Offline billys7
#1 Posted : 20 July 2013 01:12:24(UTC)
billys7
Do you know what kind of signal, is the short circuit report, that accept a central unit from a booster ?
Thank you!
Online H0
#2 Posted : 20 July 2013 08:13:03(UTC)
Märklin boosters set the short circuit line to positive in the case of a short circuit. I don't know which voltage will be used.
Offline efel
#3 Posted : 20 July 2013 15:09:08(UTC)
efel
After the 6015 booster schematic, it's a +5V
See Here (X1-5 output)
Fred
Offline billys7
#4 Posted : 20 July 2013 17:48:34(UTC)
billys7
Thank you for your answers.
I have seen the same part of the "Short Circuit Message" also here http://www.stayathome.ch/booster_en.htm , but i don't know how exactly works.
Can you explain me ?
Thank you.
Online H0
#5 Posted : 20 July 2013 19:41:14(UTC)
If one booster is on overload or detects a short circuit, it gives a positive voltage to the short circuit feedback line - and the CU will then turn the track current off as if the CU detected the short circuit itself.
Offline billys7
#6 Posted : 20 July 2013 20:42:37(UTC)
billys7
Ok. I understand that, but i can't understand it on the schematic.
Offline efel
#7 Posted : 21 July 2013 13:31:05(UTC)
efel
There are several ways, more or less sophisticated, for detecting a "short" on the track, and nearly every booster has its own.
Below a short explanation:
Refering to the 6015, you will see that if the booster output exhibits large enough negative waves (-16 to-24V is the normal value), the voltage at the "D3-R5-R6-C4" rectifier-filter will be low enough to get 0V at the op amp output, hence to X1-5 (short circuit report line) . Otherwise (= short or low voltage on the track), op amp output will be 5V, as well as X1-5.
thanks 2 users liked this useful post by efel
Offline billys7
#8 Posted : 22 July 2013 15:57:00(UTC)
billys7
Thank you very much for the explanation.
Vasilis
This page was generated in 0.420 seconds.
