Offline Larry
#1 Posted : 09 May 2013 22:18:58(UTC)
Larry
My plan is to build station tracks and platforms under a glass-like housing to fit on 4 by 8 foot platform to park a number of train sets. I envision it being something like those at the Köln Hauptbahnhof but the ceiling would be far more simple. My belief is that the train sets would be better protected from dust, etc., having a cover over them but still be visible and easily accessible. Coming from my main layout and leading to the station (really a yard) I am going to add several bridges linked together to roughly model those over the Rhein River leading up to the tracks/platform at the Köln Hauptbahnhof.
There does not seem to be anything from Faller, Vollmer, etc., that would be helpful and currently available.
Does anyone know of anything from any manufacturer to help create the above even if it means buying a number of plastic kits?
Thanks so much!
Larry
#2 Posted : 09 May 2013 23:57:51(UTC)
Hi Larry,
One of the best I have seen advertised, is the Grand Gare station from Jouef.
This was produced in the 1970s, but are still available on ebay.fr, either in kit form or made up.
The nice thing is, the platforms, canopy and other appendages, were in modules, so you could buy as many as you needed.
One example is Item #360650607160, for sale now on eBay.
Another possibility is the Hornby Dublo version produced in the 1950s, but is rarely available, and probably way more expensive.
See item #181135535581 on eBay.
#3 Posted : 10 May 2013 00:14:36(UTC)
Dear Larry,
Another solution would be the 00 scale large overall roof card kit from Scalescenes: http://www.scalescenes.c...005a-Large-Overall-Roof. I used the kit - adjusting it to my needs - on my own layout. However, I did not dare to follow the instructions to print on transparent foil, which requires an enduring printer...
Cheers - Ak
Offline Larry
#4 Posted : 10 May 2013 02:57:13(UTC)
Larry
Kimball and Ak,
Thanks for your great ideas. The kits from Jouef, Hornby and Scalescenes all sound great. I did not know any of them existed, so thank you.
The idea of making a train station/shed out of cardboard is really enticing. I looked at making the station/yard from plastic but there seemed to be no curved pieces that would be needed for the roof.
Since this 4x8 area would be connected by bridges and to the side of the main layout the paper might look realistic from this distance.
Use of paper is intriguing. Do either of you know if many have used such with Marklin layouts? It seems to be gaining popularity in the US with crafts but the UK seems to be the most advanced from what I have gathered in Google searches.
I did find some amazing stuff. One site has all kinds of structures from Disney:
http://www.disneyexperience.com/models/?page=1
Thanks again!
thanks 1 user liked this useful post by Larry
#5 Posted : 10 May 2013 03:09:31(UTC)
Larry, you could take a look at the Faller 120199 and 120180 covered platforms.
#6 Posted : 10 May 2013 03:11:39(UTC)
Picture of the Joeuf platform Kimball was talking about.
Bigdaddynz attached the following image(s):
#7 Posted : 10 May 2013 10:11:46(UTC)
Hi Larry,
I believe that not many have used paper or cardboard models on Maerklin layouts. I am a heavy user though. When scrolling through the description of my various layouts in this forum, you will hardly find any plastic structure. Most buildings and backdrops are more or less kitbashed paper models. Nowadays, I am mostly using plywood substructures to support the "wallpaper".
For my terminal station hall I had the local copy shop print two versions of a Scalescenes kit on thin cardboard, which I adapted to my needs - spanning four tracks and two platforms - by reducing the roof width from roughly 50 cm to 30 cm and reinforcing the structure with wooden strips and plywood sections. With some dexterity and skills, creating curved sections will be no problem. I attach two photos. The first one shows the plywood reinforced support walls before mounting the roof, and the second one depicts the (almost) final outcome.
Have fun - Ak Smile
P.S. Words to the wise: Do not forget to apply a "paint finish" to avoid fading of colors...
#8 Posted : 10 May 2013 10:42:50(UTC)
In order to view the old Jouef kit more completely, another item available on Ebay.fr is #161018779940. It was sold as a "double possibility", and more platform and roof extension kits were available originally.
You can view this item in your home eBay by typing this number in the search box.
Offline grnwtrs
#9 Posted : 10 May 2013 21:15:36(UTC)
grnwtrs
Larry
Today while perusing new items from my local dealer in Detmold, I saw a couple of Faller kits that mite fit
in with what you want.
Check out Fallers #194119 S Banhof @ 34.79 euro, also kits # 12018, or # 120180
Actually there are probably dozens of kits that could fill your needs.
I am sure there are a lots of different manufacturers of kits that would be fun to consider. BigGrin
thanks 1 user liked this useful post by grnwtrs
Offline Larry
#10 Posted : 13 May 2013 13:23:34(UTC)
Larry
Thanks for all the great ideas! Your advice and time is greatly appreciated.
