Offline Carim
#1 Posted : 12 December 2015 19:38:28(UTC)
Carim
I apologize straight off if I am asking some really dumb questions here. I recently bought some Marklin 89391 block signals and a Viessmann 4811 block signal (I believe that they are effectively the same product). Looking at the documentation that came with the signals, the Marklin signals need a 16V power source and the Viessmann needs 14-16V. The accessory output on my 67013 controller is marked as 11V; so am I correct in thinking that I am going to need an alternative power source to power these signals? If so, can anybody recommend a solution (I only have four signals)?
Secondly, I was going to control the signals manually via a Viessman 5550 universal switch. This comes with a series of plugs that I guess you use to attach the relevant wires to the switch. Are you just meant to stick the wire through the plug and then ram it into the relevant hole on the switch? It doesn't seem to give a very secure connection. Also how much bare wire should protrude from the tip of the plug?
Finally, when I was playing around with one of the 89391 signals, a resistor fell off one of the wires. When I examined the wire, it looked like the insulation had never been stripped i.e. it looks like the wire was just stuck onto the resistor with a bit of insulation tape and there may never have been a proper, soldered, metal to metal contact. Has anyone else come across this problem? Obviously, on this example I am going to have to remove the tape still stuck to the resistor and resolder the connection, but I am not going to be too impressed if I have to do this for all of them. Cursing
Carim
Edited by user 14 December 2015 17:12:40(UTC)  | Reason: Changed status from "Question" to "Solved"
#2 Posted : 12 December 2015 19:55:30(UTC)
Hi Carim,
Can't help you with the first and third questions, but I can tell you how I use the Viessmann plugs.
Stick the stripped wire (strip about a cm back) through the plug as you correctly guessed, but then fold the uninsulated wire end back so that it lies along the outside of the plug body. When you insert the plug in the socket the part of the wire that is folded back will make contact with the metal sides of the socket and also help to keep a tight fit between the plug and the socket. Once you've done one or two you will know how much of the insulation to strip back.
Hope this helps.
#3 Posted : 13 December 2015 00:18:46(UTC)
You have been a member since:: 23/07/2014(UTC)
Carim
Hi Carim
I suspect that what you are looking at is a solder joint that has been covered with heat shrink tube after it has been soldered (what you describe as tape).
I suspect what has happened is the wire has been nicked when the insulation was stripped off, and the solder hasn't wicked up the wire and under the insulation. The wire has then broken off at the end of the insulation leaving the rest of the wire in the solder joint on the resistor lead.
The best way to remove the heat shrink is to use a sharp knife (a scalpel type of knife is ideal) and cut it length wise, and then split it open to peel it off the lead. If you have a Maplin store near you, they may stock heat shrink tube of a suitable size (you will probably need the smallest size they have) otherwise you can get it from Farnell or RS or Rapid. The new heat shrink will shrink to half (or possibly a third) of its unshrunk diameter.
On re-reading this before posting I realise I am assuming the heatshrink is only over the resistor leads. If they have used a single piece that goes right over the resistor body then it probably has not shrunk small enough to go tight on the flexible wire, which it needs to do to provide the mechanical protection to the wire to help prevent exactly what has happened.
If you were nearby I would say bring it over and i could sort it out.
Alan
Offline gwolski
#4 Posted : 13 December 2015 03:30:25(UTC)
gwolski
Carim
1. Voltage - Check your signal manual again. Mine says maximum of 10V for the signal LEDs but separately 16V are needed if using the 7244 relays. My layout is digital, so I'm driving my signals from an ESU SwitchPilot using 10V external power supply.
2. Quality - I own about a dozen of the Marklin signals, and mine are just fine. Hoping you just happened to get one with a substandard solder joint.
Cheers!
Gene Wolski
Offline Carim
#5 Posted : 13 December 2015 10:30:33(UTC)
Carim
Alan
Hi Alan,
Thank you for the offer and those excellent instructions. Fingers crossed, I should be able to do the repair it on my own (I think it would be a four hour round-trip to you). If I mess it up with the soldering iron, I'll come running back for help! Blushing
Kind regards,
Carim
Offline Carim
#6 Posted : 13 December 2015 11:13:15(UTC)
Carim
Cheers!
Hi Gene,
Yes the Marklin document says exactly what you said.
On Viessmann 4811 it says:
Technical Data
Poweer supply: 14 - 16 V
current (for each LED): approx 10 mA
and in the diagrams shows the signal wired to the 5550 switch and the wire with the diode going to a 5200 (transformer).
So I tried to recreate the above circuit using the 67013 controller/transformer; but nothing worked. Then I noticed that the accessory output was 11 V - hence my original question. So I am wondering why nothing works - is it because I am using too low a voltage or is there something wrong with the wiring (I know for one signal that is the case)?
The documentation with the Viessman 5550 suggests that you do need a 16 V supply:
So if I want working signals, do I need to buy a transformer with a 16 V output? Crying
Carim
#7 Posted : 13 December 2015 12:37:20(UTC)
Did you check the polarity of the voltage?
The signals need DC - and if the DC from your 67013 has the wrong polarity then you won't see lights.
Offline Wal
#8 Posted : 13 December 2015 13:14:43(UTC)
Wal
hello Carim,
I use these 89391 signals on my Z layout. I power them from the the grey/yellow output on the standard 67013 controller. I control them from the "basic" 8945 universal relay. This is sufficient for these signals because they only have the red and green function. For all the other signals you require a different relay which comes from the HO range and hence requires the 16v to drive it.
I have some recommended reading for you which helped me immensely to set these signals up.
There is a web site called "Guidetozscale" and if you go to the following two links it will all be explained...
