Joined: 27/07/2010(UTC) Posts: 32 Location: Athens - Greece
Do you know what kind of signal, is the short circuit report, that accept a central unit from a booster ?
Thank you!
Joined: 16/02/2004(UTC) Posts: 15,463 Location: DE-NW
Märklin boosters set the short circuit line to positive in the case of a short circuit. I don't know which voltage will be used. |
Hi, After the 6015 booster schematic, it's a +5V See Here (X1-5 output) Fred
Thank you for your answers. I have seen the same part of the "Short Circuit Message" also here http://www.stayathome.ch/booster_en.htm , but i don't know how exactly works. Can you explain me ? Thank you.
Originally Posted by: billys7  but i don't know how exactly works. If one booster is on overload or detects a short circuit, it gives a positive voltage to the short circuit feedback line - and the CU will then turn the track current off as if the CU detected the short circuit itself. |
Ok. I understand that, but i can't understand it on the schematic.
There are several ways, more or less sophisticated, for detecting a "short" on the track, and nearly every booster has its own. Below a short explanation: Refering to the 6015, you will see that if the booster output exhibits large enough negative waves (-16 to-24V is the normal value), the voltage at the "D3-R5-R6-C4" rectifier-filter will be low enough to get 0V at the op amp output, hence to X1-5 (short circuit report line) . Otherwise (= short or low voltage on the track), op amp output will be 5V, as well as X1-5.
 2 users liked this useful post by efel
Thank you very much for the explanation.
Vasilis
