Offline applor
#1 Posted : 29 July 2009 06:33:45(UTC)
applor
Hello everyone,
I will be building a large K track layout in a very large shed in the future.
I would like a very realistic layout with long sweeping bends for the main line.
I was wondering what the maxium angle bend that can be done with the 2205 flex track? I'm wondering if it I could use them for loooong curners, as even the widest radius K track curves are only 618mm which is way too sharp for running an ICE at 300km/h around.
The other option is to use the 2274 curve. It has a 902mm radius which would be great, however there is no parallel curve to go with it so you can't run a main line with a pair of tracks.
I know a lot of people only have small layouts and this stuff has never been an option but I'm hoping someone can shed some light on what they've done?
Offline Graham HO
#2 Posted : 29 July 2009 06:49:27(UTC)
Graham HO
Do whatever you want to do with M.2005, but make sure you use a jig or pattern for consistency of curve and a set of Flexgleisspanner (Conrad part munber 21 77 33-47 or a more recent upgrade number) - indespensible for this sort of project.
Offline Graham HO
#3 Posted : 29 July 2009 08:10:03(UTC)
Graham HO
Apologies for the typo in my previous thread - it should have course been M. 2205. The revised part number from page 109 in the Conrad 2009 Catalogue is 21 77 33-65 at €20.95 incl. tax. There is also a Z gauge item Part number 21 77 36-65 for the same price.
And to conclude - a comment from Roland Zötzl in the Catalogue "Einfach praktisch: Für exakte Bogen"
Offline pab
#4 Posted : 29 July 2009 12:30:16(UTC)
pab
In addition to what Graham said, you also need a cutter, like a dremel.
I had no problem bending K track.
#5 Posted : 29 July 2009 12:40:28(UTC)
The 2205 *IS* a flexible track, and can be bent to any extend.
The 2274 is nice, and you can use it as one of the tracks in a double tracked line, where the parallel track can be made with the 2205.
While the mentioned tools are a great help, I laid my tracks without any of them. (Well, I used a Dremel until the last disc broke, now a use a saw)
Offline applor
#6 Posted : 30 July 2009 04:42:24(UTC)
applor
Ok so from these replies I take it there is no real physical limitation on what radius you can bend a 2205?
So It could thereotically be bent to a 360mm radius? I don't think this would be possible due to the inside rail having to be shorter than the outside?
Either way if I can use them as an outside cuver with the 2274 that should give a nice sweeping curve - otherwise I can just use a pair of 2205's for an even wider radius curve.
Does anyone have pictures of the 2205 being used as a large radius curve on a layout?
Offline rschaffr
#7 Posted : 30 July 2009 04:43:30(UTC)
rschaffr
When you bend it any amount, the rails become uneven. You must cut the longer rail.
-Ron
#8 Posted : 30 July 2009 04:55:43(UTC)
The 2274 track does'nt make a circle.
I have used the 2274 track and bending (not physically) it to a 180 half circle doesn't hurt.
This gave me a startingpoint to lay my flexi track next to it and uphold the distance between the 2 tracks, making the 2205 an even curve.
regards.,
Offline Hannu
#9 Posted : 30 July 2009 12:35:53(UTC)
Hannu
You can not bend flex to arbitrary sharp curves. The shorter radius, the larger stress affects the tiny plastic parts, which keep rails on track. Someone recommends that fine 2-rail flex should not be bend under 1000 mm radius. That is very conservative recommendation, and many use also shorter radii and Märklin's flex has also more robust structure. I would not use that under 600 mm radius.
#10 Posted : 30 July 2009 15:30:02(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Hannu
I once bend a short section sharper than the industrial track radius. It was used on my first permanent layout. No problem! ;-)
-However, the track-piece was not recyclable when the layout was broken up...
Offline applor
#11 Posted : 31 July 2009 03:31:50(UTC)
applor
Yeah as mentioned I only want to use them for wide radius curves of 1000mm or greater, which shouldn't be a problem then.
Wanted to make sure it would handle that radius as I've never used it before.
Thanks for the help everyone.
This page was generated in 0.714 seconds.
