6 Pages«<456
Offline James
#251 Posted : 28 May 2009 08:27:09(UTC)
James
Lutz:
As always... thanks againCool.
Sincerely
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
Offline pa-pauls
#252 Posted : 28 May 2009 12:14:20(UTC)
pa-pauls
it should be out any time within the next two weeks.
And if I did understand you correct Sir then also a new updated manual will be out confused
Pål Paulsen
Offline Nigel Packer
#253 Posted : 28 May 2009 15:38:17(UTC)
Nigel Packer
<br />Looks rather like a problem with your CS/your update than with this new update version content. None of the problems described by you show up with my CS's after having performed the same procedure.
BTW: What's your GPF version now? What's the value of the status inquiry interval?
With my German language selection, there is a corresponding message. When I choose EN, the help screen is just empty and no error message is displayed.
Hi Lutz,
Thanks very much for your interest and comments.
My CS2 is at version 1.1.3(0), with hardware version 3.4. The CS2 itself and all three of my 60173 boosters are at TFP level 1.22.
However, I think I have solved the problem! First of all, I performed an "Update program" step without nothing connected to the CS2, and the problem went away (the update failed, naturally). mfx locos responded quickly, and (eventually, after about half an hour) the mfx locos on the track sorted out their registrations and all started to work normally.
Then, later, the problem returned, and I was up to 30 seconds or more response time for mfx locos. But I discovered that it is the presence of my BR112 loco from the 26540 set that causes the problem! If this loco is not on the track when the CS2 is booted, everything works OK.
So, I've no idea why, but it looks as though I need a new mfx decoder for this loco. Have you ever seen a problem like this? I wonder if it's a known mfx fault?
I think this loco may be on its way back to Weinsberg!
Thanks again for your helpful input.
Best wishes,
Nigel
#254 Posted : 28 May 2009 16:40:21(UTC)
<br />Is it work with Booster 60173?
Yes, no problem. [^]
Thanks, The booster work well after the update.[:p]
No problem so far, Well done Marklin.Cool
Offline mmervine
#255 Posted : 29 May 2009 02:13:37(UTC)
mmervine
Glad to hear that this is out and working! A couple of members of the ETE-ENE have the CS2. I will let them know that the new firmware is available.
#256 Posted : 29 May 2009 03:46:45(UTC)
<br />A hardware interface is announced by Märklin to connect a CS1 2.x.x to a CS2, but it is not clear whether it would work with a CS1 v3.x.x. Märklin says "possibly will not".
Although Marklin have previously stated that connecting a v3.0 CS1 to a CS2 in this way will invalidate the CS2 warranty, as Marklin has no way of determining what might (or might not) happen.
#257 Posted : 29 May 2009 14:38:02(UTC)
Nigel Packer
<br />have you ever heard about Christian Lindberg/Mandrake in the corner? (I'd bet Juhan and/or some other Swedish members have biggrin)
Looks like it really has nothing to do with the update. Maybe you might try to perform a reset on the loco/decoder and test it again before having to send it back.
Good luck! wink
Hi Lutz,
Thanks. No, I'd never heard of Christian Lindberg, so I looked for him on YouTube. Obviously a great musician, but slightly weird (in the charming sort of way that could only be Swedish!).
I can't manage to reset the decoder - the CS2 obviously doesn't recognise the loco, and it doesn't respond to the programming sequence on a 6021. Hans (my dealer) has passed the question on to Frank Mayer, so we'll see what he thinks!
Best wishes,
Nigel
Offline sudibarba
#258 Posted : 30 May 2009 05:21:07(UTC)
sudibarba
I finally got time to update my CS2. Took the cable out of my computer, hooked it to the CS2 and did the update smooth as silk. I don't know why one would use the stick to do it. I guess if you didn't have high speed internet connection you could get the update on someone elses computer and take it to your CS2.
Anyway, the keyboard works and I was able to correct some some other picture problems I had. Somehow, I had gotten the data base of pictograms messed up. My F7 showed the picture of the Red Arrow. Changed all the f7s to the now available correct Santa Fe.
Now, I am thick I guess. When I select the "everything option" I get the choices of Loks with pictures. Very nice. I can scroll between the pages of loks. But, what do the letters stand for?
