Offline Deborail
#1 Posted : 26 October 2009 16:25:22(UTC)
Deborail
United Arab Emirates
Gents, i have a 21-pin connector type locomotive ordered, from trix, in this i can fix the 66839 digital decoder. Is this digital decoder used for enabling the movement of the loco by the mobile station, or is it for the lights only??. The loco in question is 22221 Br 218....Another loco is DCC ready. It means I can use the mobile station to move it independently, right?
I don't understand what is the function of the 21-pin digital decoder and what are the limitations in a loco that only has a 21-pin connector as opposed to the DCC built in locos.
George
Given enough time, tasks manage themselves.
Offline tekin65
#2 Posted : 26 October 2009 17:25:47(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by Deborail
<br />I don't understand what is the function of the 21-pin digital decoder and what are the limitations in a loco that only has a 21-pin connector as opposed to the DCC built in locos.
George hi,
They both are the same thing; "DCC ready" and "digital ready with 21 pin interface" practially saying the same thing in different ways: both means you need a decoder.
The decoders you'll buy for any type of common HO interface (6 pin for Flm., 8 pin NEM, or 21 pin) will do the same thing. You can use them all with your Trix MS provided that they are DCC (or Selectrix, or both) decoders.
Limitations in a loco that only has a 21-pin connector as opposed to the DCC built in locos will depend on the decoder you will put in the 21 pin connector loco.
Hope this clears things a bit.
Cem.
Now all eras but no ICE
Offline Deborail
#3 Posted : 05 November 2009 07:20:29(UTC)
Deborail
Now I have a BR 218 and I have also ordered a 21-pin decoder, how do I fix the decoder inside the BR218???
George
#4 Posted : 05 November 2009 07:31:49(UTC)
Line up the pins and plug it in!
The decoder will piggy back on top of the interface PCB.
Check your decoder and locomotive instructions first, to see what specific information is given.
BTW, checking the Trix catalog I purchased recently suggests 66839 is the correct decoder.
Offline Deborail
#5 Posted : 05 November 2009 08:10:25(UTC)
Deborail
<br />Line up the pins and plug it in!
Hi Bigg Daddy NZ...
Yes it is the 66839. How does one do the piggy back thingy? I guess I have to unscrew the loco and open it, then what? There is no information in the loco instructions. When I open up the loco will there be a place to just insert it?? Or do I have to remove anything first?
George
#6 Posted : 05 November 2009 08:27:49(UTC)
I haven't done one myself yet (waiting for my 2 Trix Br44's to arrive), but it should be obvious where to plug the decoder in. Take the top of the loco off, you should see a 21 pin socket that will match up with the 21 pin plug on the decoder. The decoder will end up sitting on top of the interface PCB.
Offline Deborail
#7 Posted : 05 November 2009 08:29:23(UTC)
Deborail
<br />I haven't done one myself yet (waiting for my 2 Trix Br44's to arrive), but it should be obvious where to plug the decoder in. Take the top of the loco off, you should see a 21 pin socket that will match up with the 21 pin plug on the decoder. The decoder will end up sitting on top of the interface PCB.
Okay - will do that when it comes...What is the interface PCB??
George
Offline tekin65
#8 Posted : 05 November 2009 08:36:05(UTC)
tekin65
Turkey
<br />Okay - will do that when it comes...What is the interface PCB??
George hi,
The PCB is the little board where some electronic circuits drawn on. Now, this is what you are looking for (see the pins sticking out):
With a great possibility there is something like this already plugged into the pins:
Just pull it out and place the decoder over the pins and push down.
Cem.
Offline Deborail
#9 Posted : 05 November 2009 08:50:38(UTC)
Deborail
Thanks Cem, I will try this....
George
#10 Posted : 05 November 2009 09:04:57(UTC)
The pins and the socket should be numbered, or at least pin 1 should be identified. You need to make sure that pin 1 on the decoder and pin 1 on the socket are lined up. Take note of the orientation of the terminator board that Cem shows in his 2nd picture before you pull it out. The decoder should plug in the same way.
PCB = Printed Circuit Board, i.e. the Board that all the various components are soldered to.
Offline tekin65
#11 Posted : 05 November 2009 10:00:33(UTC)
tekin65
Turkey
George hi,
Take note of what David says about correct positioning; I wonder if the decoder have protection if inserted the wrong way ... most do.
Cem.
Offline pa-pauls
#12 Posted : 05 November 2009 11:38:36(UTC)
pa-pauls
No it does not !
Pål Paulsen
Offline tekin65
#13 Posted : 05 November 2009 11:44:36(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by pa-pauls
No it does not !
