheels, trailing truck etc and it will need to be cleaned up a bit. I don't plan on restoring or repainting it, just cleaning waxing polishing and protecting and getting it to run well. I am aware of Ritter for many parts like the wheels so I think that will be ok as well. One thing I am a little curious on is narrowing down the year(s) this was made. I know it was shown in some prewar catalogs and I understand 0 was made postwar as well including these cars and loco I think. I found some comments on line which claimed that prewar 40cm cars had yellow lettering on the black frames of the cars while postwar did not. Does anyone know if that is correct or if it is a good detector of pre versus postwar production? Also, although I have seen a few scans of various prewar catalog pages I have not seen one with this complete train yet and so I am curious to know if the consist matches a cataloged set consist and if so maybe which one? I suspect this set started out all together as it is coming from a part of the US that you would not expect a top line prewar Marklin set to end up. It probably came back with a service man or something like that. Anyway, here is one picture from the auction, I'll post some more in a bit and some better ones once it arrives and I get my grubby little hands on it.
Dennis H.
If it's old and broken, I like it
thanks 7 users liked this useful post by Dennis H.
Offline CCS800KrokHunter3
#2 Posted : 21 January 2018 00:12:12(UTC)
CCS800KrokHunter3
Congratulations - I bid on this set too, I think you got a good price. I would have bid more but I just bought a similar set.
Although Ritter does seem to make quality parts I haven't had any luck in purchasing from them ever.
The yellow letter is true, those were made in the pre-war years. Yours was likely produced partially in 1938/39 and then some of the cars were possibly made in 1944/45 when production began again.
Best wishes,
Paul
Edited by user 25 January 2018 23:43:54(UTC)  | Reason: Removed recommendation of a parts supplier that I was ultimately unsuccessful ordering from
thanks 2 users liked this useful post by CCS800KrokHunter3
#3 Posted : 21 January 2018 01:30:12(UTC)
Hi there, Dennis, great score.
The numbering system for that era is quite a mystery, Paul knows it better than me and I think may have an article on decoding the numbers, I know for certain the last digit refers to the gauge, I believe the 4 before that are the Loco model, and the prefix "HR66" relates to technical features, motor type, reverse unit etc - clarify Paul ??
The first catalogue reference I have with the HR66/12920 is in the 1933 catalogue, but is not in the 1931 edition. If there was an issue in 1932 I don't have it but I think you can safely take 1932/1933 as the first years/s of production.
The coaches however do not appear in the 1933 catalogue, in that style.
Here's a couple of catalogue images of the loco (sources acknowledged) :-)
Note here the price of this item, 75.00 (Marks). That was right up there, and for comparison, the cheapest electric 0-gauge loco that same year (R12880) was 9.50 Marks.
Have to go help daughter strip the interior of her slightly crashed car for repair now but if I get time later I'll try to find some Coach images. I could not yet find a start set with THAT Loco, but in 1936 appears set HR744 which appears to have the same or very similar coach consist but with the HR700 Loco.
Someone else may jump in sooner with more info and images now that the date is narrowed down to the early-mid 1930's.
I suggest it's 'likely' all came together originally, but not certain.
Hope this helps.
Steve
#4 Posted : 21 January 2018 03:23:54(UTC)
CCS800KrokHunter3
I knew I could count on you for the catalog scans, Steve, thanks for sharing! You're right on about all the O Gauge info. I did a quick overview of O Gauge here, it needs more depth but covers some of the high-level info:
https://marklinstop.com/...-o-gauge-intro-overview/
Also of note is this similar set on eBay-US - note there are no yellow inscriptions.
https://rover.ebay.com/r...2%3Ag%3A0NIAAOSwwcRaUVIA
I agree that there was no specific set but Marklin many times created bundles during the War time that were perhaps packaged together. That is why when you see an HR 66 12920 or HR 70 12920 you almost always find a 1941, 1942 J, 1943, and 1944. I would say that's the basic set, then those with a little more to spend added the interiors, which were denoted by a "G" appended to the model number. The set that I purchased has two 1944 cars (one with a whistle inside), two 1943 cars, and a 1945 car. The HR loco and the 40cm cars certainly do go together perfectly. The shorter 174X cars a better suited for the E 66 or GR 66 locos...
