Offline Janne75
#1 Posted : 06 April 2013 15:52:11(UTC)
Janne75
Hello all,
Today I did a list of my Delta and Digital locos to see which addresses from 1-80 are still free and which are having two or more other than mfx locos. All went well until again I had to try to change digital address of an ESU Lokpilot decoder. Decoder address was 64 before I started. I put my CS2 60214 track current supply to programming track socket. I used POM method to change the address to 21. Everything went well except that now my CS 2 dont run this loco with address 64 or 21... But again my good old Control Unit 6021 runs it just like it should with the same address 21... Why? Is there some hidden second address for CS2? Reboot of CS2 wont help and I have put the track current socket back to normal track connection.
There is always same kind of problems with CS 2 and ESU, but with CU 6021 there is no problem at all. If these nightmares continues with ESU's I will soon sell these "shit" away and buy only Märklin decoders or locos equipped with them Mad !
What can I do to be able to run that loco with the address I want with my CS 2 which is my main controller? Control Unit 6021 is used for lower tracks at the moment but will be replaced with CS 2 when my upper and lower tracks are connected later.
Angry Janne from Finland Wink
Edited by user 06 April 2013 23:36:26(UTC)  | Reason: Not specified
#2 Posted : 06 April 2013 16:16:00(UTC)
Could it be you have to entries for address 21 in the CS2? If one says STOP and the other says GO loco will not do what it's supposed to do (we had this type of problem a few times at club meeting using the CS2).
How did you change address? Using the address field or CV programming?
Loco works with CU 6021, so address was changed. Delete the loco from the CS2 and create a new loco with address 21 (that's what I would do).
BTW: I'm trying to get rid of mfx decoders, with DCC decoders I have less problems by far.
Offline Janne75
#3 Posted : 06 April 2013 16:20:22(UTC)
Janne75
Hello again,
My Finnish temperament was shown again... Blushing
The "problem" is solved. I changed the address temporarily to 22 ONLY at the settings page and then back to the desired 21. CS2 in program track mode.
I found this info from Tom's (H0) recent post to me...
Edit: Thanks again Tom! There was not another loco with address 21, but that was a good hint. I was again messing things in POM and CV list. I found out that if the address was changed only at POM then it also had to be changed under PRG CV site. The main problem with me LOL and ESU decoders is that I dont remember how I should change the address of them. Now I will change the address of another ESU loco. Lets see how it goes BigGrin .
Janne
Offline RUBEN SPAIN
#4 Posted : 06 April 2013 16:27:03(UTC)
RUBEN SPAIN
Hello all,
Please, do not worry. I think that ESU decoders are better than Marklin decoders and you should not to have problems with it.
Could you tell me the following?
1. What is the software version of you CS2?
2. What is the protocol you used with this ESU decoder? It is in DCC or motorola?
3. If you use the Programming Track. Why did you use the POM way to writing decoders? This method is only for writing Cvs in the main track. I do not do this ever. It is better to do using the programming track method.
4. Could you read the address of the decoder with the CS2? In the programming track please.
5. Could you please tell me if you can read the CV1 of this decoder with the CS2? You must entry in the CV menu for this decoder. Remember, put it in the programming track.
thanks 1 user liked this useful post by RUBEN SPAIN
Offline Janne75
#5 Posted : 06 April 2013 17:05:33(UTC)
Janne75
Thanks to both of You from very fast help!
My CS 2 SW version is 2.0.1 (0) and the loco is created as DCC loco. I did not remember that POM should only be used at main track and not programming track. The CV1 could be read and it is now 21. In some of my other ESU locos that CV1 is not the same as the decoders "usable" address with say Control Unit. Like Tom has wrote before the loco address should only be changed from loco settings page and not POM or CV pages. I am really glad that I was able to get it running now also with my CS2.
So I will keep also my ESU locos and not sell the "shit" away... =)
Janne
Offline Janne75
#6 Posted : 06 April 2013 18:27:02(UTC)
Janne75
An update. That other ESU loco address change went ok from 60 => 27. In that locos CV1 there was and still is value 3 (primary address).
I have also an 3021 V200 006 that has a programmable decoder. If it is ESU or is not I dont know? It has a address 69 now, but I can not change it's address like I did with the other ESU and it dont react to Märklin programming method with those lights blinking in different frequency. But the loco does give it's "feedback sound" when I try to program it's address the "ESU way". It must be left to this address 69 then. There is no real problem with this as I can change that other loco with same address with it's 8 dip-switches. RollEyes
Janne
#7 Posted : 06 April 2013 19:16:11(UTC)
The address is determined by CVs 1, 18, 19, and 29. Another reason not to change the address from the CV page.
I presume that long addresses are activated in CV 29 and address is set in CVs 18 and 19.
Could be Uhlenbrock or Tams (or even another brand). You should be able to change the address with the CU 6021. If you want to change it, please show pictures of the decoder.
