2 Pages<12
#51 Posted : 08 November 2009 07:52:50(UTC)
The problem is that the train room is located away from the router - hence the use of an on board wireless card in the PC. The PC's original LAN port then connects the ecos via a cat 5/6 cable..
Works great in terms of Windigipet's control of the eCOS...
I am not sure that the switch will help here.. confusedconfused
Offline DasBert33
#52 Posted : 08 November 2009 10:26:05(UTC)
DasBert33
XP has a 'network bridge' function to be able to act as a bridge/gateway. Maybe you can use it between the fixed network adapter and the wireless one. I don't know about IPs though, if they have to be in the same subnet or not. I never succeeded in using that function.
Bert
Offline Fredrik
#53 Posted : 08 November 2009 11:52:14(UTC)
Fredrik
You have been a member since:: 13/07/2004(UTC)
Hi Adrian,
get your self a wireless accesspoint, or a 2:nd router which can act like such an accesspoint, and connect the ECoS to it. Then change the IP-address settings in the WDP-interface settings to the new IP of the ECoS (which is then in the 192.168.1.x range). Then also enter the IP in TouchCab and you're done! biggrin
Fredrik.
WWW: MJ-fjärren
#54 Posted : 08 November 2009 12:58:21(UTC)
Thanks Bert - It worked a treat.. I ended up bridging the network between the lan and the wireless networks on the PC after I set the lan card to a 192.168.1.xxx address and changed the eCOS address to 192.168.1.xxx. Now the eCOS is visible on the local network.. I hope that nobody hacks my eCos now.. [xx(]
Touchcab is awesome.. As soon as I dialed up the correct address it loaded all the locos from the eCOS into the iPod.. I then used Skype to view the trainroom and operated the layout (until Harry Potter decided to derail on a switch that has operated perfectly for months) using the iPod...
I fired up WindigiPet remotely and lost control of the loco as it assumed a higher authority had control of the loco.. In fact, Windigipet allows you to manually control locos on the layout.. While Windigipet had control of the layout I could still watch the turnouts switching on the iPod screen... Very cooooooool... [^][^][^][^][^]
Anyway after I shutdown Windigipet, I could not get control of the loco until I exited and restarted TouchCab..
A great effort and well worth the $10 I paid (okay - and the $244 for the iPod touch!)... I would like to see a better awareness of other programs like WDP and railway & Co, so that I can use the iPod to do things at the far end of the layout, even when Windgipet is running...
#55 Posted : 08 November 2009 13:03:14(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MJ-Teknik
<br />Hi Adrian,
Actually this would be my preferred solution, but I can't get two wireless routers to talk with WPA security... I can get it work as an unsecured network, but there is no way I can run an unsecured network in my neighbourhood.. If you can show me a site that can help me to get this to work, I would be very happy to give it another try.. SmileSmile
Offline Fredrik
#56 Posted : 08 November 2009 13:15:37(UTC)
Fredrik
Try one of these: "D-Link DAP-1522 Wireless Accesspoint" (or you actually might need 2...):
ftp://ftp.dlink.eu/datasheets/DAP-1522.pdf
Fredrik.
WWW: MJ-fjärren
#57 Posted : 08 November 2009 13:34:16(UTC)
Eeeekk at $229 each I might stick with the bridged network devices.. But it sure looks good... I agree that two are needed.. Thanks for the link..
Offline GSRR
#58 Posted : 08 November 2009 14:43:32(UTC)
GSRR
Views messages in topic : 1,339
Hello Jens.
What is your latest with offering connectivity to the CS 2 60214?
Thomas
Offline Fredrik
#59 Posted : 08 November 2009 16:19:38(UTC)
Fredrik
<br />Eeeekk at $229 each I might stick with the bridged network devices.. But it sure looks good... I agree that two are needed.. Thanks for the link..
You might even get the proper length of network cable to connect the ECoS directly to the router...!
But it should be possible to connect to routers with WPA-security... Which routers do you have?
Fredrik.
WWW: MJ-fjärren
Offline TouchCab
#60 Posted : 08 November 2009 20:06:55(UTC)
TouchCab
I know there are issues with WDP, yet other programs coexist nicely with TouchCab.
I've been talking the the WDP author about it, and he told me that in the WDP system settings, you should enable "Display of all Loc-commands via
entry" (for processing locomotive command events) and "Display status of
solenoid devices by entry via keyboard" (for solenoid device command
events).
I haven't tried it myself yet, but perhaps this helps.
Jens
This account is no longer active
Offline TouchCab
#61 Posted : 08 November 2009 20:21:54(UTC)
TouchCab
[size=1" face="Verdana" id="quote]quote:Originally posted by GSRR
Hi Thomas.
I've been looking into the CS2 protocol a while back, and while I can query the CS2 for locomotives, I can't do the same for accessories. So the auto-load is broken, and I haven't been looking at the protocol since. Consequently, it's not right around the corner.
However, that YouTube video has certainly stirred things and kicked in some doors, so the world may be changing. It helps when people want to talk to me ...
I also noticed from the website log that TouchCab is being discussed in the insider club forum, but I don't know what they're saying. Hopefully something nice. If anyone is listening, please let Märklin know I am interested in talking to their CS2 programmers.
