Firstly I deleted all the locos in my MS2. There were 7 listed, why I don’t know as I have only 2 locos. The locos deleted were:
BR 24 014
MM2 – 20
MM2 3
MM2 – 16
BR 50 981 DB
DCC- 0
BR 03
I don’t understand the MM2 and DCC references in relation to locos. The terms aren’t explained in the Instruction booklet. The BR’s are definitely locos.
Having now deleted all locos from the MS2, I set about reentering my two locos. I placed the BR 50 981 (29640) on the track and followed the instructions for:Entering a Locomotive with the resulting outcomes:
1. Registering an mfx Locomotive - No loco detected
2. Entering a Locomotive with a Locomotive Card - I have no card so could not action.
3. Finding a Locomotive (Select Find) - Loco found as BR 50 981 DB. Loco runs perfectly with all functions working. Excellent.
Note: This loco address is the same as the name set at the factory according to the loco Manual. This loco address is NOT in the Database. The Database lists 33840 BR 50 3448 but I found my Loco
did not respond to that address.
I removed the above loco from,the track and replaced it with the BR 03 and repeated the process with the following result:
3. Finding a Locomotive (Select Find) - Loco found as DCC – 0 (with f1, f2, f3). Loco responded to ON/OFF commands only. No control possible.
4. Finding a Locomotive (Select From Database) – 100’s of options available – couldn’t find the appropriate address.
5. Entering a Locomotive Manually - I couldn’t understand this section. MM2 Programmable, DCC, Domain. What’s that all about?? No explanation in MS2 Instruction booklet.
I then became suspicious about the BR 03 loco. After spending several hours with Professor Google, I concluded:
1. The BR 03 loco included in a 29640 “Era III” Mega Digital Starter Set is a 37957? BR 03 252 with name set at the factory: BR 03. ( I have the Manual)
2. The BR 03 loco that came with the so-called 29640 set I bought is actually a BR 03 1022. My research indicates that this is a 2000/01 model with fx , not mfx.
To confirm this conclusion, I removed the tops of the tenders from both locos and found the BR 03 has a 602758 fx(?) decoder. I could not locate a reference number on the BR 50 decoder but assume it’s the latest version mfx decoder.
I’m going to contact the vendor and try to get resolution to the problem of the substituted BR 03’s.
In the meantime, is there any way of getting the BR 03 1022 to operate on my set-up (MS2 and C-track)??
nunk attached the following image(s):
