Offline HARNO
#1 Posted : 11 March 2012 04:33:46(UTC)
HARNO
Views messages in topic : 38
what needs to be done to run Lilliput wagons on Marklin track?
I found a really nice set of Lilliput passenger cars ( Rheingold) and want to run it on Marklin tracks
can anybody tell me
thanks
Offline BR01097
#2 Posted : 11 March 2012 05:49:55(UTC)
BR01097
Liliput H0 will sometimes run fine on Märklin track without alteration, depending upon the model and where it is in the consist. That means: if it is a coach, it may have under-carriage fittings that cannot clear turn-out indicator lamps, or it may be too light to be placed too far ahead in the train, or the flanges on its wheels may not be sufficiently deep and it may derail on curves. Because in 1978 Märklin did not make available Austrian coaches to go with its #3036 ÖBB express locomotive, I bought my first Liliput 1st-class Schürzenwagen and baggage car in Vienna. Märklin curves are tighter than perhaps any other manufacturer, so the movable steps on the coach would hang up in the chassis in curves and derail the truck. Slight modifications or removal of projecting parts may be necessary. None of these reports should discourage you from buying the Liliput line. It is in some ways superior or at least equal to the best European model retailers.
thanks 1 user liked this useful post by BR01097
#3 Posted : 11 March 2012 08:44:04(UTC)
can anybody tell me
thanks
I had the same set, but sold it to a fellow Märklinist after Märklin came out with their metal version.
It ran perfectly on Märklin track after the inner spacing of the wheels was adjusted to the 3-rail spec.
The inner spacing (measured between flanges) for two rail is 14.3 mm, the spec for Märklin is 13.8 mm.
You will need a caliper.
Take the axles off, press the wheels together to 13.8 mm, re-assemble and it will run beautifully!
BTW, this is true for any 2-rail vehicle if you cannot find/get 3-rail replacement axles.
Offline kbvrod
#4 Posted : 11 March 2012 14:42:01(UTC)
kbvrod
thanks 1 user liked this useful post by kbvrod
Offline arconell
#5 Posted : 12 March 2012 14:26:33(UTC)
arconell
Hello Harno,
The set is from Vienna production, art. 820. I´ve got that same set. It runs sort of OK on C-track but not without first curing some problems. Make sure the trucks can turn freely, with some of my coaches I had to scrape off some rough edges on the body-underside where the trucks would move against while running thru curves. The big challenge is getting lighting in the coaches, because the couplers cannot easily be replaced with current conducting ones, in fact they cannot be replaced at all without major surgery to the truck frame.
I have tried the solution with individual pick-up shoes per carriage but there isn´t really room for them, ergo: frequent derailments. I have just ordered a set of 11 mm wheels for the coaches, standard issue is 10 mm, see the link provided by Kevin, in hopes that by lifting them up just by 1 mm, it will take some of the excess pressure off the pick-up shoes. The coaches are very light weight indeed and with all five you will have to run them at relatively slow speeds on curvy layouts and across switches, even after adjusting the wheelset flange spacing on the original wheelsets. Partly also because the flange depth on the original is only 1 mm, M standard is 1,3 mm.
Regards, Robert
Offline HARNO
#6 Posted : 12 March 2012 15:56:28(UTC)
HARNO
Thanks for all the answers.
@ Robert
with the weight i was reading about that. I would probably put some lead ( fishing gear) in the passenger cars if there are some spaces open to make them more heavy.
With the lights i already have an idea ( i saw something from a guy on the internet): Take the pick up shoes off and run small wires from car to car and hook it up to the locomotive via a coupler and connect it to the decoder in the locomotive. I know the locomotive have to stay then with the passenger cars. I hopefully can put it then on a decoder output and might can switch it on and off via the MS or CS. Its kind of all in my head Smile but if i get it to work it is a different page Unsure
but thanks again for the answers
Offline Jeremy Palmer
#7 Posted : 12 March 2012 17:33:45(UTC)
Jeremy Palmer
Barbados
Dumb question department, apologies in arrears, I have admired John Paolo and Mike C's Liliput Domino in their posts
on that subject. The subject in this post - does this affect ALL Liliput AC models or just ones that you wish to CONVERT
to AC??
Jeremy.
Jeremy.
Offline arconell
#8 Posted : 12 March 2012 21:57:25(UTC)
arconell
Hi Jeremy,
Dumb manufacturers rather than dumb questions is more to the point. Lilliput originally was an Austrian manufacturer producing beautifully detailed models but with crappy engineering. No wonder they failed and after a short while being owned by Herpa (German, manufactures miniature cars) they fell into the hands of Bachmann who subsequently closed down everything in Austria and moved development and production to China.
So Vienna production models are generally very good looking, even by today´s standards but unless you do some re-engineering of your own you´re better off keeping them in a showcase. The (early) Chinese Lilliputs are of better quality in that department in that they will run better out of the box but in my experience not for very long... Their latest models have improved in all respects but it is still not prime quality, in terms of materials used, motors, gears, etc. So don´t expect the mileage and heavy use you can get out of most (non-Chinese) Märklin models.
