Offline klafleur3
#1 Posted : 05 July 2013 16:11:09(UTC)
klafleur3
I'm looking at buying a Marlin 76515 remote crane for my digital layout. Can anyone tell me you much powers does it require to operate? I'm worried about it effecting the performance of me running multi trains on the layout. Also, does it work with a Marlin 6021 control unit without a keyboard? Ken
thanks 1 user liked this useful post by klafleur3
Offline kbvrod
#2 Posted : 06 July 2013 17:33:46(UTC)
kbvrod
Hi klafleur,all,
Can one of you guru's help with this?Blink
Dr D
Offline Markus Schild
#3 Posted : 06 July 2013 18:24:30(UTC)
Markus Schild
The power consumption is negligible. The crane is powered by small can-motors which have a very low consumption. The manual describes how to operate it with 6021:
Copy and paste the link to new window.
Markus
Offline thealien666
#4 Posted : 13 August 2013 22:27:39(UTC)
thealien666
My father has a 76515 crane that he controls with a 60652 remote. Everything was working fine with the default value address 71. Suddenly, the hook went down at full speed and everything stopped. The crane lights come on when the crane is powered but the remote doesn't control anything on the crane anymore. He has tried a reset of the remote, and re-tried controlling the crane with address 71 but no reaction from the crane.
Is there a way to reset the crane itself ?
Thank you for any info.
#5 Posted : 14 August 2013 19:35:09(UTC)
To me, it sounds like a blown decoder...
Does your father have a CS1, CS2, EcoS or an Intellibox?
Then you can try to read the decoder address on the programming track to see if it responds at all...
Offline thealien666
#6 Posted : 15 August 2013 04:22:46(UTC)
thealien666
No unfortunately. He only has the 60652 remote control that he uses exclusively for the crane, as it is the only Marklin product he has on his layout.
The crane is out of warranty, so we took it appart to check all the connections of the daughter board decoder, wires, and if motors were turning freely by hand. Nothing jammed, nothing disconnected, nothing physically broken. So we came to the same conclusion as you: busted decoder.
Pretty frustrating for a $400 crane.
He will surely never buy another Marklin product again... Poor quality electronics.
Anyway, thanks for your valuable opinion and suggestions, it's greatly appreciated ! :-)
#7 Posted : 15 August 2013 09:21:39(UTC)
It's a harsh call to judge the quality of a brand on the basis of one blown decoder, in an item which is not even within the core range of the manufacturer.
Unfortunately it is not possible to guarantee reliability in electronic components. Out of box failures are very common, and even having the item working for a year or two does not mean that it will continue to do so indefinitely.
Offline thealien666
#8 Posted : 15 August 2013 16:35:02(UTC)
thealien666
Perhaps you're right.
But maybe if the crane didn't cost so much (with the additional cost of buying a remote control just for it because Marklin doesn't supply even a very basic one with it to control it) my father would take his loss, and simply accept the fact that he's unlucky.
Anyway, advice to anyone looking to buy this 76515 crane: be prepared to loose a lot of money if yours should eventually fail too, outside the warranty of course.
(Unfortunately no other company makes such a detailed operational crane. And my father, living in north america, doesn't have anything else Marklin so that's why he had to buy a dedicated remote control just for it)
Offline AshleyH
#9 Posted : 15 August 2013 17:14:54(UTC)
AshleyH
I think you will find that Marklin will repair the crane, so it will not be a total loss.
Remember that the warranty is 2 years on Marklin items.
Initially try the dealer you bought the crane from, then Walthers, then Marklin Service Dept in Goppingen.
To the best if my knowledge, Marklin will normally repair anything for a fairly reasonable fee.
Best Regards
Ashley
Offline AshleyH
#10 Posted : 15 August 2013 17:18:53(UTC)
AshleyH
Of course, there is a possibility that it is the 60652 or it's control box 60113 that has failed.
As you are only using those for the crane, the fault could lie there, and be cheaper to solve.
Again, a visit to the supplying dealer with all 3 Items would be very helpful I think.
This page was generated in 0.782 seconds.
