Offline atilla
#1 Posted : 19 March 2009 15:08:32(UTC)
atilla
I was reading a very interesting topic about pantographs and catenary in which one of the posts mentioned disasters on the layout involving the pantograph of a speeding train getting caught on the catenary and the subsequent mess. These discussions made me wonder if this sort of thing happens on the prototypes? I assume that things must be designed to preserve the overhead wires at the the expense of the overhead wires; but, what are all the real world considerations?
Offline spitzenklasse
#2 Posted : 19 March 2009 15:13:35(UTC)
spitzenklasse
Greetings Atilla! I.M.H.O., well yes speed kills? I've had a couple mishaps. $18 to replace a panto on my br 152 100 jare DB museum Loco.
Offline Ranjit
#3 Posted : 19 March 2009 15:55:26(UTC)
Ranjit
Shouldn't this topic be moved to "Prototypes"?
Ranjit
#Get Vaccinated
Offline hasan
#4 Posted : 19 March 2009 16:02:20(UTC)
hasan
Does this answer to your question? [:0]
Bye,
Offline supermoee
#5 Posted : 19 March 2009 16:03:44(UTC)
supermoee
Hello Attila,
these accidents happened often at the beginning of high speed traffic in Italy.
In Italy they run DC 3000V power supply, so to transmit high power a big section of the catenary is needed because of the low voltage and high current.
So the catenary was very heavy and it happened often, that the ETR500 high speed train took the catenary with him because of resonance of the catenary.
I tried to stay for hours in such a train without airconditioning and with non opening windows, waiting that a diesel loco come to tow the train to the next station.
rgds
Stephan
Offline atilla
#6 Posted : 19 March 2009 16:42:55(UTC)
atilla
What a good YouTube! I suppose that is the result of wear on the pantograph; but, I guess it could as easily be the other way round, where wear on the catenary causes premature failure on the pantograph.
When I was a kid, we used to put nails on the tracks (low speed feeder line for the local tire factory). These flattened objects were great prizes in grade school. I'm pretty sure this would not have been the thing to do on a high speed line.
It sets me to wondering, I've seen tennis shoes tied together by their laces and tossed into the air so that they catch on phone or power lines. I would guess that this action would be very bad on catenary and heavily discouraged in countries where catenary runs everywhere. But, it would make a great scene on a layout for the catenary repair car, "A group of workmen on top of the platform removing a pair of tennis shoes dangling from the wires."
Offline atilla
#7 Posted : 19 March 2009 16:45:50(UTC)
atilla
[size=1" face="Verdana" id="quote]quote:Originally posted by Ranjit
<br />Shouldn't this topic be moved to "Prototypes"?
Ranjit
I guess that I was conflicted about where to place it. I thought it was of equal interest that it happened on the layout; so, I put it here.
Offline perz
#8 Posted : 19 March 2009 20:47:10(UTC)
perz
Last autumn my daughter was delayed for several hours on a ride with the Swedish "high speed" train X2000 because of such a pantograph accident. So it happens in Sweden too.
#9 Posted : 19 March 2009 21:00:59(UTC)
And I moved it here... Smile
Offline Ranjit
#10 Posted : 19 March 2009 21:17:11(UTC)
Ranjit
Thank you, Juhan.
Ranjit
#Get Vaccinated
#11 Posted : 20 March 2009 02:17:35(UTC)
One note about the BR 103.
For quite a few years, the OBB (Austria) refused to grant permission for DB Loks of this class equipped with the original 'scissors" pantographs to operate on it's network. It was only later once the pantographs had been changed that the DB could operate these Loks on trains to Vienna, Innsbruck and other destinations.
In many such accidents, especially at high speed, the catenary can be damaged for several kilometres, requiring significant repairs before the train (and the line) can be put back into normal service.
Modern pantographs are equipped with devices to minimize sway and optimize contact between the wiper and the catenary wire. They are also designed to absorb most of the damage to protect the line installations as much as possible.
#12 Posted : 20 March 2009 02:22:48(UTC)
To: Attila, Ranjit, Juhan and all:
This thread was moved to the Prototype section. The question was inspired by problems on the layout (model trains). As this topic covers both model RR and prototype, I think that it could be classified as pertinent to model RR.
At what point does a thread that can have model RR implications get moved and what would have to be different for it to qualify to remain in it's original theme?
Offline atilla
#13 Posted : 20 March 2009 19:11:32(UTC)
atilla
<br />To: Attila, Ranjit, Juhan and all:
Mike, it really doesn't matter to me. After I do may daily "job hunt", I go through the forums here. I only care that I can find the thread again. Like I said, orginally, I was conflicted myself about where to put the question; but, it is centering more on prototype behavior than model behavior and does make sense here.
Of course, I could ask the question? Are there similar problems with certain types of pantographs causing catenary problems on the layout?
[}:)][}:)][}:)]biggrin
#14 Posted : 21 March 2009 02:11:13(UTC)
Then, somehow, the magical number 7219 would pop into mind.
With regards to model trains, do you find scissors (diamond) pantos or the single arm ones more reliable in HO, or have you not noticed a difference?
Offline atilla
#15 Posted : 21 March 2009 05:02:55(UTC)
atilla
I have yet to add my first electric loco. I am waiting with bated breath for a 37226 (apparently I'll be waiting until Q3). The pre-order of the gator started me looking at catenary in general. When I look through the pictures of the more modern trains, they seem to have the single arm design. I a guessing that there is some advantage. Wiki seems to hint that they are more responsive. I can't think of any advantage one way or the other in a scale model environment. One of the reasons I'm asking the questions is to leverage the knowledge of people here.
Is 7219 the replacement part number for a single arm Marklin pantograph? Are they more vulnerable than the double armed ones?
#16 Posted : 21 March 2009 13:53:17(UTC)
I have yet to put up my catenary, but I am toying with the idea of using a technique I saw described in a book. The idea is to limit the travel of the pantograph with a fine thread or wire, so that it does not quite reach the actual catenary wire. This looks quite convincing, but protects it from damage.
Offline atilla
#17 Posted : 21 March 2009 15:43:29(UTC)
atilla
One thread that I was reading suggested that you just put up the masts, without putting up the catenary. Also, there was a suggestion to always leave one section free of catenary as putting a loco on the track with the wire in the way could be difficult.
I love this forum. It is a great way to learn all about the little devil that hides in the details. I'm pretty sure that I am ham fisted enough to make plenty of mistakes on my own; but, there is enough wisdom to save me from a lot of mistakes before I stumble through the process.
I find it particularly interesting that the prototypes have many of the same problems. Of course in the case of the prototypes, there are all kinds of implications that stretch from danger to worker to interrupted passenger/freight service and manufacturing of spare parts.
This page was generated in 1.189 seconds.