By the way, I just purchased some Atlas O-54 6060 track which I highly recommend...it's not Marklin but certainly much easier to find! From your avatar it looks like you might collect Lionel or some other brands so I'm sure you're more familiar with non-Marklin track, etc. I'm still trying to hunt down a good transformer...
Best,
Paul
Offline Pmare4
#5 Posted : 21 January 2018 04:09:10(UTC)
Pmare4
You have been a member since:: 15/10/2015(UTC)
Hi Cookee,
What you've said there is correct to my understanding, but the HR66/12920 was produced until October 1954. One of the easiest ways to date the HR is the lettering on the rear of the tender, pre-36 tenders just have "Germany," but 1936 and later tenders have "Made in Germany." Locos made after 1950 have the Marklin Bicycle logo instead of the lettering Made in Germany. Post 1938 locos have unpainted buffers on the tender rear.
H was the loco designation used by Marklin in the 1930s for all 4-6-2 Steam Locos, for example, the H4021 LNER was a model of the Flying Scotsman, but the H4021 PLM was a model of a French 4-6-2. I would assume the R meant the locomotive was in the style of the Reichsbahn.
The 66 after that indicates the type of reversing unit fitted, 64/ and 70/ reversing units are also found in HR locos.
The 12 is (I assume) a prefix meaning the loco is for 20v electric operation.
The last 3 digits (920) change depending on the size of the loco, the smallest locos begin at 880, followed by 890, 900, 910, and 920. 920 seems to have been used for the R920 and anything which happened to be larger.
Some locos first produced in the 1920s, but with production which continued into the 1930s, do not follow the same pattern with any of the numbers after the /.
For those locos: 402x = Live Steam operation; 102x = Clockwork operation, 1302x = Electric operation. The x can either be a 1 or an 0 depending on the gauge.
The train set H744 bears no relation to the HR66/12920 since it is 00 gauge!
Offline Dennis H.
#6 Posted : 21 January 2018 04:13:14(UTC)
Dennis H.
Hi Paul, Steve, Thanks for your responses and great information. Yes, I have a great deal of Lionel, American Flyer, and other stuff Jep, bing, KBN, Bassett Lowke, Would be better if I could focus on something. My layout is tube style tinplate track with a couple of lower level 042/054 curves and I've been working on an upper level with 072 or maybe 096 for some other locos I have. I suspect this HR66 will have to go up there too as the 042 will likely be tad tight for it with the flanged center drivers.
I did ask the seller if he had found any other stuff with the Marklin train and he did say he found some track and lockons etc, so we'll see what turns up. For what it's worth, I use old transformers, always have even with the Lionel Legacy loco's I have although I need to add some protection for those locos. I figure the Postwar Lionel ZW would be good for this but probably better would be the Prewar 250 Watt Z since it dials up to 24 volts and the ZW only to 20 volts. I will say this, those old Lionel transformers are real lumps but man they are indestructible and they really will get a big heavy train up and motoring. Nothing like a set of 2343 twin motor F-3s humming on 072 curves pulling everything you can tie on with the Z cranked up all the way Love .
After looking some of those interiors on line it almost seems like you could fabricate something like them out of thin brass or sheet metal. Would not be correct, but might not be to bad lol.
Paul, since you were watching this set on ebay, I assume you saw the E66 12920 set also on ebay right now with the three 175XX series cars? Before this set was listed, I made offers of $400 and $450 FOR THE E66 set but he turned me down. He came back and said he'd take $500 for the set. Glad I waited for the HR LOL I suppose even $500 for the E66 set isn't all that bad but it's probably at the top of what that particular pile is worth
Dennis H.
Offline Dennis H.
#7 Posted : 21 January 2018 04:26:56(UTC)
Dennis H.
