Offline Deborail
#1 Posted : 19 October 2009 10:40:37(UTC)
Deborail
United Arab Emirates
Dear Friends, if I were to get a trix mobile station (66920) would that be enought to control my locos? I already have a DC transformer and I plan to control 4-5 locos....
George
Given enough time, tasks manage themselves.
Offline tekin65
#2 Posted : 19 October 2009 10:43:38(UTC)
tekin65
Turkey
Hi Gregor,
You can control all the locos that have Selectrix or DCC decoders. I use Trix MS to control my multiprotokol decoder installed 3 rail locos too.
Cem.
Now all eras but no ICE
Offline Deborail
#3 Posted : 19 October 2009 10:47:53(UTC)
Deborail
Yes but is the mobile station enough? What wires go into and out of the mobile station?
George
Offline tekin65
#4 Posted : 19 October 2009 11:04:17(UTC)
tekin65
Turkey
For 4-5 locos without many functions, especially smoke generators, it should be enough.
Two wires from transformator comes in and two wires to tracks go out - this happens on the digital adapter. If you buy the set you'll get everything you need: transformer, digital adapter, MS, and connector track.
Cem.
Offline Deborail
#5 Posted : 19 October 2009 17:16:35(UTC)
Deborail
<br />Hi,
Cem.
The one set i see on the trix shop (11122) is only for N-gauge, can it also be used for HO??
George
Offline tekin65
#6 Posted : 19 October 2009 17:37:11(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by Deborail
<br />The one set i see on the trix shop (11122) is only for N-gauge, can it also be used for HO??
It is the Trix Mobile Station itself biggrin
Sure can be used for HO, no problems. But I'd go for a set without decoders.
Cem.
#7 Posted : 20 October 2009 01:12:16(UTC)
Cem.
Nope...!
Itemnr:11122 has lesser power out to the track,while 66920 has more power output.
It´s not the same set.
11122 is an set suited for N-scale at 12 volts.
Offline tekin65
#8 Posted : 20 October 2009 01:18:30(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
<br />It´s not the same set.
You mean there's two different Trix MS's?
Cem.
Offline Deborail
#9 Posted : 20 October 2009 14:45:16(UTC)
Deborail
Gents, for the item 66920, is the transformer and connector box also included (along with the mobile station) in the package?? In the trix online shop it is not clearly described. I need to get all three in a set. At the moment I am just using a cheap transformer connected directly to the line....
George
Offline tekin65
#10 Posted : 20 October 2009 15:27:13(UTC)
tekin65
Turkey
11122 is the set you want.
Cem.
Offline Deborail
#11 Posted : 20 October 2009 16:08:26(UTC)
Deborail
<br />11122 is the set you want.
Cem.
I know...just ordered it PLUS a BR 218 (blue and white) Cool
George
Offline Deborail
#12 Posted : 20 October 2009 16:11:28(UTC)
Deborail
Thank you Cem. - you have been very helpful to me.....
George
Offline tekin65
#13 Posted : 20 October 2009 16:13:36(UTC)
tekin65
Turkey
No problem George, enjoy your new stuff ... once they arrive Smile
216 in cream/turquoise is one of my favorites.
Cem.
Offline Deborail
#14 Posted : 20 October 2009 16:17:49(UTC)
Deborail
<br />No problem George, enjoy your new stuff ... once they arrive Smile
Cem.
Cream/turquoise -- - yes not blue-white!!!biggrin
George
Offline tekin65
#15 Posted : 20 October 2009 16:26:07(UTC)
tekin65
Turkey
<br />Cream/turquoise -- - yes not blue-white!!!biggrin
SmileSmileSmileSmileSmile
#16 Posted : 20 October 2009 20:58:12(UTC)
The set 11122 has connector box for N-scale in 12 volt livery out to rail.
It depends that N-scale is in function at 12 volts,because of motor at locomotivs.
And there is weaker transformer for that.
In HO scale there is bigger transformer and connector box for 16 volt out to rail.
If you shall drive and using HO scale,forget about set 11122!
So with 66920,you can control up to 6 locomotivs depends of motor at locomotivs.
66920 has 1,9 Amps out to rail in maximum load.
While 11122 has about 1,2 Amps in load.
Good luck!
P.S.
Trix mobil station don´t have adjusts the voltage!
That´s way two different of connector box.
Offline Deborail
#17 Posted : 21 October 2009 11:30:22(UTC)
Deborail
But the set 11122 has the same mobile station no. 66920. And also the transformer included in this set up is 18VA. I have already ordered the 11122 kit, when it comes, I will see how it works...
George
#18 Posted : 21 October 2009 20:17:44(UTC)
Yes mobil station is the same...but not connector box!
11122...12 volt connector box
66920...16 volt connector box
Offline Deborail
#19 Posted : 22 October 2009 14:33:54(UTC)
Deborail
The 16 volt connector box is not available in the database....What is the ordering number for it?
George
Offline tekin65
#20 Posted : 22 October 2009 17:31:15(UTC)
tekin65
Turkey
Looks like nobody knows, I'll check mine for part number this evening and let you know.
Cem.
#21 Posted : 22 October 2009 19:31:28(UTC)
<br />The 16 volt connector box is not available in the database....What is the ordering number for it?
Hi...!
There is no itemnr. for connectorbox,since it´s follows only in set and cannot therefore get seperat.
Offline tekin65
#22 Posted : 22 October 2009 20:17:04(UTC)
tekin65
Turkey
George,
Goofy is right, no number on digital adapter. If you'll have difficulties with the one you receive I can get you the correct one.
Cem.
Offline Deborail
#23 Posted : 24 October 2009 10:34:56(UTC)
Deborail
Yes okay anyway by the time i get this I would have 3 locos...Maybe the supplied current won't be enough for these? We'll see in a weeks time or so...
George
Offline Deborail
#24 Posted : 07 November 2009 09:30:33(UTC)
Deborail
<br />The set 11122 has connector box for N-scale in 12 volt livery out to rail.
Good luck!
P.S.
Hi Goofy, I got the 11122 kit it now and it works nicely with my 3 HO locos....No problem....It gives 1.9 A current. and 20 V AC. I think it can only power maximum 4 locos in HO.
George
This page was generated in 0.494 seconds.
