Offline fatso
#1 Posted : 20 September 2009 02:14:53(UTC)
fatso
Hi guy"s just come to find a set of left z gauge point where the plastic V is loks like to strip of metal are in place im missing one part the points are not working right and the point are all ballast into place can take pic but have probs posting it.mike
Beware MS suffer spelling and grammar not always right or near but try my best
Always looking on the bright side of life
Offline ozzman
#2 Posted : 20 September 2009 16:01:57(UTC)
ozzman
Mike, it doesn't sound good, if I read you right. You might be better off replacing the turnouts altogether.
Gary
Z Scale
Offline ztrack
#3 Posted : 21 September 2009 17:25:51(UTC)
ztrack
I would test the turnout. I have had these metal plates fall off before, but was still able to use the turnout without difficulty. Note, if the plate does come loose (typically one end), it is possible to reattach. I have even used a little CA glue to hold in place. But most of the time, I just remove it. But again, test run and make sure the trains go through okay first before you scrap a turnout. It you do decide to replace it, save the turnout for a branch line or siding.
Rob
Ztrack Magazine Ltd.
The Magazine For Z Scale Model Railroading.
www.ztrack.com
www.ztrackcenter.com
www.ztrackresale.com
This page was generated in 0.181 seconds.
