Joined: 08/03/2013(UTC) Posts: 2 Location: Burbage Wiltshire
Any thoughts on using the M track 7171 soundabsorbers. Could one use strips of thin foam rubber or soft rubber sheeting instead. IF using 7171 do you have to use 2 per rail?
I have had 7171 sound absorbers in two layouts. The first one had only one 7171 per rail which wasn't good. Latest layout has two per rail and works good. No experience with other materials.
My friend has used cork underlay which seems to work also.
Åke
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
To minimise sound from the track it's also a good idea to minimise the number of screws used to hold the track in place. The sound travels through the screws into the wood of the baseboard which then amplifies it. On my old M track layout I got a significant reduction in noise by only having one screw for every 3 pieces of track instead of 2 screws per track as I had previously |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
 3 users liked this useful post by RayF