There you go ... be careful then [:0]
Pal, it is quite strange; I wonder why they didn't add a simple protective circuit, many producers do [xx(]
Cem.
Offline DasBert33
#14 Posted : 05 November 2009 11:55:26(UTC)
DasBert33
You have been a member since:: 21/01/2004(UTC)
But it does have a key pin so in theory you can not plug it incorrectly.
Offline tekin65
#15 Posted : 05 November 2009 12:07:23(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33
<br />But it does have a key pin so in theory you can not plug it incorrectly.
Oh, ok then. Hear that George? You cannot go wrong biggrin
Cem.
#16 Posted : 05 November 2009 12:17:18(UTC)
Thanks Bert, I wasn't sure about that, so didn't say. George, as Cem says, this means that the decoder should only go in one way.
Offline Deborail
#17 Posted : 05 November 2009 12:55:52(UTC)
Deborail
Another question friends...what if i try to control this loco (trix 22221)by the trix mobile station before the 21 pin connector is inserted? Will it damage the loco? I have tried with a normal 12v dc transformer and the loco works nicely...
George
Offline pa-pauls
#18 Posted : 05 November 2009 12:55:56(UTC)
pa-pauls
Yes you can ! I put in a LokSound decoder up-side-down once and it blow !
Pål Paulsen
Offline davemr
#19 Posted : 05 November 2009 13:07:35(UTC)
davemr
Yep. You can put in a decoder upside down. In my case it did not blow so was lucky.
dave
davemr
Offline tekin65
#20 Posted : 05 November 2009 13:21:01(UTC)
tekin65
Turkey
<br />Another question friends...what if i try to control this loco (trix 22221)by the trix mobile station before the 21 pin connector is inserted? Will it damage the loco? I have tried with a normal 12v dc transformer and the loco works nicely...
You cannot control an analog loco with a digital command unit. If you put it on rails it'll just run at full speed. I don't think it'll be damaged though.
Cem.
Offline Deborail
#21 Posted : 05 November 2009 13:41:19(UTC)
Deborail
So it means the 22221 loco is a completely analogue loco if there is no 21-pin connector.
Cem.
George
Offline Deborail
#22 Posted : 05 November 2009 13:43:21(UTC)
Deborail
Cem.
That means the 22221 is analogue and it only becomes digital after a 21-pin connector is inserted....right?
George
Offline tekin65
#23 Posted : 05 November 2009 16:51:53(UTC)
tekin65
Turkey
Hi George,
Yes, that's right.
Cem.
Offline DasBert33
#24 Posted : 05 November 2009 17:18:14(UTC)
DasBert33
IMHO if you plug it the way it is supposed to you can't plug it wrong. There is a hole missing on the decoder PCB where the keypin is.
I agree that you can insert it wrong 'halfway' and that in that case the decoder might die, but when inserted properly (in the sense of mechanically properly so all pins make full contact and are equally deep in the socket ) it should only be possible in the correct way.
Bert
#25 Posted : 05 November 2009 19:20:22(UTC)
No it does not !
Yes it does!!!
The only wrong functions are lighting not in function,if decoder is not correct inplug!
In all decoder,there is always protection!
#26 Posted : 05 November 2009 19:23:02(UTC)
Just read after locomotivs newsletters,about how to inplug decoder!
Offline pa-pauls
#27 Posted : 05 November 2009 19:24:42(UTC)
pa-pauls
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
Yes it does!!!
Sorry Goofy but here you are wrong indeed ! read above wink
Pål Paulsen
#28 Posted : 05 November 2009 19:34:30(UTC)
Not if you turn decoder 90 degrees!
Offline pa-pauls
#29 Posted : 05 November 2009 19:51:15(UTC)
pa-pauls
What are you talking about Goofy confused
Turn decoder 90 degrees ? We are talking here about the 21 pol type decoder
and it is not possible to turn it and why should you ? But it is possible to
mount it up side down as what you are supposed to do and then you'll have a problem wink
Pål Paulsen
Offline tekin65
#30 Posted : 05 November 2009 20:38:46(UTC)
tekin65
Turkey
<br />Not if you turn decoder 90 degrees!
Perpendicular confusedconfusedconfusedconfusedconfusedconfused[:0][:0][:0][:0][:0]
Cem.
#31 Posted : 05 November 2009 20:46:15(UTC)
90° is not enough - you probably mean 180° ...
Better turn it 360° and it'll fit again ...
