Offline go-2004
#1 Posted : 12 April 2005 12:15:49(UTC)
go-2004
Hello, this is mt first post! Can anyone help me with a wiring diagram for a Marklin 3014 electric loco. It has a serious electrical fault. With the lococ on the test bed and transformer turned on, the motor decide to glow just behind the motor plate near the brushes. I have thoroughly cleaned inside the motor. Help would be appreciated.
Email rjw@ceinternet.com.au
Robert
Offline rschaffr
#2 Posted : 12 April 2005 16:02:47(UTC)
rschaffr
Welcome to the forum, Robert. Can you be more specific as to exactly where the glowing is? Is it on the motor plate or the field coil behind it?
-Ron
#3 Posted : 12 April 2005 21:57:43(UTC)
Views messages in topic : 31,695
Welcome to the forum robertwink
Offline bmcrae
#4 Posted : 12 April 2005 23:31:37(UTC)
bmcrae
Greetings Robert and welcome! Smile
Offline Peter Neumann
#5 Posted : 13 April 2005 07:10:54(UTC)
Peter Neumann
Welcome to the forum.
Unless I remember it incorrectly, the light bulbs and holders of the 3014 RET800 have to be secured in place on both ends of the engine (front and rear) otherwise the flat bulb flanges that touch the center of the back of the bulb to provide power (+ voltage) touch the body (- voltage) of the engine instead. The short may appear elsewhere, like through the brushes. If you have the light bulbs in place properly, then this wouldn't be the cause.
Hope this helps.
Peter Neumann
#6 Posted : 13 April 2005 15:24:26(UTC)
Hi Robert, welcome to The Forum Smile
Offline go-2004
#7 Posted : 14 April 2005 01:29:07(UTC)
go-2004
Thankyou all for the welcome.
The test was carried out with body and light bulbs removed and on a test bed. Initially it would function in one direction and short in the reverse direction, then after a 20 minute period of trying to discover the fault, the lococ decides to short in both forward or reverse positions. the actual glowing appears to occur at the point of contact of the brushes on the plate on the field coil or is this the armature?(the part that turns). Not actually on the motor plate. Sorry for my ignorance.
Robert
Offline Hoffmann
#8 Posted : 14 April 2005 02:12:50(UTC)
Hoffmann
Hello Robert,
Welcome, Your Armature (the part which rotates)is probably shorting out between the copper segments. Take the armature and clean between the segments with a small brush and use Alcohol (not the stuff you drink please) see if this helps.
Also make sure your drive is moving freely ( all those gears)
Martin
marklin-eh
Offline go-2004
#9 Posted : 14 April 2005 14:16:07(UTC)
go-2004
Thanks Martin for the advice, I had a close look at this and it appeared to be clean in between the plates, I have managed to get the loco going. I had completely dismantled and thoroughly cleaned and then oiled the loco, the part I missed was the tiny contacts on the switching unit, cleaned them and now does not miss a beat in either direction.
Thanks again Robert
PS no doubt I will be back with more problems !!!!!!!!!!!!
Offline rschaffr
#10 Posted : 14 April 2005 15:12:42(UTC)
rschaffr
Robert:
Excellent news. Enjoy!
-Ron
Offline HueyCE
#11 Posted : 15 April 2005 08:06:25(UTC)
HueyCE
Robert- Great to see you got your lok fixed, and welcome to the forum.
Ira
This page was generated in 0.595 seconds.