Larry
Offline Mark5
#11 Posted : 13 May 2013 20:59:06(UTC)
Mark5
....[...text...]
Nice work Alsterstreek,
Reminds me a lot of Santa Apolonia Station in Lisbon. Was that in the back of your mind?
- Mark
Offline jcrtrains
#12 Posted : 14 May 2013 00:27:52(UTC)
jcrtrains
Has anyone built anything from the firm Joswood? This year they have announced an absolutely massive structure that can bee seen at the following:
Joswood site
I would like to hear anyone with experience with the firm
thanks 3 users liked this useful post by jcrtrains
#13 Posted : 14 May 2013 03:24:10(UTC)
- Mark
Thanks Mark,
The beautiful lIght blue Lisbon Santa Apolonia terminal building adjacent to the port facilities with the attached coach yard and the large wye connected to the Chelas junction and Oriente station throat? Yes, that was one of the inspirations. Actually, the Joeuf kit would be suitable to recreate the large overall roof. However, rolling stock and fantasy names are more a reminiscence of Northern Germany. E.g., the alias Slumburg-Alltoofar is referring to the Hamburg-Altona terminal in Germany, which used to be a brick building with a station hall before the 1970s refurbishing.
Cheers - Ak Glare
#14 Posted : 14 May 2013 19:48:23(UTC)
I don't know if I would want to build the whole building exterior or do it in such a way where the viewer looks down on the tracks from above as if he was looking down from the roof. This would enable the platforms and other details to be in plain sight and for the viewers and the operator to see the operation of the bahnhof, especially if it is a HBf/Kopf-Bahnhof where locomotives must be detached and the train then leaves in the opposite direction. A through station is easier and may allow for you to install a roof.
Offline jcrtrains
#15 Posted : 07 December 2013 15:36:58(UTC)
jcrtrains
Folks;
Joswood has released more details on thier model of the Leipzeg covered station. It's really pretty incredible and I am thinking of giving it a try. I have the Vollmer station as you can see with my layout pics so this would be a complete replacement.
The following is one of the brochures for it:
Joswood Leipzeg
Does anyone have any experience with this firm?
Offline Danlake
#16 Posted : 07 December 2013 16:47:36(UTC)
Danlake
If the price is not an issue the TRIX kit of Hamburg Dammtor station is spectecular. You could do some kit bashing and install a clear roof instead.
https://www.marklin-user...569_Dammtor-Station.aspx
https://www.marklin-user...r---Era-IV-V-layout.aspx
http://www.ebay.de/sch/i...p;_sacat=0&_from=R40
Brgds - Lasse
Offline biedmatt
#17 Posted : 15 December 2013 18:00:16(UTC)
biedmatt
Well Lasse, I need to thank you for your post. Though I do not believe my wallet would do the same. I first noticed the Dammtor station in the recent Trix N-scale release and though it a shame they did not do it in HO. Your post told me otherwise. I managed to score both parts to the kit plus eight additional Faller kits for some iron bridges and arcade viaducts. Very excited, thanks!
Matt
Era 3
Offline jcrtrains
#18 Posted : 06 June 2014 23:50:59(UTC)
jcrtrains
Well. folks I am boldly going where no man has gone before. Here are some prototype pics; they are getting close to the kit production and mine is on order. My layout will require significant city re-design. I will be doing one half of what is displayed.
Joswood Station
I will keep you all posted.
Offline Shamu
#19 Posted : 07 June 2014 04:11:52(UTC)
Shamu
Holy snapping duck doo................. picture 19 says it all..........
And I thought my 8 x Kibri 39565 Train Shed w/- Platforms and Roof 'BONN' was going to look impressive.
Thats put me in my place........... and made me jealous........ wish I'd never seen it Crying
Offline biedmatt
#20 Posted : 07 June 2014 04:26:13(UTC)
biedmatt
Damn!
Matt
Era 3
Online river6109
#21 Posted : 07 June 2014 07:31:11(UTC)
if the only think you worry about dust, let them get dusty and it puts on a nice natural patina and if dust is the main object a duster always can get rid of dust and it wont cost you € 499.00. I don't do any dusting on my layout, except vacuum cleaning the tracks from time to time and the rest of metal parts gets picked up from magnets, e,.g. Roco telex coupling and a magnet placed underneath a carriage.
Offline GlennM
#22 Posted : 10 June 2014 19:11:16(UTC)
GlennM
Joswood Station
Wow, sounds like a great project, please keep us posted with lots of pictures with commentary.
BR
Glenn
This page was generated in 0.997 seconds.