&lt; AD E Sw &gt;
By choosing them I get the pages of loks - but what do the letters stand for?
Eric
Offline laalves
#259 Posted : 30 May 2009 14:24:31(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by sudibarba
<br /> I can scroll between the pages of loks. But, what do the letters stand for?
&lt; AD E Sw &gt;
I'm intrigued by the same thing, only I have "79" and "BR".... I wonder what that means. I can't relate these labels to addresses and/or names of my loks, so I don't get it.
Offline jeehring
#260 Posted : 30 May 2009 14:56:51(UTC)
jeehring
<br /> But, what do the letters stand for?
&lt; AD E Sw &gt;
Eric
Sometimes you could see what happens with other languages , you and Luis,... are you using it in English ?
Or....lets wait for next chapter of "manual of instructions"...may be wink ....or next update wink
#261 Posted : 30 May 2009 15:48:17(UTC)
Nigel Packer
&lt; AD E Sw &gt;
It's the first two characters of the name of the first loco on each page of locos.
It's just a hint to help you pick the right page when you are looking for a loco to select.
Nigel
Offline sudibarba
#262 Posted : 01 June 2009 01:00:40(UTC)
sudibarba
Help! Maybe I've forgotten something. I can't seem to change the decoder addresses now. I call up the lok, pick the tool icon and get the screen as normal. All things appear the same. Lok name, picture, decoder "programable"
I change the address and hit the download icon in the lower right of the screen.It starts transferring but only for a short time. It then says transfer complete and I click the green check and the green check to exit the screen. Lok does not respond. Before the change worked fine on the programming track. Go through process and up load address and it gives the old address which works fine. So, address not going through. Lok pilot 3.0 by the way. Never had a problem setting addresses before. Did I forget something?
Eric
Offline jeehring
#263 Posted : 01 June 2009 01:23:00(UTC)
jeehring
<br />My two boosters are alive... I'll do a bit of testing when I have the time and see how it goes.
Considering how things have gone the last two times, I'm very cautious before saying anything.
Happy that you seem to have gotten relief - I know it has been trying on you.
Eric
Thanks Eric, and you're right!
I've been around the interface a bit, and I haven't been able to interpret completely the new DCC decoder programming method which does support Programming On the Main (POM). I don't see a "conventional" DCC programming interface as it was previously.
This new one appears to be more complex to operate, but also customizable. CVs can be "baptised" and a "portfolio" of CVs may be created as required and the resulting decoder profile may be saved. Thus, one may create a profile for Lopi v2, another for Lopi v3, another for LS v3.5, etc, etc. Without instructions, the way I understand the programming process is like this:
1 - Create profiles for your DCC decoders and save them. Each CV in the profile will then be identified by the name you give it;
2 - Call an existing or create a new DCC lok;
3 - Load the relevant decoder profile (e.g. Lopi v3);
4 - Change the values of the CVs as required;
5 - The profile and the CV values become embedded with each DCC loco you have and is saved together with the loco information.
This is a really clever process, which reduces the crypticism of DCC CV programming but also makes it more complex and initially more time consuming. Also, different firmware versions of the same decoder models may have different or new CVs, so care is required.
Please
Is the new interface described abov available now for everybody including those who download from V 1.05 or for those who download from V 1.07(2) or V 1.07 (3) with dcc , only ?
Offline sudibarba
#264 Posted : 01 June 2009 04:15:24(UTC)
sudibarba
Update - see my previous post.
I have tried my Marklin hobby 36854 Rag & 36851 Cargo. I can change the addresses at will perfectly. I still cannot change any of my Lokpilot 3.0 conversion reliably. I did get one of the 4 I tried to change but I could not get it to change back or to another address.
Can someone else try their Lok pilot conversions. Not sure what to do next. I hope this is not what I think it is.
Eric
Offline SierraDelta
#265 Posted : 01 June 2009 21:25:17(UTC)
SierraDelta
An overview of all the function symbols available after the update is now available here:
http://mediencms.maerkli...CS2-Funktionssymbole.pdf
Søren
___________
CS2 60213 version 1.6.4(3)/GFP 1.40
2011 planned purchases - | nothing |
#266 Posted : 01 June 2009 22:35:43(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by SierraDelta
<br />An overview of all the function symbols available after the update is now available here:
Any English?