I don't know exactly what is going to happen and when, but other command stations are within reach. Just don't expect support for anything with only an RS-232 serial port.
Now, all the commotion also means I'll step back for a while and focus on getting some work done. I'll be reading here on and off, but don't expect me to post much.
You can still reach me through the TouchCab web site and the mail addresses listed there.
Thanks all
Jens
#62 Posted : 08 November 2009 22:12:31(UTC)
Originally posted by xxup
<br />....But it should be possible to connect to routers with WPA-security... Which routers do you have?
Netgear DG834PN (in service) and a Netgear WPN824 (retired)
#63 Posted : 08 November 2009 22:17:29(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by TouchCab
events).
Thanks.. I will give it a go.. Smile
Offline GSRR
#64 Posted : 09 November 2009 04:28:23(UTC)
GSRR
Hi Thomas.
Thanks all
Jens,
Thank you for the update, hopefully you can make progress with the CS2. I was at a train show today and discussed your product with some of the other club members. TouchCab is certainly appealing when trying to run a large club layout and having access to a portable control, allowing greater mobility around the layout. As shown in your video.
Thomas
Offline TouchCab
#65 Posted : 13 November 2009 01:24:11(UTC)
TouchCab
Okay, I'm back. The next TouchCab release is close to beta.
xxup, any luck with WDP ?
Jens
Jens
#66 Posted : 13 November 2009 14:09:31(UTC)
<br />...Okay, I'm back. The next TouchCab release is close to beta.
Nup.. I already had those settings on WDP... It's not a big deal.. I just have to return the loco to the "display case" in the loco database and then TouchCab works fine.. It just seems odd that I don't have the same problem with turnouts..
#67 Posted : 12 December 2009 12:27:49(UTC)
Touchcab just got updated to v1.3... Looks like there has been some work on the controller vs ipod problem.. Thanks Jens... I am going over to Nev's place to show it off over Christmas.... See http://www.touchcab.com/...eleasenotestouchcab.html .
Offline GSRR
#68 Posted : 27 January 2010 19:37:05(UTC)
GSRR
The much anticipated, and also much hyped Apple Tablet is expected to be announced today. I am interested to see if and how TouchCab will work and look on the Tablet. Also what if any new features Jens can bring to it.
Thomas
#69 Posted : 27 January 2010 22:07:36(UTC)
Applications designed for the iPhone can run on the iPad. Apple is also releasing updated tools
for software developers to help them build iPhone and iPad programs.
Quote from this article: http://news.yahoo.com/s/...BHNsawNhcHBsZXVudmVpbHM-
Offline Piper
#70 Posted : 08 February 2010 23:08:50(UTC)
Piper
Frostie wrote:
Great idea, but waiting to see how you can interface Iphone into CS2
Frostie,
Its easy, you can do it via a CS1. I tested it earlier tonight and it works.(I hope you have a CS1 lying around somewhereLOL)
Pieter
Era I-V / HO / C-Track / MS2, CS2 & CS3 Z gauge. Insider
Member of Märklin Modellers Group
Offline GSRR
#71 Posted : 09 February 2010 10:54:22(UTC)
GSRR
While at Euro East 2010, (Held at the Big E show) one of our club members brought a small layout with an EcOS controller and a wifi router. We were able to connect my iPod Touch and presto! I was controlling the 2 loks with TouchCab. It really is a marvel to see in action.
Jens, How are you making out with connection to CS2, without having to go through a CS1? BigGrin
Thomas
Offline TouchCab
#72 Posted : 12 February 2010 23:39:24(UTC)
TouchCab
Hi.
Sorry - I'm not even close, so you better hang on to those CS1's for a while.
Jens
Jens
Offline GSRR
#73 Posted : 12 June 2010 23:15:41(UTC)
GSRR
TouchCab v1.5 released
11 June 2010
http://www.touchcab.com/news.html
Offline Legless
#74 Posted : 30 June 2010 11:42:09(UTC)
Legless
Hi Jens, the program works great.
My grandson says,"it's cool". Has anybody tried it on a Ipad?
Legless
Offline GSRR
#75 Posted : 25 August 2011 03:37:35(UTC)
GSRR
TouchCab 1.6 is released
Wednesday, 24 Aug, 2011
After a last minute rejection, TouchCab and TouchCab Free version 1.6 have now been approved for sale in the iTunes App Store. If the apps are not there yet, they will be within the next 24 hours.
The rejection was due to TouchCab not looking good on an iPad, which is fair enough, since it was never built for it. After recompiling for iPhone and iPod only, the review process was picked up immediately (wow) and there were no further issues.
So - TouchCab is off the iPad for now ...
Also, I had to restrict this version to iOS 4 or better, since I no longer have any means of testing for iOS 3.x. Sorry folks, but that is the way it’s gonna be. I have had reports of 1.6 crashing on iOS 3.x, but no way to solve it.
You may find that things behave slightly different in version 1.6 compared to 1.5, and this may cause some getting used to.
Please check the release notes or the instructions if you are uncertain. I’m sure you’ll appreciate it after some operating sessions.