//guidetozscale.com/html/automatic_operation.html
//guidetozscale.com/html/signals.html
Wal
Offline Carim
#9 Posted : 13 December 2015 15:10:58(UTC)
Carim
Hi Tom,
If you look at the second Viessman document in post #6, it suggests either AC or DC. Prior to seeing this, I thought that LEDs needed DC and that I would have to use a bridge rectifier in the circuit if my power source was AC (as it is). I thought that there may be something in the 5550 switch acting in conjuntion with the diode on the signal that effectively converts the polarity - or am I totally wrong?
If I added a bridge rectifier to the 11V AC power source, I would get a DC current but it still looks like insufficient voltage to operate the 5550 switch. (Also what voltage on the bridge rectifier - is higher better than lower?). Confused Confused
I am fast coming round to the conclusion that I need another transformer or I have to be happy with non-working signals on my layout! Crying Crying Cursing
Carim
Offline Carim
#10 Posted : 13 December 2015 15:43:15(UTC)
Carim
Originally Posted by: Wal Go to Quoted Post
hello Carim,
Wal
Hi Wal,
Thanks for all that helpful info. I had read up the stuff on "Guidetozscale" before posting, but it still left me confused. My problem comes from not being an electronics expert and from trying to mix Viessmann and Marklin. Primarily, I wanted to avoid all those Marklin relays because I physically have no space for them on my layout. In fact, I never intended to have working signals on my layout; I just saw some on a layout at the Zedex 2015 exhibition and thought, wow those look nice! Then in an impulsive fit of late-night internet shopping, I set myself up for all these problems.
Given that I already have the Viessman switch, I think that the simplest, cheapest and most space-efficient solution is to get hold of a Viessman 5200 transformer. But I still don't get how the LEDs can run on its AC output.
Carim
#11 Posted : 13 December 2015 16:59:34(UTC)
Are you sure your power source is AC and not DC?
The 67013 comes with a DC wallwart and I don't think it will generate an AC output when you feed DC into it.
Offline Carim
#12 Posted : 13 December 2015 17:50:36(UTC)
Carim
Hi Tom,
No I am not 100% sure, but Gaugemaster (the UK distributor) said that the accessory outlet is AC, but they said that it has no +ve or -ve (you may remember my previous question about this - this answer contrasted with Marklin's reply in which they said that the yellow terminal had a +ve charge). The controller itself has markings next to the red terminal indicating 11V DC (I assumed that this only referred to the red/brown terminals). The website "Guidetozscale", as mentioned by Wal above, suggests that accessories need AC; so I assumed the yellow and grey terminals are AC. Maybe you can start to understand why I am getting a bit confused.
Carim
#13 Posted : 13 December 2015 18:02:07(UTC)
Solenoids work with either AC or DC.
With a DC voltmeter you can check if the output is DC (if you have one).
You can try the signal with reversed voltage from the controller.
Offline Carim
#14 Posted : 13 December 2015 19:40:24(UTC)
Carim
Thanks for that info.
No need for the voltmeter as I've just looked underneath the 67013 and found an inscription indicating both outputs are 11V DC. Blushing Well some progress at least! So I am now just underpowered - my 5550 switch needs 16V.
Offline gwolski
#15 Posted : 14 December 2015 03:32:31(UTC)
gwolski
The Viessmann 5550 is simply a switch and does not have a minimum voltage (although it does have a 24V max rating). As long as your wiring from the LED signal and power pack are correct, it will simply apply power to either the red or the green LED (if we're still discussing the two color block signal).
The red and green LED wires from the signal should connect to the 5550 along with the grey (?) accessory output from the transformer. The other wire (with the heat shrink diode) is attached to the yellow accessory output.
Now that I say that, did you re-attach the diode backwards? They are direction sensitive.
Cheers!
Gene Wolski
Offline gwolski
#16 Posted : 14 December 2015 03:35:58(UTC)
gwolski
Gene Wolski
Offline gwolski
#17 Posted : 14 December 2015 03:39:03(UTC)
gwolski
NOTE: In the 5550 wiring diagram, it shows how to wire the signal and box if you also wish to control track power with it. If you simply want to control the signal, then the red and green wires go into the appropriate holes for the one switch. Does that make sense?
Gene Wolski
thanks 1 user liked this useful post by gwolski
#18 Posted : 14 December 2015 07:32:37(UTC)
Turn the diode around and you risk the LEDs in the signals.
Try the diode at both poles. With märklin you might find that yellow is minus, not plus.
Offline Carim
#19 Posted : 14 December 2015 09:47:44(UTC)
Carim
Cheers!
Gene,
Thanks for this - this is the sort of level that I need - all makes sense now. I haven't touched the wire with the diode on it, just one "green" resistor fell off. I had got confused as I thought that with LEDs, the resistors had to be placed ahead of the LED on the +ve wire. But according to DCC Concepts' literature, whilst that is best practice, it doesn't really matter. I will repair the broken signal and make a test set-up and let everybody know how I get on.
Carim
Offline Carim
#20 Posted : 14 December 2015 17:10:52(UTC)
Carim
We have success!!!! BigGrin Signal repaired and got it working. Many thanks to everyone who helped on this one. BigGrin BigGrin
Offline gwolski
#21 Posted : 14 December 2015 23:10:05(UTC)
gwolski
In the end, the circuit works as long as you don't exceed the maximums for the LED (that would be bad). As long as the resistor (correctly sized for your power supply) and LED are in series, the voltage drops across each no matter the order in the series. Obviously the LED (it is a diode, after all) has to be connected correctly.
I'm so glad you have it working! I really like my 8939x series signals.
Cheers!
Gene Wolski
This page was generated in 1.223 seconds.