Offline Burnix
#267 Posted : 02 June 2009 15:02:38(UTC)
Burnix
Finally I got the chance to perform the update and it actually caused me a lot of problems the first couple of times. It kept stating that the update was unsuccessful. The problem was that it was not downloading the software the first couple of times (visible in the progress bar during the updating).
After having tried a couple of times by simply pressing "update program" in the setup screen, I pressed the wrench icon (switching to processing mode), then pressed the "update program" and viola... the update succeeded.
Anyway - the CS2 and the booster is now updated and everything looks great. I haven't had the time to try out all the functions yet, but I hope to get a time slot from SWMBO very soon.
Best,
Burnix
Offline gachar001
#268 Posted : 03 June 2009 17:48:04(UTC)
gachar001
India
I tried updating my CS2 last night. No luck. I connected the CS2 to my router and started the update. It progressed fine with all the different color bars. After that, I got the language selection popup screen. I select English and click the check mark. Then I get a message saying the update was not successful.
I tried it many times (including what Burnix did with the wrench icon) but no luck.
I have always had a problem with my CS2 where on startup it always asks me to pick the language. Not sure if this is causing the problem.
Gautham
Atlanta, GA USA
Offline gachar001
#269 Posted : 03 June 2009 23:26:52(UTC)
gachar001
India
<br />Reset; then (re-)install version 1.0.5 using the USB; then perform the network update to 1.1.3. If this still fails wait until 1.1.3. is also available for USB. wink
I will try that. Thanks. Hopefully it will work.
Gautham
Atlanta, GA USA
Offline Burnix
#270 Posted : 04 June 2009 10:56:13(UTC)
Burnix
Regarding the changing colors I seem to remember that the bar color was blue while actually downloading the software and that when the bar cursor (grey) reached the end it jumped back to where the blue began and continued. I definitely remember that this looked different to what I had seen before.
I don't know if this is of any help, but I hope you will be able to update it successfully.
Best,
Burnix
Offline Olle3770
#271 Posted : 04 June 2009 15:28:46(UTC)
Olle3770
[size=1" face="Verdana" id="quote]quote:Originally posted by gachar001
Mine was like that until I specifically set the language i some preferences dialog and after that used the shutdown-button to actually make sure everything I did was saved properly. Don't know if this helps.
Offline jonas_sthlm
#272 Posted : 06 June 2009 16:15:46(UTC)
jonas_sthlm
Possible to programera CV 921 with the update? tried but could only come to 255
My updates work without any burnt up this time biggrin
Anyone who can tell how the process is to record the Turntable 7686 track with CS2 wink
http://www.maerklin.de/faq/show...;sb=5&o=&fpart=1
Do I need to connect 7686 with programme track ??
Managed to add button into layout biggrin
http://www.modelltag.se/download/file.php?id=200
Offline Fredrik
#273 Posted : 07 June 2009 11:41:14(UTC)
Fredrik
To program the TT your should first press the STOP-button (yes the BIG ONE!) to shut power of your layout. Then you press it again and within 5 seconds you must start programming your TT following the instructions in the TT-booklet. This "emergency-stop" procedure is considered as the "start-up" of the layout which is required to enter programming-mode of the TT-decoder.
And: No - you don't need to connect it to the programming track!
Fredrik.
WWW: MJ-fjärren
#274 Posted : 07 June 2009 12:30:42(UTC)
PS: Those icons -as well as the selected loco type on the MS display- are/can be stored in the decoder for a mfx loco and transferred to another controller (there is a new button on the related screen).
This statement is not 100% clear.
The icon ID is stored in the mFX decoder NOT the ICON itself.
If a function icon ID is configured by one controller (eg a CS2) that is not known by another controller (eg a CS1) it cannot extract the picture from the decoder.
Similarly for loco icons which are *.png images. To transfer this image you have to do it manually (USB update etc... ) or you can use the lococard.
6 Pages«<456
This page was generated in 1.019 seconds.