Offline RUBEN SPAIN
#8 Posted : 06 April 2013 21:11:30(UTC)
RUBEN SPAIN
Don´t worry.
You can change address using CVs page, changing CV1, without any problem. But only if you use short address. If you use long address it is better to make it using the main locomotive setup page because there is more Cvs you need to change and this way is faster and easiest.
But I think you should update your CS2 to 3.0.1. I have a CS2 60214 with 4,33 hardware.
My CS2 works better reading and writing CVs in DCC decoder since I updated.
So connect your CS2 to Internet and press update.
Offline Janne75
#9 Posted : 06 April 2013 21:22:31(UTC)
Janne75
Thanks Tom,
I quessed right then. So there is more than one CV to determine loco address. I ended the address changing and got many locos to different addresses and now there is only two addresses (8 and 78) that have multiple locos which addresses can not be changed to individual address as these are Delta locos and all Delta addresses are in use.
That 3021 with unknown decoder with address 69 can be left as it is now. Many of my Digital locos have the same address, but it does not matter as there is also mfx locos in these multiple (or even more) with the same address. I have now 13 addresses left free from 1-80 so the next locos will get these ones. Only one ESU loco has an address that is over 80 (86). I try to get my locos within addresses 1-80 to be able to run them easily also with CU 6021.
I started to think that maybe I have soon enough Delta and Digital locos when all addresses are in use... Maybe some older analog 800 series locos then and that's it! RollEyes
Janne
Offline Janne75
#10 Posted : 06 April 2013 21:40:22(UTC)
Janne75
Originally Posted by: RUBEN SPAIN Go to Quoted Post
Don´t worry.
Thanks for information! This explains why I was able to change the address from CV1 only and it worked with CU 6021. I have considered to do the update of my CS2 to newest 3.0.x.x version, but I have read that there has been some problems with it. I dont even have Internet at home, but I can download an update to usb-stick and run the update from that. I have also HW version 4.33 like You. I use my phone here at home. I really should buy an wireless network to our home. These iDevices (iPhone and iPad) gives then also new possibilities to run the locos ThumpUp .
Janne
Offline RUBEN SPAIN
#11 Posted : 06 April 2013 21:46:57(UTC)
RUBEN SPAIN
What I do is make a EXCELL Table with all the Locomotives that I have into the CS2, showing their Decoders, address and Protocol. (DCC MOTOROLA or Mfx)
By this way I can know if I have duplicated addresses or not.
You could have two locomotives with the same address if the protocol is the same. For example, two (or more) DCC locomotives with address 10 or Two (or more) Motorola locomotives with address 18 (taking carefull not to run them at the same time)
But if you have two (or more) locomotives with the same address and different protocol there could be problems controlling them because CS2 does not "loves" two locomotives with the same address in DCC and Motorola.
Offline Janne75
#12 Posted : 06 April 2013 22:24:35(UTC)
Janne75
I should also make an Excel file from my locos like You have done. All my duplicate address locos are either the same protocol or then one or more of them are mfx locos.
That is a good thing to know that I dont use the same address with a DCC and Motorola protocol loco in the future.
PS. I have some mfx locos that dont show up with that mfx icon in my CS2. For example my 37967 Mallet from 2011. I changed this locos address to 67 and everything else is working ok. I wanted to change the address to this 67 as the loco driving number is "5767". Does that CS2 SW update to 3.0.1 help to get the right loco icons when installing a new loco from database? Usually 99% of the time locos get the wrong loco model picture.
Offline RUBEN SPAIN
#13 Posted : 07 April 2013 13:43:09(UTC)
RUBEN SPAIN
Hello
First question:
The mfx locos does not need to use the motorola address. That address is only for use that locomotives only by Motorola protocol. The mfx locomotives registers itself by its own MAC address. It is absolutely different from Motorola basic mode.
You dont have to worry if you have a DCC locomotive with the same address than the motorola basic address of a mfx locomotive.
If your mallet only works in motorola mode and do not show the mfx icon when it is put over the track it means that the decoder is defective.
If you want to be sure make this:
1. Delete the mallet from CS2 database.
2. Try to make a reset to that locomotive with the 6021 (writing 08 into CV 8)
3. Put the locomotive in the programming track of CS2 and wait. If after several seconds the mfx icon does not appear that means this decoder works bad.
This problem occurs me with a BR10. That BR10 worked ok with 6021 in motorola but mfx protocol did not work. Then the shop changed it with another new Br10.
Second question:
Sometimes, when you entry a new locomotive in CS2 database (remember that mfx locomotives registers itself) the CS2 does not assing the right Icon or PHOTO. But you can upload your own photographies for locomotives.