#32 Posted : 05 November 2009 21:01:40(UTC)
Oppsss... [:I]
I mean 180 degrees.
biggrin
Offline pa-pauls
#33 Posted : 05 November 2009 21:16:09(UTC)
pa-pauls
<br />Oppsss... [:I]
I mean 180 degrees.
biggrin
Wrong again ! See my post above wink
Pål Paulsen
#34 Posted : 05 November 2009 21:34:52(UTC)
A Märklin (mfg ESU) 21-pin blows if you put it upside down and are unlucky - I've done it too. Not everyone are as lucky as Dave.
#35 Posted : 05 November 2009 21:49:33(UTC)
The point here is, as I made in my previous post, make sure you get it the right way around the first time. Saves any problems later!
Offline tekin65
#36 Posted : 05 November 2009 21:53:22(UTC)
tekin65
Turkey
<br />... get it the right way around the first time. Saves any problems later!
Isn't that so for everything we do; first marriage, first train set, first car ... ? biggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrin
Cem.
#37 Posted : 05 November 2009 21:55:01(UTC)
Yup!
Offline TimR
#38 Posted : 05 November 2009 22:33:51(UTC)
TimR
Indonesia
<br />A Märklin (mfg ESU) 21-pin blows if you put it upside down and are unlucky - I've done it too. Not everyone are as lucky as Dave.
I've plugged these 21-pin decoders in and out a few times now - now I can't recall whether or not I actually pay attention to not put it up-side-down.
But considering they're all running well, I think I got them right so far...biggrinbiggrinbiggrin
Up till now, I do this almost purely by instinct - if it fits, then....
But I will pay more attention in the future, of course....
Now collecting C-Sine models.
Offline tekin65
#39 Posted : 05 November 2009 22:35:45(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by TimR
<br />... considering they're all running well, I think I got them right so far...biggrinbiggrinbiggrin
Pure instinct, I say biggrin
Cem.
Offline pa-pauls
#40 Posted : 05 November 2009 22:47:43(UTC)
pa-pauls
Regarding mounting of the 21 pol decoder.
HAG, Märklin etc use the 21 pol decoder with the connector UP
while for example Brawa use the 21 pol decoder with the connector DOWN !
Have a look at the latest LokPilot decoder manual on page 11
You can download it here : http://www.esu.eu/en/dow...anuals/digital-decoders/
Pål Paulsen
Offline Deborail
#41 Posted : 07 November 2009 09:25:43(UTC)
Deborail
<br />Regarding mounting of the 21 pol decoder.
Guys, you got me all worried now!![:0]
Hope i fix it the right way....
Still it is in the post...
George
Offline tekin65
#42 Posted : 07 November 2009 11:26:54(UTC)
tekin65
Turkey
George,
You can always take photos and post them here so someone can instruct you the right way.
Cem.
Offline davemr
#43 Posted : 07 November 2009 12:50:23(UTC)
davemr
George. Dont worry this is not difficult. All you are doing is matching up the holes with the pins and as you would in any plug and socket.
If you can plug anything into a mains socket then you can plug in a decoder.
dave
davemr
Offline Deborail
#44 Posted : 12 November 2009 09:51:01(UTC)
Deborail
[size=1" face="Verdana" id="quote]quote:Originally posted by davemr
<br />George. Dont worry this is not difficult. All you are doing is matching up the holes with the pins and as you would in any plug and socket.
dave
Yes i did it last night, however initially I too placed the decoder the wrong way up (or down)inside the BR 218, then when it seemed not right to me i changed it over...Luckily my wife is experienced in this because she worked in a electronics factory before....she immediately pointed out the error....
George
#45 Posted : 12 November 2009 10:11:01(UTC)
On my Trix Br44's the bottom row of pins on the MTC connector has one additional pin. The top row has 10, the bottom 11. You just need to make sure each lines up with the correct row.
Offline pa-pauls
#46 Posted : 12 November 2009 13:27:09(UTC)
pa-pauls
Good to hear that George Smile
Yes David, if you line it up you should do it correct if you don't have it up-side-down then biggrin
But if you always remember that Märklin/Trix has the connector facing UP you can't go wrong wink
Pål Paulsen
#47 Posted : 12 November 2009 15:57:46(UTC)
But of course Pål, since here where I am we are down under, then up-side down to you is right-side up to us.... So if I should fit it right-side up, I can see this becoming very confusing very quickly.....biggrin
Offline pa-pauls
#48 Posted : 12 November 2009 17:45:42(UTC)
pa-pauls
LOL biggrin
Indeed my friend [:p]
Pål Paulsen
21 pin connector with LoKPilot 3.0 mfx (Digital)
by MarioFabro 19/05/2008 20:24:06(UTC)
This page was generated in 0.891 seconds.
