Offline Alex H
#1 Posted : 09 February 2026 20:11:56(UTC)
Alex H
Hi.
I am in the process of installing the above turntable into my layout, controlled by a YaMoRC YD7010 controller and iTrain 5.1.16.
The turntable manual states that the decoder is preset to MM/mfx, and it can be changed to DCC operation in the Configuration. What it doesn't say is how to access the Configuration, or what the process is. More worryingly the manual says later on that to change to DCC the turntable has to be reprogrammed with a CS2 or CS3.
Does anyone know if there is a way around this, or do I need to find someone with a CS2/3?
Many thanks
Online Ross
#2 Posted : 10 February 2026 00:36:19(UTC)
Ross
Hi Alex,
If your YaMoRC YD7010 controller is able to switch points/turnouts with MM (Marklin Motorola) protocol then use MM protocol as the default and NOT DCC.
See your inbox for my response to you message.
Originally Posted by: Alex H Go to Quoted Post
Hi.
Many thanks
Ross
Marklin TT 74862 (General MRR)
by Drongo 19/05/2023 08:35:11(UTC)
This page was generated in 0.298 seconds.
