Offline ac jacko
#1 Posted : 18 June 2011 04:42:10(UTC)
ac jacko
I have been looking at lokshop and confued with all different Seuthe numbers for my loco's.
I am looking at smoke units for my loco's and what Seuthe is the model requred. Can anyone assist which is the models required fo:
3003
3048
3084
3085
3102
3318
Now I am looking at converting to Loksound V4 and going digital so will these smoke units still be ok?
I have been bombarding poor john (rivers) from perth, so I am looking at giving hm a break from my newbie queries
cheers Dale
Edited by user 18 June 2011 10:34:09(UTC)  | Reason: Not specified
#2 Posted : 18 June 2011 08:45:07(UTC)
Hi, Jacko,
There are two different shapes of smoke generators for Märklin locos: big (M* #7226, Seute #10) and small (M* #72270, Seuthe #20). These are for analogue voltage.
For digital voltage there is the same shape with higher voltage: big Seuthe #11 and small Seuthe #24.
So you'll need either Seuthe #10 or #20 for your locos as they are now.
3003: not prepared for smoke generator
3048: #10
3084: #10
3085: #10
3012: ???
3318: #20
(All information is supplied without guarantee.)
That depends how they get wired. Normally smoke generator will be controlled by the decoder and you'll need the analogue type even for digital locos. If the smoke generator is not wired to the decoder, you'll need the digital type.
Offline ac jacko
#3 Posted : 18 June 2011 10:36:50(UTC)
ac jacko
Thanks very Tom, I edited my original post as Loco is 3102 so if you can assist much obliged
cheers
#4 Posted : 18 June 2011 11:12:29(UTC)
Dale,
the same as 3085 but the 3102 takes 2 smoke units.
With the 3003, Seuthe make some generators for locos with plastic housing.
I've used some of these smoke generators, although the smoke stack on a 3003 is just enough to squeeze one of the smoke generators through but if you fail to hit the dead centre when drilling (hand drilling prefered, as the drill bit heat is too much when using an electric drill and it deforms the plastic or could actually be ripped off and gets stucked to the drill bit).
Somewhere I've shown photos of locos being converted with smoke generators.
#5 Posted : 18 June 2011 11:32:54(UTC)
Here's a reference chart I picked up from where I don't know, that shows all the Seuthe smoke unit types.
Bigdaddynz attached the following image(s):
Offline ac jacko
#6 Posted : 18 June 2011 12:26:42(UTC)
ac jacko
Thanks gents ,much obliged
Offline Joseph Meiring
#7 Posted : 19 June 2011 20:19:54(UTC)
Joseph Meiring
thanks David - Have you heard if one type is "better" (more efficient), than the other?
I've been told the 7226 is more efficient than the 72270, and gives less trouble?....or is this just "urban legend"??
Joe
#8 Posted : 19 June 2011 20:34:56(UTC)
This is my experience, too.
But since they have different sizes, it's a case of take it or leave it.
7226 can be installed without removing the shell of the loco.
BTW: the Seuthe kits come with a syringe that can be used to insert the smoke fluid into the generator.
I recommend to get at lest one Seuthe kit to get hold of such a syringe.
#9 Posted : 19 June 2011 20:42:17(UTC)
Joseph Meiring
Thanx for that Tom - I certainly need that syringe - what a mess to get oil into my BR23!! That 50ml bottle of 02420 fluid is going down FAST!!So what Seuthe kits will I need for my 39230 and for my older 3309?
Joe
#10 Posted : 19 June 2011 21:16:06(UTC)
Seuthe #10 or Märklin #7226.
Seuthe #E10 is the smoke generator without accessories (but only few dealers have them listed).
#11 Posted : 19 June 2011 21:30:59(UTC)
Joseph Meiring
Thanx again Tom - Lokshop has the Seuthe #10 in stock for 14 Euro. I will put in my order for the #10 when I order my 39302 blue ML 2200 CC
Joe
#12 Posted : 19 June 2011 22:18:59(UTC)
Agreed! Definitely well worth the trouble. ThumpUp
This page was generated in 0.502 seconds.
