Hi Pete.
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Nightowl4933 I suppose it's lke a tree. Easy to say it's a tree - but try explaining how it works!
Exactly. But, as I said, once you understand part of it the rest comes quite easily.
Quote:[size=1" face="Verdana" id="quote]quote:I think I'll order one from Conrad to see how good/easy it is, because as you say - there isn't much to a colour light signal. I just hope I don't have to source other parts elsewhere, such as LED's, but they should come complete. I'll let you know how I get on.
Well, they are cheap enough to risk one. I assume that the LEDs are included. They are in the Semaphore kits.
Quote:[size=1" face="Verdana" id="quote]quote:I'm not sure why the 7244 is only listed in the HO section, but M* themselves told me about using them for the new (current) light signals. It seems they should really be listed under 'All Scales', but there you go! The operating voltage is higher, which is why I bought the 16v transformer, but it looks like V* signals work between 14v and 16v too. They even do their own relays (5551).
Actually, I have had them working at far lower voltages but eventually went to the higher voltage because I was working with several devices switching at once.
Quote:[size=1" face="Verdana" id="quote]quote:Erm, I think it might be a bit early for me - I'm not quite sure what you're trying to show in your diagram, sorry.
I should have done a drawing.
The top line was supposed to show the stop/slow signals and the track, line 2 the rough positions of the distant signals and line 3 was a description. I was going to put it all in one line but it was too long.
Quote:[size=1" face="Verdana" id="quote]quote:My interpretation is:
(Editing your text slightly. Hp0 = stop, 1= go, 2=40kph.)
Hp0/Hp1 (89391) - used as stop/go (red/green) signals at the end of each block (however many there are) and would need a single relay - requires Vr0/Vr1 (from 89380).
89392 - used as entry signals into a station area (or junction) with Hp0/Hp1/Hp2 (stop, go, go slowly - red, green, green/amber) - would need 2 relays and is preceded by Vr0/Vr1/Vr2 (expect clear/stop,slow).
Hp0/Hp1/Hp2 as above + Hp00/Sh1 (89393) - used as an exit signal from a station area with the same as the 89392 but with the added Hp00 (train/loco halt, shunting not permitted) and Sh1 (train halt, shunting permitted). There is no semaphore equivqlint so I use separate shunting signals which are all just left at Sh0 permanently.
Shunting signal would be used to allow a loco to move forward, leaving its train behind, in order to run round the train of go to shed. It does not function in the same way as Hp0 as authority has to be given to proceed, juts as a train cannot leave the station until the all clear is given by, e.g., the guard.
89390 - used as a warning of the next signal status, so if it precedes the 89392 it would show the following:
Vr0 => Hp0
Vr1 => Hp1
Vr2 => Hp2
and similarly if the 89390 precedes the 89391 it should only show Vr0/Vr1.
Quote:[size=1" face="Verdana" id="quote]quote:So, in a nutshell, for every station area I'd need a distant signal, an entry signal and an exit signal, with block signals at every block in between - and these blocks should be at least one and a half times longer than the longest train - with a distance signal if the block is long enough to need one.
That about sums it up.
BTW, you can download the signal book in English from
http://www.lctm.info/Biblioteca/Libros/index.htm . I know it applies to HO but the basic principles are the same as HO analogue except
that the centre 'rail' becomes one of the running rails in Z.
Hope that helps. It's difficult to express in words.
Quote:[size=1" face="Verdana" id="quote]quote:Over the statutory/obligatory/traditional Scottish Hogmanay hangover yet?
Doesn't apply. I do not drink, but I did stay up till 0100 typing messages here. :o)
All the best,
Chris.
PS. Have a look at my latest trackplan. I will give you an idea of how it is all laid out but be aware that there are no approach distant signals.
