Offline Graham HO
#1 Posted : 18 August 2009 02:02:57(UTC)
Graham HO
Views messages in topic : 126
Hi - are there any members that have had persoal experience or can advise on programming a Uhl. 76200 lok decoder with M.6021 controller. I need to reduce both the F3 Rangier (switching) speed and maximum speed on a recent conversion. Many thanks in advance.
Offline efel
#2 Posted : 18 August 2009 02:44:20(UTC)
efel
Seen on UHL site:
Programming with a Märklin Center
With a Märklin center all CV's can be programmed, but not read.
1. Switch Center off and on.
2. Select the address of the decoder and switch the light on.
3. Operate the direction change-over 5 times in quick succession with the stationary locomotive (speed
step 0), until the light turns off.
4. Set the speed controller to "zero". The rear light now flashes slowly 4 times.
5. Enter the number of the CV that is to be programmed.
6. Briefly operate the direction change-over. The rear light flashes fast 4 times.
7. Enter the desired value for CV e.g. a locomotive address.
8. Briefly operate the direction change-over. The rear light flashes slowly 4 times.
If further CV's are to be programmed repeat points 5-8.
If programming is to be terminated switch the center to "STOP" or set the address to "80" and briefly
Since a Motorola digital center from Märklin only accepts inputs of 01 to 80, the value "0" must be entered
by entering the address as "80".
NB: "Marklin center" means 6021
Fred
#3 Posted : 18 August 2009 02:47:42(UTC)
I programmed an Uhlenbrock decoder a few months ago (wasn't a 76200).
The loco starts flashing lights when you release the reversing position.
That's unlike ESU style decoders where you hold the reversing position until the loco starts flashing.
On the 3rd or 4th attempt I managed to change the address.
Grrrr - sooner or later all my Uhlenbrock decoders will get a fine place on the book shelf ...
Just in case you don't have the manual: look here:
http://uhlenbrock.de/GER...64-01B.apd/Bes76200e.pdf
This page was generated in 0.475 seconds.