Regards, Robert
thanks 4 users liked this useful post by arconell
Offline kbvrod
#9 Posted : 12 March 2012 22:03:02(UTC)
kbvrod
Bingo.
Dr D(want to talk about a BR 95???)
Offline drstapes
#10 Posted : 13 March 2012 00:52:48(UTC)
drstapes
can anybody tell me
thanks
what a useful tip. thanks
geoff
Geoff (UK)
thanks 1 user liked this useful post by drstapes
Offline Elukka
#11 Posted : 13 March 2012 06:43:15(UTC)
Elukka
I'm a bit confused how that works. Isn't the axle a solid piece of metal between two solid wheels? How can they be pressed together? And will it still fit in the wheel holders?
Offline HARNO
#12 Posted : 14 March 2012 02:42:06(UTC)
HARNO
Elukka
on the Lilliput you probably have axles they made for the two rail system not as marklin for a three rail system.
So you have on the two rail system axles they isolated with a ring and so you can press on them and make them smaller and they would fit on marklin. I think i was reading that it would fit that way only good on the C-track for Marklin and all other tracks ( K &M track for Marklin) need new axles.
I hope i explained it right
File Attachment(s):
2012-03-13_213458 radsatz.pdf (24kb) downloaded 57 time(s).
thanks 1 user liked this useful post by HARNO
Offline arconell
#13 Posted : 15 March 2012 03:38:07(UTC)
arconell
Meanwhile I put the 11 mm AC wheelsets on my Lilliput Rheingold set and guess what, it works like a dream! Remember, I´ve got pick-up shoes and mass contacts on every coach (5 in total). Original wheel rim was 10 mm, causing the pick-up shoes to bottom out on the elevated center studs in the switches. The 11 mm wheelsets have cured that problem completely and as an added advantage, friction is reduced to such an extent that even my little T12 class steamer can pull the set of 5 coaches along my entire layout. The new wheelsets came from
http://www.das-service.d...llbahn-radsatz/index.php
See also Kevin´s reference in this thread.
As compared to the original old Lilliput (DC) wheels the finish is also much smoother. Less noise, less friction, more pulling power.
Best regards, Robert
thanks 1 user liked this useful post by arconell
Offline mrmarklin
#14 Posted : 25 March 2012 04:26:49(UTC)
mrmarklin
Just ordered my first ever Lilliput set, and am not encouraged by the remarks! I did ask my dealer to change the wheelsets for 3 rail, and hopefully this can solve some of the running problems.
#15 Posted : 25 March 2012 07:04:42(UTC)
I have had numerous Liliput freight cars and passenger coaches in my collection for many years now. I have not had any major problems with rolling stock from the original Vienna productions, especially as most of the items were delivered with AC wheel sets (provided by the dealers). This includes 30cm DB, FS and SBB passenger coaches, SBB Swiss Express EWIII coaches, SBB Light Steel coaches and various international freight cars.
I have a few Liliput Herpa models. For example, this generation of SBB Light Steel coaches included modified coupling shaft designs, which were often problematic. Others were trouble-free.
I also have a number of Liliput-Bachmann (China) models. The most recent generation of items do suffer from some design and part related problems. Once again, using the SBB Light Steel coaches as an example, Bachmann has improved on the Herpa design for the coupling shafts, but the coaches lack a spacer which would allow the bogies to operate without rubbing against the coach bottom and the coupling shaft. It appears that the coach was designed to include such a part, but I have not seen a single coach that came with this piece. The result is that the wheels rub against the chassis and the coupling mechanism when entering or leaving an inclined or declined area of track.
As far as other models, I was pleased with the SBB EW I coaches in Era III appearance as these coaches have not previously been available in large production. These coaches fit in nicely with the Light Steel coaches. On the downside, it would appear that this coaches are copied from the design of the earlier Lima models. The design of certain model features very closely parallel that of the Lima design. To confirm this, even a little slot in the rear (inside) of bogie design is included. The Lima model had this for a purpose. The Liliput model reproduces this feature but without the purpose.
I was impressed with the SBB Flirt and NPZ Domino trainsets. The first Flirt model had issues with light shining through the white body of the trainset. Using a more solid white dye in the molding process would have resolved this issue, and Bachmann has corrected this on subsequent models. On the NPZ Domino, there have been certain improvements, but Bachmann needs to improve quality and finish to attain the level of Roco, LSM, ACME. A $300 model that lasts 5 minutes is not something that will bring modellers back to your doors for future purchases.
As far as older models like the Rheingold, the 1950s skirted coaches and such, these models were the flagship models of Liliput production at that time and were nicely rendered. I would make sure that the coupling design allows for smooth operation and install AC wheel sets for operation on Maerklin tracks. This will ensure that the models will run smoothly on those layouts. Modellers operating Maerklin M Track should be aware that longer coaches may come into contact with the turnout lanterns and should only be used on tracks that do not involve turning on the inner radii of such switch tracks. These coaches should have no problem operating on R2 and can be used on R1 if turnout lanterns are removed.
This page was generated in 0.420 seconds.