Thank you Peter, That actually clarifies a good bit for me. I had been looking at several auctions for the last couple of weeks and making sense of or learning the numbers so to speak. It's no different than Lionel, you gotta learn the numbers to know what your looking at LOL
Something else I think I picked up that I'm curious about. Is it correct that the Green variations of these loco's like the HR66, E66, GS66 were only made in 1932? I read that somewhere and want to make sure I learn it correctly!
Dennis H.
thanks 1 user liked this useful post by Dennis H.
Offline Pmare4
#8 Posted : 22 January 2018 01:04:01(UTC)
Pmare4
Hi Dennis,
Green locos were made until the middle of 1933, then the colour changed to matt black. The GR is particularly difficult to find in green, since production only began in early 1933, and by the time the New Items Sheet of 1933 was sent to dealers in May, the loco was described as being finished in Matt Black. Of course they were still available after that, but only as special orders from the factory.
Below is a picture of a dark red E920 made as a special order for Hermann Goering.
Unfortunately, since I don't speak Lionel, I've made a glossary below with the correct English terms in the centre and the Hornby equivalent on the RH side: BigGrin
027 - 1ft Radius curved rails - EA1 Electrical Curved Rails
036 - 1.5ft Radius curved rails
042 - 1.75fr Radius curved rails
048 - 2ft Radius curved rails - EA2 Electrical Curved Rails
054 - 2.25ft Radius curved rails
072 - 3ft Radius curved rails - EA3 Curved Rails
096 - 4ft Radius curved rails
Lockon - Terminal Connecting Plate - TCP Terminal Connecting Plate
The Marklin HR is capable of running on 3ft Radius or larger curved rails. The ones I would recommend are Hornby Solid Steel Rails, and of course the Marklin Modellschienen.
Offline Dennis H.
#9 Posted : 22 January 2018 03:12:02(UTC)
Dennis H.
Hi Peter, Thanks for your thoughts. I also have a supply of Gargraves track which is T rail in profile with wooden ties and flexible. Nice track really. Here is a portion of my Lionel layout with some prewar colorful trains. It will be nice to add the HR66 and the JEP SNCF 222 I have coming to the layout.
Dennis H.
Offline Pmare4
#10 Posted : 22 January 2018 06:14:32(UTC)
Pmare4
Very nice Dennis, I don't collect Lionel myself but the Prewar trains are very nice. I particularly like the streamlined Commodore Vanderbilts. Is that an original Blue Comet in the station? As well as Marklin HO I also collect Hornby O gauge, a picture showing some of my locos is attached below.
Gargraves track is nice, although since Marklin locos are fitted with Spoon pickups, not rollers like on Lionel items, you might have some difficulties around points and crossings. Since your layout looks to be fitted with tubular-rail tinplate tracks, you shouldn't have any issues though.
thanks 1 user liked this useful post by Pmare4
Offline Dennis H.
#11 Posted : 26 January 2018 05:16:55(UTC)
Dennis H.
Very Nice Peter! I Don't have any Hornby yet but do have a few Bassett Lowke "projects" that I would like to get running eventually. It seems that I collect projects more than trains sometimes! Yes, the Blue Comet as you see it is original although it is sitting on a replacement frame as the original crumbled due t zincpest. Hopefully, the HR66 will show up in the post tomorrow or Saturday as I am getting a bit anxious although I've been working on the JEP 222 I got in the mean time. There are always trains to work on!
Dennis H.
Offline Dennis H.
#12 Posted : 26 January 2018 05:31:49(UTC)
Dennis H.
Peter, I can't resist since you mentioned you liked the Commodore Vanderbilts. Here are two. One is the Lionel Red Comet 264E, this one is all original. The second is a custom stretch job I've been working on. I took two 264E shells and two tender shells and spliced them in order to get a real 4-6-4 sized tinplate CV. Actually, the Marklin Prewar CV was my motivation for my 265E stretch project. I still have a ways to go and don't work on it as often as I would like but I think I will be happy with it once it is finally complete.
Dennis H.
This page was generated in 0.449 seconds.
