Offline Janne75
#1 Posted : 21 June 2013 17:07:53(UTC)
Janne75
I just tried to power this analog 2-rail Lima NSB electric loco from analog AC Märklin catenary. This motor is DC one if I have understood right? Confused
I just thought that I will get it going, but no success... Only smoke from powered pantograph! Scared
As I don't understand anything about these Lima 2-rail locos this is not a surprise. I wired first other motor terminal with a wire and connected other end of that wire to upper part of the pantograph. Upper part is metal and lower part is plastic. I did not have a clue which motor terminal is + and which is - I just wired first the left one. Results = nothing else happened than slight smoke between pantograph and catenary. Then I tried to connect the right side motor terminal and there was some noises from motor, but it did not run... And smoke was coming again between pantograph and catenary. The power was supplied only for a couple of seconds so I think that nothing was damaged.
Are these "results" caused because of analog DC motor supplied with analog AC current? Is the only way to get it running to install a digital decoder suitable for DC motors and install a slider (pick-up shoe) under it? I would like to power this one from analog AC catenary and not install a slider under it, so if someone knows how to do it please let me know.
Thanks in advance!
PS. I'm sorry that this topic has Lima loco and not Märklin as this is Märklin forum...RollEyes
Janne
Offline rbw993
#2 Posted : 21 June 2013 18:00:15(UTC)
rbw993
You have been a member since:: 19/08/2008(UTC)
Janne,
Sounds like you might have created a dead short on the first attempt. You must make sure that the motor is fully isolated electrically from the frame. And no you can't run a DC motor off analogue AC current. You will need either a decoder or a bridge rectifier for the motor. Problem with a the bridge rectifier is that the loco will only run in one direction.
Roger
#3 Posted : 21 June 2013 18:40:11(UTC)
With a suitable decoder (for DC motors with support for analogue AC operation), you can run the loco from the catenary.
AC fed to a DC motor causes the motor to change direction 100 or 120 times a second with the changes of polarity. This way you can get noise and smoke, but no smooth running.
#4 Posted : 21 June 2013 20:02:59(UTC)
I at first glance thought you intended to power the Maerklin catenary with DC power. This would be the easiest solution. You can power your Maerklin AC loks from the rails and power the DC electrics from the catenary.
I do fear that you may have burned out your locomotive by powering it using an AC transformer. I would recommend you check the wires and test it using a DC transformer to make sure it is still working.
Offline Janne75
#5 Posted : 21 June 2013 22:12:01(UTC)
Janne75
What decoder do you recommend for this kind of loco? Is there some decoder that works without need to do changes to this DC motor? No, I want to power my analog AC electric locos from the catenary and also this DC motored NSB Lima loco.
I want to get Digital signals with more reliable route = tracks. I don't need to be able to run any analog steam or diesel locos at my C-track Digital layout, but it is interesting to have AC powered analog catenary to supply power to analog electric AC locos.
My turnout Digital decoders are connected to tracks also and my CS2 is feeding current to locos and turnout motors/lanterns. Then 6647 analog AC transformer supplies power to the catenary. I have a separate 6002 trafo for layout lights. Then a different transformer for Märklin my World series signals. These signals are not connected to track power as the red wires are not connected. They are only for looks and I run my trains according to these signals manually.
Lima NSB pantograph is maybe not the best type to use with Märklin catenary as they are narrower than Märklin pantographs. It looks like that they could be run off the catenary wires if catenary wires are not very well alligned. What is the right position to hang catenary wires to the masts horisontally? Or is the slight movement of wires required or should they be attached tightly to the mast arms? Confused
I'm sorry for these stupid questions, but I'm a newbie with catenary. Blushing I think that when there is a full mainline route with catenary then it is more "tight" and at the moment when there is only a few masts and wires test section it is more "loose" wires as the ends are still open. I'm sorry for my bad English, but I hope that you will understand what I meant in this text... RollEyes
Janne
#6 Posted : 21 June 2013 22:20:58(UTC)
I don't have any Lima locos.
Changes to the motor are not required. But if the motor draws a huge current you will need a decoder that is strong enough (this is a problem with some older Roco models).
If you take a decoder with overload protection, no damage should occur if motor current is too high for the decoder.
I like ESU decoders, you don't. The mLD should also work.
This page was generated in 0.350 seconds.
