Offline guitartoys
#1 Posted : 02 November 2017 00:32:09(UTC)
guitartoys
So I'm going to need a pile of wire, both for connection between a device like a track section or turnout to the controller, and then some heavier gauge wire for busses.
In looking at the books I have found, it looks like Marklin's standard color wires are
Wire:
Gray
Blue
Brown
Yellow
Red
Yet their plugs colors are
Plugs:
Gray
Brown
Yellow
Green
Orange
Red
(no blue?)
Why would I not just get wire the same colors of the plugs, and have the entire wire that color?
Just wondering
Thanks.
M
Offline Pmare4
#2 Posted : 02 November 2017 01:26:19(UTC)
Pmare4
Blue wires are for solenoid connections and have either red, green or orange plugs on the ends. Red plugs are for setting points to the bend or for setting signals to go (1 diagonal arm). Green plugs set points to the straight and signals to stop (1 horizontal arm). Orange plugs are used to set signals to "proceed with caution" (2 diagonal arms).
Brown wires are for ground connections, yellow wires for lighting, and grey wires for items such as house/street lamps which can be wired with either wire as a ground connection. Red wires are for track power. All of these wire colours have matching plugs.
In terms of what wire to use I would recommend 24AWG gauge wire (same as the official Marklin product) in the correct colours so that way you don't connect your track power to ground or make any other easily preventable mistakes.
#3 Posted : 02 November 2017 04:41:02(UTC)
You are correct for points wiring, but for signals red is stop and green is go!
Offline Pmare4
#4 Posted : 02 November 2017 05:16:22(UTC)
Pmare4
Actually... It's not. See this excerpt from the Marklin Miniature Railway handbook:
MÄRKLIN signaling installations on a large scale can be made up by placing several signaling control panels together,
one after the other (fig. 156). Such a signaling system is like a power-operated signal box on a full-sized railway. Each
control panel has red and green buttons to show the positions of signals or points, as the case may be. If a red button
is higher than the green one working with it, the signal will be at "Danger"
and the points open for the branch line.
If the green button is higher than the red one, the signal will show "Line clear" and the points will be open for the main
line. The settings of the points and Signals can therefore be seen from the control panels alone, even though they may
be out of sight from the signal control point, owing to being hidden by a hill or a building.
#5 Posted : 02 November 2017 05:32:49(UTC)
That seems to be a somewhat extreme setup, and since there doesn't seem to be an accompanying wiring diagram, I'd have to take that advice with a grain of salt. The Marklin signal manuals definitely show green for go and red for stop. I'll dig them out when I get home, but I'm not one to argue with them.
Offline Pmare4
#6 Posted : 02 November 2017 05:47:43(UTC)
Pmare4
You might be right there... Either way I just reread the excerpt I posted above and it turns out green pressed in means points are set to the branch...
The button sticking up is meant to represent the "current state" of the signal or points.
thanks 1 user liked this useful post by Pmare4
Offline applor
#7 Posted : 02 November 2017 06:11:37(UTC)
applor
Annoyingly they use brown for earth instead of just black. In domestic electric brown is active Cursing
Offline Pmare4
#8 Posted : 02 November 2017 07:23:42(UTC)
Pmare4
Black was ground for Marklin until the 50s! But then again black was the only colour of plug available.
Offline Br502362
#9 Posted : 02 November 2017 08:57:39(UTC)
Br502362
Blue, black and white plugs are also used.
This is quite good but in German language.
http://www.maerklin-sammler-inf.../kabel_steckerfarben.htm
Åke
#10 Posted : 02 November 2017 09:09:34(UTC)
I'll dig them out when I get home....
Excerpt from the 0340 Signal manual
Likewise from the 0361 Signal manual
Offline Pmare4
#11 Posted : 02 November 2017 09:31:27(UTC)
Pmare4
Hi Åke,
I think the white, black, and blue plugs have been made up by the author for use on their home layout.
That's strange - a few pages later it says the opposite:
#12 Posted : 02 November 2017 10:46:43(UTC)
I don't think so, they are available from Brawa as specific items (I've just purchased some Black and Blue's).
Brawa 3051 - 10 Yellow Plugs
Brawa 3052 - 10 Red Plugs
Brawa 3053 - 10 Green Plugs
Brawa 3054 - 10 Brown Plugs
Brawa 3055 - 10 Blue Plugs
Brawa 3056 - 10 Orange Plugs
Brawa 3057 - 10 Grey Plugs
Brawa 3058 - 10 Black Plugs
Brawa 3059 - 10 White Plugs
Offline Pmare4
#13 Posted : 02 November 2017 11:00:27(UTC)
Pmare4
I don't think I was quite clear there. I meant the author invented their own wiring code for the plugs.
#14 Posted : 02 November 2017 19:43:28(UTC)
One deviation I make to the standard Marklin colour codes is to change the colour of one of the blue wires to purple. I use the blue wire for the green plug and the purple wire for the red plug. This way when extending wires to the control box I don't have to guess which wire is which.
Offline Rwill
#15 Posted : 02 November 2017 20:29:39(UTC)
Rwill
All very sensible and then they introduced the "new style plugs" which don't integrate with the old style at all and now many things like decoders have gone back to screw terminal which I actually prefer and a lot of use the various cable joiners like "wago" and then the Start up range uses moulded plugs and sockets and a completely new and contradictory colour scheme for wires
#16 Posted : 02 November 2017 21:14:52(UTC)
Running the correct color wire is much more important that the color of the plug.