1. Search a photo for the locomotibe using google.
2. Download that photo to your PC
3. Open it with a photo software like Adobe Photoshop
4. Change the dimensions at maximum to 128 X 48 72 ppp
5.Change colour to indexed format
6. Save the file as png format. Do not use caracters as _-*/ etc in the name. Only numbers or letters.
7. Make a folder named icons in a USB pendrive
8. Copy the file to that folder
9. Connect the USB pendrive to CS2
10. Select USB Stick in setup menu
11. Press update.
12. When it finished to will have the photo into CS2
13. Enter into locomotive main config page
14. Change the photo selecting the new you have uploaded.
You can upgrade the software version. The problems with 3.0.1 are minor problems. One is DCC reading has a bug that show wrong ACC delay, Vmin values in the main locomotive setup page, but you can entry manually this values reading the CVs 2 and 3. Some people had problems when they tried to update. The CS2 of that people gets hang with the blank screen but they solved downgrading first the CS2 to 1.6.4 software (using USB pendrive). Then they updated using Internet connection.
As long as I know the updating problems were with CS2 with HW 3.4. All people I know that have HW4.33 did not have problems.
thanks 3 users liked this useful post by RUBEN SPAIN
Offline Janne75
#14 Posted : 07 April 2013 23:08:14(UTC)
Janne75
Thank you very much from good advices. I have to test your method with my 37967 Mallet when I have time for doing that.
I know that loco icon updating thing. I have already updated my CS2 loco icons. I mean that it is odd that when adding a new loco from database there comes different loco icon. Märklin should be more precise with this one as it has not happened once or twice. It happens almost always...
I will consider the CS2 update, but I am not in a hurry with this one as everything else is working like it should. When things work it is not time for update if there is no real advantages from that 3.0.X version for me.
Janne
Offline NZMarklinist
#15 Posted : 08 April 2013 03:34:12(UTC)
NZMarklinist
Janne, Ruben,
Thanks for your postings, it is interesting to read. I presently have a CS1-R (Ecos) and with all my decoder upgrades of non sound or Delta Marklin Loks, I use ESU M4 decoders, now V4, but previously some V3 ones. I do have one a M37900 V290 that has an MSD because they have amplified function outputs on the decoder and I wanted individually operating telex at each end. I'd have to say not one of my favouirite upgrades, but it all works. Cool
I would just like to point out that with M4 or (MFX) I have not experienced any address conflicts. I have kept my old 6021 but do not use it anymore, thought it may be useful for a Xmas tree circle layout, or some such, one day. Unsure
I think Ruben's idea of a spread sheet for all your Loks is a very good one, it can also be used for tracking servicing, and other events or whatever, for them ThumpUp It can also keep a total of their value, great for insurance purposes Scared
As I am a bit of a fan of the MFX+ Cab Control Idea, and have one Lok (Klass 23) and another (BR218) on the way, so I am destined to get a CS2 Scared It seems from what I read that as long as you have a reliable internet connection, that an on line update is the way to go !
Having a CS2 as well, will then make the 6021 totally redundant as I will have the CS1-R for other train operations including my modules Wink
That said I believe a 6021 could be useful for a non communicative decoder by programming the old M/M way !? Unsure so will probably keep my 6021, just in case as the value is so not great anymore Wink
Glen
Auckland NZ
#16 Posted : 08 April 2013 03:51:20(UTC)
NZMarklinist
Janne
Hi Janne,
All the Lok Icons with both Ecos and CS2 are apparently identified by just a number in the decoder, and seeing there are so many icon versions and Controller software versions this is not an exact science. The decoder does not know what the lok looks like that it is installed in, weather it be factory one or otherwise. So the decoder carries a number for the icon, not the actual picture, that saves any hang ups but does give an often unreliable result, untill we have edited it ourselves, but one we all should know how to solve, ie go to the menu and change it or create and download the correct one Wink
However I confess creating new ones is not something I've done as yet due to the lack of photo editing sofware. Anybody have a recommendation for a suitable one for both Ecos and CS2 ?? Smile
Glen
Auckland NZ
#17 Posted : 08 April 2013 09:26:43(UTC)
The CS2 selects the loco symbol based on the name stored in the decoder and the filename of the image. So when a new Rh. 1012 registers, the CS2 may decide to use the image of a DB 101 for it.
When you open the properties page, you see three question marks as the image (not the automatically selected 101). When you leave the page clicking on OK it keeps the "???" image until you select a suitable image.
With mfx there are no address conflicts if they do not forget to set unique serial numbers in the decoders (I had two decoders without serial numbers that were causing various problems, but Märklin replaced them free of charge (one loco was already out of warranty)).
The MM address of mfx locos is ignored while they run on mfx.
Janne uses mfx/DCC/MM on one part of the layout and MM only on another part, so every loco must have a unique MM address in the range 01 through 80 and he cannot disable MM with his DCC/MM decoders.
This page was generated in 0.522 seconds.
