Offline Unholz
#1 Posted : 28 August 2017 15:12:19(UTC)
Unholz
Report in the German Stummi forum with regard to Marklin's SBB Eb 3/5 cat. no. 37195: https://www.stummiforum....=2&t=151642#p1719818
Offline Eurobahnfan
#2 Posted : 28 August 2017 17:40:25(UTC)
Eurobahnfan
Views messages in topic : 431
I have a few older Maerklin rolling stock pieces that have developed some slight warping, though nothing serious... and certainly nothing like this on my locomotives. I'm very careful about the environment in which my trains are stored or operated, but even then, you can't prevent something that's bound to happen as a result of poor construction. Not saying the newer stuff isn't of good quality, but with very few exceptions, I haven't purchased too many new items over the last few years.
#3 Posted : 28 August 2017 18:22:33(UTC)
I can't blow up the images- where were the issues on the locomotive? I have a 37136 I should probably check out.
I'm getting tired of having to fix these plastic-pest issues... (and zinc) US boxcars, Kof, ALl 3 of my seetal crocodiles...
#4 Posted : 29 August 2017 02:54:38(UTC)
Is this the result of the plastic warping due to heat or other cause or is this another case of plastic damage from metal deterioration?
Offline Tower
#5 Posted : 29 August 2017 15:15:09(UTC)
Tower
I've had to bin at least 10 plastic US box cars due to severe warping. Al my wagons including the hopper car and the caboose from my 29570 American Starter set had to go, all were released around 2005. They were stored in their boxes in a cool area so I do not believe heat was the issue.
Very annoying!
#6 Posted : 29 August 2017 16:11:01(UTC)
That probably is real zincpest (Made in China stuff), not a plastic problem.
The metal frame distorts and causes the plastic body to break.
This here is a case of real zincpest (deforming metal):
Offline Eurobahnfan
#7 Posted : 29 August 2017 17:08:28(UTC)
Eurobahnfan
HO... wow: that's incredible! I don't recall seeing one quite like that, ever. The collector in me says to stick with finding those items made 20 years back or further -- at least then I can see if there are any issues present. It's hard to justify the price of some of the newer items considering you're left to wonder how they'll hold up.
#8 Posted : 29 August 2017 21:02:20(UTC)
The right kind/formula of aluminized zinc casting material is important. ... and outsourced makers will cut corners to save money without stringent oversight and testing. Its almost as if one has to take a sample from the liquid metal for testing every week to ensure no cheating.. its like the Olympics. Impurities in the mix are apparently the cause, that react to moisture in the air, and cause crystal formation/changes within the cast parts that then deform the parts.
Offline Tower
#9 Posted : 30 August 2017 12:22:16(UTC)
Tower
Mine did exactly this, Is it Zinc Pest?
thanks 2 users liked this useful post by Tower
#10 Posted : 30 August 2017 13:40:55(UTC)
Yes, the floor of the cars is fine metal - it bends and eventually breaks the plastic body. Not a plastic problem, just the well-known China zincpest.
Offline TEEWolf
#11 Posted : 01 September 2017 19:03:48(UTC)
I do not know. But at Wikipedia I found a very interesting article (in English). This article shows a picture with wheels of a Maerklin coach having the zinc pest.
Zinc pest at Maerklin wheels
Offline Collector
#12 Posted : 01 September 2017 19:51:53(UTC)
Collector
You are not the only one. I don't want to find out 5 years down the line that the quality control in China sucked or at least was unable to spot things which come to light only years later!
DRG/DB/SBB Epoche II/III/IV
thanks 1 user liked this useful post by Collector
Offline dickinsonj
#13 Posted : 03 September 2017 02:30:23(UTC)
It makes me wonder...
Edited by user 03 September 2017 14:21:25(UTC)  | Reason: Not specified
#14 Posted : 03 September 2017 08:43:52(UTC)
It makes me wonder [...]
This thread is about deformed plastic parts.
Please ask questions about real zincpest in appropriate threads like this:
https://www.marklin-user...boxcars---Zinkpest-today
https://www.marklin-user.../t347-What-is--Zinc-Pest
Guest (6)
This page was generated in 0.528 seconds.
