Offline graafjp
#1 Posted : 16 December 2009 00:28:39(UTC)
graafjp
I am thinking to build a switchboard with the Uhlenbrock Track Control system.
I would like to connect this to my 6021 via the 6021 loconet adapter.
Unfortunately I cannot find if communication between Loconet and 6021 is in both ways.
I would like to know if I set a switch or signal with memory or keyboard this change in setting is reflected on the Track-control switchboard....
Hopefully there are some people here using the 6021 loconet adapter who can inform me if there is communiction in both ways or only from loconet to 6021.
Jos
Jos
#2 Posted : 16 December 2009 10:08:08(UTC)
Yes, communication is both ways. (Unlike the Sniffer option of the CS1 or 605x interface)
Absoutely no problem with using and programing basic addresses. Some of the more advanced features like route selection may have issues with setup (require an intellibox to play with CVs), but in operation the transmission of accessory switching commands is fine
What you are suggesting is just one more item to "add to the business case" for getting the UB 63820. And, I think, an excellent choice for joining/bridging the Marklin and LocoNet environments
If you were not aware, the Track Control system also has "Throttle" modules and can therefore control Locos. It is just important that any loco address used is de-selected from the 6021.
Note: While the "LocoNet to Mobile Station" adapter enables utilisation of all those extra MSs from startersets over "distance", IT is not bidirectional and will not know if exteranl changes are made to a locomotive it has called up.
Offline graafjp
#3 Posted : 16 December 2009 11:54:49(UTC)
graafjp
Hi Peter,
Thanks for your answer. That's good news!
For programming the switchboard I am planning to use the usb-loconet interface to set things up.
I know there are some limitations but basic switch and signal operation should suffice for me. No more remembering which key on which keyboard key to press....
The idea of using the Throttle's is also interesting so I can also add them later.
I'm also planning to experiment with Lissy to control loc functions (sound off when loc is in the invisible part of my layout, etc).
I know it's more expensive to set up those things without a PC but I'm not in a hurry and want to get away from the PC when playing with my model railroad as I am using a PC all day for my work....
Jos
#4 Posted : 16 December 2009 12:14:56(UTC)
I published several articles on the Uhlenbrock Track Control system in our Marklin Club magazine, which was written by one of our members, with some assistance from Clapcott - they did a presentation to the club of this system back in about June this year.
The articles give a general overview of the Uhlenbrock Track Control system.
I could send you a copy if you wish.
Offline graafjp
#5 Posted : 16 December 2009 13:27:14(UTC)
graafjp
Hi David,
If you could send me a copy by e-mail that would be great.
I don't know if my e-mail is visible in my profile so I did sent you an e-mail message a few minutes ago.
Jos
#6 Posted : 16 December 2009 14:44:13(UTC)
Do not plug the loconet adapter in to a 6021 that is turned on, the loconet adapter might be destroyed.
I tried this; but got a new Loconet adapter free of charge from Togcenter Gentofte in Denmark.
Very nice service wink
Can I have a copy of the mail, please.
P.S: I hope this is not one of those "I will send to true Marklin fans, who never said
anything bad about the world greatest model-manufacturer" biggrin biggrin biggrin
Offline graafjp
#7 Posted : 07 January 2010 00:43:17(UTC)
graafjp
Well I have been experimenting with track-control connected to the 6021 with the loconet adapter from Uhlenbrock.
All works well but I am unable to get signal switching working when using a signal with more than 2 aspects.
using the red/green signals is working ok, but when using the marklin new digital signal with attached switching (rangier) signal I am unable to program that I can use all the 4 aspects of this signal. Also using extra buttons for halt/faht/rangierfahrt switching I am unable to getting that at work...
Hopefully someone has some hints because the basic operations are working perfectly and I am starting to like this track-control a lot BigGrin
Jos
#8 Posted : 07 January 2010 01:57:15(UTC)
Jos, your email to me must have got caught up in my ISP's spam filter, so I never got. I have sent you an email via the forum, so can you please reply to that. Cheers.
Sure Per, will send you a copy as well.
#9 Posted : 07 January 2010 08:58:18(UTC)
Per ,
AFAIK there is only one of those persons around. Cursing Cursing Flapper Flapper Flapper
PS: the new Supply of Smilies are great.
NNLove Flapper Flapper Drool Drool
PS:
After that Model was made the then Production Manager realised his/her (or what ever applies) Mistake and destroyed the mold and no further models were made. Which is a big relief to true Marklin Fans but not the rabid Marklin Fan.
Flapper Flapper Flapper Flapper Flapper Flapper Razz
#10 Posted : 07 January 2010 09:31:18(UTC)
You got it Nev!
Copies of articles on their way to Per and Jos.
Offline graafjp
#11 Posted : 07 January 2010 18:11:30(UTC)
graafjp
Bigdaddynz wrote:
You got it Nev!
Got them. Thanks very much.
Jos
#12 Posted : 07 January 2010 18:59:01(UTC)
Got mine too, and had forgot that I asked for them Crying Blushing
This page was generated in 0.523 seconds.