What’s next?
•TouchCab 1.7: XpressNet accessories
•TouchCab 1.8: Märklin CS2
•TouchCab 2.0: Track plans, iPad and Mac
Have fun, and don’t forget to tell me if you find anything strange, OK?
TouchCab Release Notes
Version 1.6
New features and changes
•Revised track power scheme
•Improved left/right hand cab layouts for easier operation
•Indexed locomotive list (for 14+ locomotives)
•Access to functions F8+ by swiping the function buttons
•Landscape mode removed
•Up to 29 functions
•iOS4 suspend/background mode supported
•Last used locomotives moved to cab view
•New function symbols for ECoS 3.4.0
•Improved handling of special characters in loco names
•Stop all trains at exit removed
•"Shake to stop" removed (silly feature)
•Many improvements to the overall code
Bug fixes
•Fixed handling of 1 or 2 occupied locomotives
•Improved network handling
•Lots of minor fixes
Known issues
•Functions above F19 not working with ECoS v3.4.0 due to a bug in the ECoS software.
Offline NZMarklinist
#76 Posted : 27 September 2011 06:42:03(UTC)
NZMarklinist
Jens, all,
I updated my touchcab version to 1.6 via ITunes a few weeks ago. Now sadly it will not open or stay open at all, even for a demo look thru, on my I Phone so I can't even connect it to try it.Cursing I thought about a reload but that seems to involve removing it from Itunes as well as the phone. Does that mean I have to re purchase the App ??Confused
Touch Cab was a big reason I chose an Iphone over other devises.
Glen
Auckland NZ
Offline Maxi
#77 Posted : 27 September 2011 13:48:19(UTC)
Maxi
Views messages in topic : 757
First question is which iOS are you running on your IPOD iOS4 or iOS 3.x.
#78 Posted : 30 September 2011 06:04:36(UTC)
NZMarklinist
Jens, All,
Just to recap from the other thread, I deleted Touchcab from my Iphone and reloaded it, now it works fine QED Cool
Glen
Auckland NZ
Offline ak_marklineer
#79 Posted : 30 September 2011 06:28:15(UTC)
ak_marklineer
Touchcab is a great wireless controller and has proved very reliable, for me, you also have to watch out for Glen in control of Loco's, now that's scary! Marklin has an app (for the CS2 only) it mimics the CS2's screen and controls the locos, signals, switches etc in the same way as the CS2 does. Touchcab is wonderful for the CS1
Steve
German DRG ERA II
MSIG of The Auckland Marklin Club Inc
www.marklin.org.nz
CS1 with WiFi
TouchCab with iPhone
Offline GSRR
#80 Posted : 13 February 2012 17:08:12(UTC)
GSRR
TouchCab 1.7 is released
Now, what’s in the pipeline for 2012?
Well, the previously announced roadmap stands:
v1.7: Lenz/XpressNet (estimated early 2012)
v1.7.5: Extra features for Lenz (estimated April 2012)
V1.8: Märklin CS2 (estimated July/August 2012)
V2.0: Track plans, iPad and Mac (estimated late 2012)
thanks 2 users liked this useful post by GSRR
#81 Posted : 13 February 2012 19:47:51(UTC)
And for the Ecos controllers (both versions).
Offline witzlerh
#82 Posted : 14 February 2012 20:49:54(UTC)
witzlerh
I have a CS1. Is is not updated by Marklin or ESU as i got it after the program was complete. Will touchcab work with this?
Harald
CS2 DB & Canadian Era 3-6
#83 Posted : 14 February 2012 21:06:38(UTC)
Yes it will, provided you have the CS1 connected to a home network or router with a wireless capability.
I have used TouchCab with my CS1, see https://www.marklin-user...progress.aspx#post266802
#84 Posted : 14 February 2012 21:35:21(UTC)
I think that your CS1 needs to be at v2.0.3 or v2.0.4 to support Touchcab, which means it will have to have been updated to hardware and software v2.0 by Marklin.
#85 Posted : 15 February 2012 03:27:06(UTC)
NZMarklinist
The Auckland Marklin Club's donated CS1 v1.0? is, courtesy of, and thanks to Toottoot, on its's way to Marklin now for the upgrade to V2.0/2/3 ???
So I think sending any older CS1 v1.x is worthwhile
Glen
Auckland NZ
Offline GSRR
#86 Posted : 23 February 2012 20:51:33(UTC)
GSRR
just released on iTunes
1.7.1 - Bugfixing
Today TouchCab and TouchCab Free version 1.7.1 have been uploaded to Apple for review.
The following issues have been addressed in these versions - (F) is the item applies to the free version also:
•Added missing placeholder for locomotive name (F)
•Fixed special language character encoding for names (F)
•Fixed backup to iTunes (F)
•Fixed missing train route symbol for Märklin CS1 v2.0.4
•Fixed momentary functions for Lenz and when swiping
•Accessories now have default 100ms pulse time instead of fixed output (Lenz)
•Fixed a situation where setting the drives of a 3-way turnout in the wrong order would cause a short
r/Thomas
Guest (4)
2 Pages<12
This page was generated in 1.008 seconds.