For running power to tracks (ground and digital) as well as 16V AC and 12V DC you want to use a good heavy (thick) wire. Since wire can be expensive you may like the option of buying one big roll of (say) white and then color the wire brown/red/yellow etc as needed. See https://cabin-layout.blo...changing-wire-color.html
For running s88 feedback wires you need multistrand cables (cat 5 is good and readily available) see https://cabin-layout.blo...m/2014/08/s88-cable.html for examples and discussion on color there.
#17 Posted : 02 November 2017 21:35:01(UTC)
Without knowing, I think this writer is confused or the translation wrong.
To me it is very strange to push the green button for STOP and the red for GO.
It should be the other way round, IMHO.
P.S: Orange wire is known to be the best !!! BigGrin
#18 Posted : 02 November 2017 22:25:12(UTC)
Exactly!
Exactly!
(I'm trying to find the orange wire thread, but I'm sure Per will know where it is)
Offline Pmare4
#19 Posted : 02 November 2017 22:50:56(UTC)
Pmare4
Hi Per,
That's German logic for you...
As long as you use the same convention for all your wires and plugs I think you'll be alright.
#20 Posted : 02 November 2017 23:19:04(UTC)
Exactly!
I think it started with a quiz, which ended in a lot of strange things.
https://www.marklin-user...---Quiz--Weird-Wire-Vote
It also reminded me that I promised to supply wooden hand uncouplers, which I never have done. Crying
Wooden hand uncouplers is another good story, which I don't have time to find right now.
Offline Jabez
#21 Posted : 02 November 2017 23:28:24(UTC)
Jabez
If you are unhappy with the Marklin convention of which switchbox button should be pushed in (and thus which one rises up as a status indicator) just swap the incoming red and green plugs onto the opposite colour sockets on the switchbox and you will get the opposite effect.
#22 Posted : 03 November 2017 00:07:06(UTC)
You will have to send them to Donnie now, George has moved out of that house....
#23 Posted : 03 November 2017 03:19:21(UTC)
I use wooden plugs and paint them in various colours
Offline DB Fan
#24 Posted : 03 November 2017 03:46:07(UTC)
DB Fan
LOL LOL LOL LOL ThumpUp ThumpUp
#25 Posted : 03 November 2017 04:54:03(UTC)
sjbartels
I'm good with the black plugs and wire.... but I'm with BDNZ..... what in the heck do I use these orange plugs for????? They seem to be multiplying and yet I've no use for them!
MrB32
#26 Posted : 03 November 2017 05:12:39(UTC)
Officially (https://www.maerklin.de/fileadmin/media/service/faq/Technik-Tipp-102.pdf) Orange is for the position slow available on some signals (for example 7041).
#27 Posted : 03 November 2017 05:45:38(UTC)
sjbartels
Interesting......
MrB32
#28 Posted : 03 November 2017 05:46:27(UTC)
not really... :) :) :)
Offline Pmare4
#29 Posted : 03 November 2017 06:04:59(UTC)
Pmare4
Orange plugs multiply by the Purellum factor (1000) and are only suitable for use on official Marklin-Users.net Orange Wire®.
Use on non-Marklin-Users.net products is not sanctioned under Federal Regulations and is punishable by paying a fine of $500 to the Webmaster or sending him (or me!) 5 locos - whichever is more expensive.
LOL Cool
thanks 2 users liked this useful post by Pmare4
#30 Posted : 03 November 2017 06:12:12(UTC)
sjbartels
LOL Cool
That's it, I am breaking out the Piko lok's!!!!
thanks 1 user liked this useful post by sjbartels
#31 Posted : 03 November 2017 10:29:01(UTC)
I treasure my coil of orange wire and my wooden hand uncoupler which form the load for my Marklin-user.net wagon. Whenever I run it on my layout it reminds me what crazy fun this forum can be sometimes! BigGrin
#32 Posted : 03 November 2017 22:02:06(UTC)
Depends on where you live:
Wire Color Codes Site
Brown or Black are hot phases in AC power, while Blue or White are neutral phases in AC power.
Where as for German automotive (maybe Bosch originated, not sure) the colors are
Brown - Ground/battery neg, Red - battery positive
#33 Posted : 03 November 2017 22:22:39(UTC)
I have a feeling that one of the blue wires may have been cut slightly shorter than the other, but can't remember which one (possibly the one with the red plug)? Can anyone confirm?
At any rate Ray's method is visually easier to follow.
#34 Posted : 05 November 2017 08:25:08(UTC)
.... they are available from Brawa as specific items (I've just purchased some Black and Blue's).
All very sensible and then they introduced the "new style plugs" which don't integrate with the old style at all ...
Yes indeed, the Brawa are a great substitute for the old style Marklin plugs which I prefer to continue for consistency, I use a lot of them :
PJ
#35 Posted : 05 November 2017 08:51:55(UTC)
Views messages in topic : 4,018
Great idea, and economical, but you have to remember to use conductive paint, and for some colours this is very expensive Scared
Guest (4)
This page was generated in 1.294 seconds.
