Offline David1952
#1 Posted : 01 March 2017 00:33:32(UTC)
David1952
Any thoughts on using the M track 7171 soundabsorbers. Could one use strips of thin foam rubber or soft rubber sheeting instead. IF using 7171 do you have to use 2 per rail?
Offline Br502362
#2 Posted : 01 March 2017 07:02:28(UTC)
Br502362
I have had 7171 sound absorbers in two layouts. The first one had only one 7171 per rail
which wasn't good. Latest layout has two per rail and works good. No experience with other materials.
My friend has used cork underlay which seems to work also.
Åke
#3 Posted : 01 March 2017 10:24:29(UTC)
To minimise sound from the track it's also a good idea to minimise the number of screws used to hold the track in place. The sound travels through the screws into the wood of the baseboard which then amplifies it. On my old M track layout I got a significant reduction in noise by only having one screw for every 3 pieces of track instead of 2 screws per track as I had previously
This page was generated in 0.539 seconds.
